		| Author | Message |
		| graeme bird
				|  Posted: Sat Mar 19, 2011 2:51 pm    Post subject: Old Style Fuel Pipe |   |
				| I have the old style rubber long fuel fill pipe in my build though its the later type. I see this was changed for the plastic side filler. Is there anything inherently wrong with the old one (though its heavy ish)?
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Sat Mar 19, 2011 4:22 pm    Post subject: Old Style Fuel Pipe |   |
				| Graem
you're right, its too heavy. It does tend to allow the smell to get into the airplane too. Swap it for a solid aluminium one of you can, just use the rubber bends to joint the ally. Or of course buy the plastic "cobra" and use that.
 I would also recommend using an solid Al breather pipe and ground it, then it won't behave like a Van De Graaf generator and generate sparks when vapour and drops of fuel rush up the breather while filling.
 One refueling fire due to this, G-**DP after a flight on a hot dry day in Germany. I suspect the spark went from the breather metal tube to the metal funnel which was grounded by Jens(at) hand. He got burnt but fortunately not as badly as -DP.
 BTW the breather pipe is too small, this is why it takes so long to fill a Classic Europa, the XS isn't a lot  better.
 Graham
 apologies for ranting, my friend makes me cross occasionally. ( I have been known to annoy him too)
 Sent: Saturday, 19 March, 2011 22:51:27
 Subject: Europa-List: Old Style Fuel Pipe
 --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
 Graeme Bird
 G-UMPY
 Mono Classic/XS FWFD 912ULS/Warp drive FP
 Build nearing completion
 http://forums.matronics.com/viewtopic.php?p=334461#334461
 http://forums.matronics.                     tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
		| Back to top |  |
