zharvey(at)bentoncountyca Guest
Posted: Mon Aug 02, 2010 2:31 am Post subject: Gear legs |
I have a Kolb Firestar KXP with a slightly bent landing gear leg. Doesn't seem to be getting any worse but I'm wondering if I bend it straight will bending weaken it? Can I just take it off and use a press to straighten it or must it be heated? Is the landing gear a weak link and if so is there a better one to use? Any suggestions are welcome.
I would like to add, that after owning and flying a goodly number of planes (both ultra lights and GA) over more years than I care to admit, I've never had a plane I enjoy flying as much as I'm enjoying my Kolb. I'm undergoing Chemo and have very little energy, but somehow I find enough energy every morning to make it out to the airport at daylight, and go flying in my KXP while it's cooler out (very hot here in Tennessee and I'm from Alaska). Homer knew what he was doing.
Gene
KXP N71RB
Camden, Tn.
Posted: Mon Aug 02, 2010 3:34 am Post subject: gear legs |
Gene- Straightening legs is common. They are supposed to be the weak link in order to protect the "A" frame. There was a thread a couple of weeks ago, and a search of the archives will show photos of how to do it on the plane. Might be listed under landing gear. Doesn't seem to weaken them, according to what I've read. Right now a lot of the people on the list are at Oshkosh, but John Hauck ought to be available on the List this morning. Maybe he can refer you to specific search words. Jack Hart's "Firefly Slide Show" also has info.
Hang in there with the chemo- my daughter has niceley recovered from it. Good luck.
Bill Sullivan
Windsor Locks, Ct.
FS 447
jhankin(at)planters.net Guest
Posted: Mon Aug 02, 2010 4:18 am Post subject: gear legs |
Gene, I am the one that had the post about straightening the gear legs on the Kolb.
If you can’t find the post, let me know and I will send them to you directly.
Jimmy Hankinson
Rocky Ford, Ga.
912 863 7384
N6007L, Firefly
JYL Sylvania, Ga.
George Alexander
Posted: Mon Aug 02, 2010 4:25 am Post subject: Re: Gear legs |
| zharvey(at)bentoncountyca wrote: | I have a Kolb Firestar KXP with a slightly bent landing gear leg. Doesn't seem to be getting any worse but I'm wondering if I bend it straight will bending weaken it? Can I just take it off and use a press to straighten it or must it be heated? Is the landing gear a weak link and if so is there a better one to use? Any suggestions are welcome.
Try this link to the forum......
http://forums.matronics.com/viewtopic.php?t=72986
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
rickofudall
Posted: Mon Aug 02, 2010 7:59 am Post subject: Gear legs |
Gene, When I got my Mk IIIC I became intimate friends with Mr Hydraulic Press until I figured out the right combination to land it. You should straighten it cold. It will gradually make the leg weaker if you have to straighten it a lot, but once or twice won't make a lot of difference. The advice I got from Travis was to keep the aluminum legs until I was confident with my landings. When you arrive with sufficient energy to bend a gear leg you also have enough energy to bend the fuselage cage, too. The aluminum legs are cheap and straightenable in an evening, the fuselage cage is expensive and takes somewhat more time to return to flying condition. I made up short pieces of plastic pipe to protect the leg from hard edges when staightening and I use a pair of blocks as you have to force them quite a bit beyond straight opposite the bend in order to take it out. 7075-T6 pretty tough stuff so take your time and you'll figure it out. I usually have to bend in two or three places to take out the bend without kinking the leg.
Happily I am no longer in practice anymore. Just take your time and you'll be fine.
I've never flown a KXP, but it seems that Kolbs are as much smile generators as they are aircraft.
Rick Girard
On Mon, Aug 2, 2010 at 5:30 AM, Gene & Tammy <zharvey(at)bentoncountycable.net (zharvey(at)bentoncountycable.net)> wrote:
[quote] I have a Kolb Firestar KXP with a slightly bent landing gear leg. Doesn't seem to be getting any worse but I'm wondering if I bend it straight will bending weaken it? Can I just take it off and use a press to straighten it or must it be heated? Is the landing gear a weak link and if so is there a better one to use? Any suggestions are welcome.
Gene
KXP N71RB
Camden, Tn.
Posted: Tue Aug 03, 2010 2:31 pm Post subject: gear legs |
Jimmy, great looking rig! If I keep bending, I'll build one.
Gene
Sent: Monday, August 02, 2010 7:14 AM
Subject: RE: Re: gear legs
Jimmy Hankinson
Rocky Ford, Ga.
912 863 7384
N6007L, Firefly
JYL Sylvania, Ga.
