James Missler
Joined: 14 Jan 2006 Posts: 8 Location: Bellevue, Ohio
Posted: Thu Apr 22, 2010 6:25 pm Post subject: Kitfox-List Digest: 13 Msgs - 04/21/10 |
ASI problems;
I had simular problems on my first flight in my mod 3. Mud Dobers got into the pitot tube of which I thought I had removed all the dibris only to have some of the loose sand which they use flow into the asi and then plug the screne at the exit port of the indicator. I removed the indicator and all tubing conectors on the back side and was able to see the pluged screan. Holding the unit with the ports down I carefully brushed the screan with a soft fine wire probe and watched the dirt fall out. This worked for me and has been fine ever since. Your indicator may be different and I don' know why there is a screan at the exit port only except for possibly some backpressure to make it work right. I hope this will help you out too.
Jim Missler
Kitfox Mod 3
Jabiru 2200 Ser.# 976
Prince 64-28 Prop
Just Plane Fun To Fly
| Quote: | Date: Wed, 21 Apr 2010 23:59:43 -0700
To: kitfox-list-digest(at)matronics.com
Subject: Kitfox-List Digest: 13 Msgs - 04/21/10
Today's complete Kitfox-List Digest can also be found in either of the
of the Kitfox-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-04-21&Archive=Kitfox
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-04-21&Archive=Kitfox
Kitfox-List Digest Archive
Total Messages Posted Wed 04/21/10: 13
Today's Message Index:
1. 06:41 AM - Fuel pump rebuild (rosane beaule)
2. 08:04 AM - Re: Brake pedal ergonomics (jridgway)
3. 01:20 PM - Re: Gas fitting sealant (Perkins, Mike)
4. 02:07 PM - Re: Gas fitting sealant (Patrick Reilly)
5. 03:49 PM - Rotax fuel pressure (jridgway)
6. 05:42 PM - Re: Rotax fuel pressure (Roger Lee)
7. 05:43 PM - Re: Fuel pump rebuild (Roger Lee)
8. 05:47 PM - Re: Using a 912 alternator cover? (Roger Lee)
9. 06:27 PM - Re: Re: Using a 912 alternator cover? (sourdostan(at)aol.com)
10. 07:20 PM - Air speed Indicator (Patrick Reilly)
11. 07:36 PM - Re: Re: Using a 912 alternator cover? (paul wilson)
12. 08:07 PM - Re: Re: Using a 912 alternator cover? (Lowell Fitt)
13. 09:07 PM - Re: Using a 912 alternator cover? (Roger Lee)
________________________________ Message 1 _____________________________________
Time: 06:41:05 AM PST US
Subject: Fuel pump rebuild
Hi all, anyone knows the part number for a rebuild kit for the fuel pump
on a 912 and a good place to buy it?
thanks
Jack
________________________________ Message 2 _____________________________________
Time: 08:04:52 AM PST US
Subject: Re: Brake pedal ergonomics
raising the brake arm up 1.5 inch solved my problem. makes all the difference in
the world. however, they are no longer true 'toe-brakes'. You do have to lift
you feet some to get on them.
http://forums.matronics.com/viewtopic.php?p=295098#295098
________________________________ Message 3 _____________________________________
Time: 01:20:37 PM PST US
Subject: Re: Gas fitting sealant
From: "Perkins, Mike" <Michael.Perkins(at)rauland.com>
The best fuel sealant that I've found for threaded fittings is Dow 730
Solvent Resistant Sealant. It was specifically designed by Dow for use
with fuel and other solvents. It's been on my airplane for 16 years now.
It doesn't harden, so it doesn't crack. Also, it really doesn't have to
cure before you let gasoline at it - the fittings are ready to use right
away. But it's not cheap. Sit down for this - it costs $99.50 for a 3-oz
tube from Aircraft Spruce. Years ago I convinced Phil to start stocking
it. At first he thought I was crazy. Maybe you all will, too. But no
fitting has ever leaked with it. A tube will probably do 10 airplanes,
which is why I loan it to my friends. We have all had good experience
with it. I've kept mine in a frig since I bought it and it's still good.
- Mike
________________________________ Message 4 _____________________________________
Time: 02:07:49 PM PST US
Mike, Thanks for the recommendation. I put mine back together today with th
e
Permatex non hardening that I already had and that Lynn says he uses. I'll
put gas in it tomorrow. If it leaks again, I will bite the bullet and try
the stuff you recommend. Did you use it on fittings going into plastic tank
s
with worn threads?
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
On Wed, Apr 21, 2010 at 3:18 PM, Perkins, Mike
<Michael.Perkins(at)rauland.com>wrote:
> The best fuel sealant that I=92ve found for threaded fittings is Dow 730
> Solvent Resistant Sealant. It was specifically designed by Dow for use wi
th
> fuel and other solvents. It=92s been on my airplane for 16 years now. It
> doesn=92t harden, so it doesn=92t crack. Also, it really doesn=92t have t
o cure
> before you let gasoline at it ' the fittings are ready to use right awa
y.
