Circuit To Combine Mag P-Lead For RPM Measurements
Site Admin
PostPosted: Sun Apr 11, 2010 9:28 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
Has anyone found a device or circuit to pick off the output from the P leads on the left and right mags for feeding to an RPM measuring device such as the GRT EIS-4000? The EIS-4000 only has a single RPM input. The installation manual suggests installing a SPDT switch between the left/right mags and then to the input on the EIS-4000 for manually switching between the mags during drop testing. But that's pretty hoekey. Seems like someone should have come up with a simple prioritized switching circuit that would, say, always read the left mag p lead unless there wasn't a signal, then read the right mag P lead output. In my "spare time" maybe I'll make one if there isn't something already out there like this.
I thought that once upon a time I saw an electronic gizmo you could screw into the standard tack drive that would give an electronic output. Anyone have a line on this device and whether its compatible with the GRT EIS?
Thanks!!
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
rene(at)felker.com
PostPosted: Sun Apr 11, 2010 9:45 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
I use the switch. But I think Vans sells the tack drive unit.
1 plus for the switch.
From a raw data point of view, the switch is better since you are looking at
each mag in isolation.
Rene
801-721-6080
Ron.McGann(at)ausawd.com
PostPosted: Sun Apr 11, 2010 2:24 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
I'm with Rene. The switch is simple and works fine. Any electrickery needs to consider that one of the mags may be grounded during start.
Cheers
Ron
VH-XRM flying in Oz
bcondrey
PostPosted: Sun Apr 11, 2010 6:00 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
Matt,
You might check with GRT - I've heard that the newer versions of the EIS now come with 2 tach inputs. Might be an upgrade available.
RV-10 N442PM
