		fklein(at)orcasonline.com Guest
				 Posted: Tue Nov 09, 2010 10:25 am    Post subject: instrument sub-panels |
				I'd very much appreciate counsel tempered by experience on the
 desireable thickness of aluminum sheet for the instrument sub-panels.
 I've used some .040" 6061-T6 which was laying around, but I've
 concluded it's way too thin.
 Many thanks,
 Fred
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Rocketman
				 Posted: Tue Nov 09, 2010 1:26 pm    Post subject: instrument sub-panels |
				Fred, .063 works fine in Baby Blue.  .080 is good, too, but heavier and,
 in my opinion, not necessary...
 Jeff
 On 11/9/2010 12:14 PM, Fred Klein wrote:
  I've used some .040" 6061-T6 which was laying around, but I've concluded
  it's way too thin.
  Many thanks,
  Fred
		david steade
				 Posted: Wed Nov 10, 2010 1:14 am    Post subject: instrument sub-panels |
				Fred
  I used .080"  (2mm) seemed about right . After I cut  all the holes there is not much left and the panels have to support a lot of  weight after they are populated.
  David Steade
  _________________ David Steade |
		frans(at)privatepilots.nl Guest
				 Posted: Wed Nov 10, 2010 2:41 am    Post subject: instrument sub-panels |
				On 11/10/2010 10:02 AM, Steade wrote:
  	  | Quote: | 	 		   I used .080"  (2mm) seemed about right . After I cut all the holes there
  they are populated.
 I used 2mm too. Keep in mind that my panel is much larger than the
 standard Europa panel; if it works for me it should work for you too. It
 is true that after the holes are cut the panel appears weakened, but
 populating the panel stiffens it up considerably. Actually it is more
 rigid than before, as the instruments have less tendency to bend and
 flex than the aluminium sheet itself.
 I used one horizontal T-shaped stiffener reduxed in halfway down the
 panel. The panel is strong enough to support all instruments, but I made
 an additional support at the rear of my electrical gyro because of its
 length and thus leverage.
 I operate the Europa mainly from a bumpy soft field, transport the
 Europa for every flight over the road on its trailer, so it sees a lot
 of vibration and bumps. So far, after nearly 100 hours, the panel is
 holding up very well with no signs of fatigue.
 Frans
				 Posted: Wed Nov 10, 2010 5:14 am    Post subject: instrument sub-panels |
				Fred,
 If you want something with a real "cool factor" you can use carbon fiber sheet. Take a look at http://www.dragonplate.com/default.asp
 Paul
 On Tue, Nov 9, 2010 at 12:14 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
 [quote] --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
  I'd very much appreciate counsel tempered by experience on the desireable thickness of aluminum sheet for the instrument sub-panels.
  I've used some .040" 6061-T6 which was laying around, but I've concluded it's way too thin.
  Many thanks,
  Fred
				 Posted: Wed Nov 10, 2010 9:46 am    Post subject: instrument sub-panels |
				Thanks to all who've responded to my question...wow!...the world of
 carbon fiber is something to behold...a tad spendy...easy to see why
 our airframes are FG instead of CF...looks like .080" alum. would
 serve me well...
 Fred