> But it=92s not cheap. Sit down for this ' it costs $99.50 for a 3-oz tu
be from
> Aircraft Spruce. Years ago I convinced Phil to start stocking it. At firs
t
> he thought I was crazy. Maybe you all will, too. But no fitting has ever
> leaked with it. A tube will probably do 10 airplanes, which is why I loan
it
> to my friends. We have all had good experience with it. I=92ve kept mine
in a
> frig since I bought it and it=92s still good.
> - Mike
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
________________________________ Message 5 _____________________________________
Time: 03:49:56 PM PST US
Subject: Rotax fuel pressure
I am in the process of adding a electric fuel pump in parallel to my Rotax 582
(DCDI) single pressure pump. what pressure should I set the pressure regulator
at?
I have a pressure gauge on the plane now and it usually reads between 4-6 PSI with
the mechanical pump only.
thanks..Jack
Is 5 PSI to high or to low?
http://forums.matronics.com/viewtopic.php?p=295166#295166
________________________________ Message 6 _____________________________________
Time: 05:42:05 PM PST US
Subject: Re: Rotax fuel pressure
The max is 5.8 psi, but no real reason to set it up there. 5.0-5.5 would do just
fine. Normal for most engines while running is 3.1 - 4.6 psi
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=295181#295181
________________________________ Message 7 _____________________________________
Time: 05:43:28 PM PST US
Subject: Re: Fuel pump rebuild
No rebuild kit for the mechanical 912 pump. It is sealed. You have to buy the pump.
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=295187#295187
________________________________ Message 8 _____________________________________
Time: 05:47:12 PM PST US
Subject: Re: Using a 912 alternator cover?
Hi Clem,
If your electrical system is exposed you absolutely should cover it. Leaving it
exposed is too risky for your safety and for the engine. If something gets into
this it will be very costly. I would consider this as an important issue to
take care of.
I would be asking the question of where it went? They come with the cover on all
912's.
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=295188#295188
________________________________ Message 9 _____________________________________
Time: 06:27:01 PM PST US
Subject: Re: Re: Using a 912 alternator cover?
Earler ones didn't.
Stan Specht
On Apr 21, 2010, at 8:44 PM, "Roger Lee" <ssadiver1(at)yahoo.com> wrote:
> Hi Clem,
> Leaving it exposed is too risky for your safety and for the engine.
> If something gets into this it will be very costly. I would consider
> this as an important issue to take care of.
> cover on all 912's.
> Roger Lee
> Tucson, Az.
> Rotax Repair Center
> 520-574-1080
________________________________ Message 10 ____________________________________
Time: 07:20:47 PM PST US
Subject: Air speed Indicator
KFer's, What is the best way to test the ASI system? Mine registered stall
at 27 and cruise at 47. I tried rolling up surgical tube on the pitot tube
to get a reading to no avail. Is there a way to test the ASI seperately?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
________________________________ Message 11 ____________________________________
Time: 07:36:13 PM PST US
Right, that cover came with the new and improved pricing on the
912UL. It was about a $2k item.
Paul
At 07:15 PM 4/21/2010, you wrote:
>Earler ones didn't.
>Stan Specht
>Sent from my iPhone
>>Hi Clem,
>>cover on all 912's.
>>Roger Lee
>>Tucson, Az.
>>Rotax Repair Center
>>520-574-1080
>>Read this topic online here:
________________________________ Message 12 ____________________________________
Time: 08:07:42 PM PST US
Not true, Roger. My 1996 R-912 did not come with one. They were introduced
later to keep stuff from being dropped into the area and sticking to the
magnets. I don't think I ever had one, but I was extremely careful in that
area. I do, though agree that they are a good idea. I have one on my new
(second hand) engine.
Lowell
Sent: Wednesday, April 21, 2010 5:44 PM
> Hi Clem,
> Leaving it exposed is too risky for your safety and for the engine. If
> something gets into this it will be very costly. I would consider this as
> on all 912's.
> Roger Lee
> Tucson, Az.
> Rotax Repair Center
> 520-574-1080
________________________________ Message 13 ____________________________________
Time: 09:07:48 PM PST US
Hi Lowell,
If they didn't come that way back then, I stand corrected (Thanks), but I'd certainly
get one on there now. I don't think I have ever had an engine come through
here without one. I know how much those parts cost and how much labor cost
are to fix some of those things in that area. That cover cost $75. The parts
and labor could easily make it ten+ times that to fix broken items depending on
the damage.
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=295220#295220
The New Busy is not the old busy. Search, chat and e-mail from your inbox
_________________ Jim Missler, Kitfox 3, Jabiru 2200, Prince P Tip Prop 64-28, Just plane fun. Bellevue, Ohio |
Pat Reilly
Posted: Fri Apr 23, 2010 9:13 pm Post subject: Kitfox-List Digest: 13 Msgs - 04/21/10 |
Jim, Thanks. My problem was easier to diagnose and fix. A piece of surgical tubing connecting the pitot tube and the plastic tube in the wing had rotted and was leaking. An access port was at that point and despite the aluminum diagonal brace in the way, I was able to replace it.
Pat Reilly
On Thu, Apr 22, 2010 at 9:24 PM, James Missler <misslerfarms(at)msn.com (misslerfarms(at)msn.com)> wrote:
| Quote: | ASI problems;
Jim Missler
Kitfox Mod 3
Prince 64-28 Prop
| Quote: | Subject: Kitfox-List Digest: 13 Msgs - 04/21/10
| Quote: | =========================
| Quote: | and Message Navigation. The .txt file includes the plain ASCII version
| Quote: | ---
| Quote: | 1. 06:41 AM - Fuel pump rebuild (rosane beaule)
| Quote: | 6. 05:42 PM - Re: Rotax fuel pressure (Roger Lee)
> 9. 06:27 PM - Re: Re: Using a 912 alternator cover? (sourdostan(at)aol.com (sourdostan(at)aol.com))
| Quote: | 10. 07:20 PM - Air speed Indicator (Patrick Reilly)
| Quote: | 13. 09:07 PM - Re: Using a 912 alternator cover? (Roger Lee)
From: "rosane beaule" <rob10(at)tlb.sympatico.ca (rob10(at)tlb.sympatico.ca)>
| Quote: | Hi all, anyone knows the part number for a rebuild kit for the fuel pump
thanks
Jack
Subject: Kitfox-List: Re: Brake pedal ergonomics
From: "jridgway" <jridgway(at)academicplanet.com (jridgway(at)academicplanet.com)>
| Quote: | ________________________________ Message 3 _____________________________________
From: "Perkins, Mike" <Michael.Perkins(at)rauland.com (Michael.Perkins(at)rauland.com)>
| Quote: | The best fuel sealant that I've found for threaded fittings is Dow 730
| Quote: | cure before you let gasoline at it - the fittings are ready to use right
| Quote: | it. At first he thought I was crazy. Maybe you all will, too. But no
| Quote: | with it. I've kept mine in a frig since I bought it and it's still good.
- Mike
Subject: Re: Kitfox-List: Gas fitting sealant
From: Patrick Reilly <patreilly43(at)gmail.com (patreilly43(at)gmail.com)>
| Quote: | Mike, Thanks for the recommendation. I put mine back together today with th
e
| Quote: | s
with worn threads?
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
> <Michael.Perkins(at)rauland.com (Michael.Perkins(at)rauland.com)>wrote:
> th
| Quote: | > fuel and other solvents. It=92s been on my airplane for 16 years now. It
o cure
> y.
| Quote: | > But it=92s not cheap. Sit down for this ' it costs $99.50 for a 3-oz tu
be from
t
| Quote: | it
in a
| Quote: | > - Mike
> Pat Reilly
| Quote: | Mod 3 582 Rebuild
Rockford,IL
| Quote: | at?
> thanks..Jack
From: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Roger Lee
Tucson, Az.
Roger Lee
Tucson, Az.
> Rotax Repair Center
Hi Clem,
| Quote: | this it will be very costly. I would consider this as an important issue to
take care of.
> 912's.
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
Stan Specht
On Apr 21, 2010, at 8:44 PM, "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
| Quote: | >
> Hi Clem,
| Quote: | > this as an important issue to take care of.
> > cover on all 912's.
| Quote: | >
> Roger Lee
> Tucson, Az.
> Rotax Repair Center
> 520-574-1080
| Quote: | >
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
From: paul wilson <pwmac(at)sisna.com (pwmac(at)sisna.com)>
Paul
>Earler ones didn't.
| Quote: | >Stan Specht
>Sent from my iPhone
| Quote: | >>
>>Hi Clem,
| Quote: | >>this as an important issue to take care of.
> >>cover on all 912's.
| Quote: | >>
>>Roger Lee
>>Tucson, Az.
>>Rotax Repair Center
> >>520-574-1080
| Quote: | >>
From: "Lowell Fitt" <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)>
| Quote: | (second hand) engine.
Lowell
| Quote: | Subject: Re: Using a 912 alternator cover?
> Hi Clem,
| Quote: | > something gets into this it will be very costly. I would consider this as
| Quote: | > on all 912's.
> Roger Lee
> Tucson, Az.
> > Rotax Repair Center
| Quote: | >
Hi Lowell,
| Quote: | here without one. I know how much those parts cost and how much labor cost
| Quote: | the damage.
Roger Lee
Tucson, Az.
> Rotax Repair Center
> _================
The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started. | Quote: |
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
