		Masqqqqqqq(at)aol.com Guest
				 Posted: Thu Jan 12, 2006 11:43 am    Post subject: glider wings on UltraStar? |
				I hope this doesn't sound too outlandish.......but......
       I have  1984 Kolb UltraStar which I purchased used in 1994.  I've flown
 it often, and love it.  It's powered by a 447 Rotax.
      Lately, I find myself interested in unpowered gliders.  Here's the
 question:  Has anyone ever replaced the wings on an UltraStar with the larger
 glider style wings, removed or downsized the engine, and had a glider?  I suspect
 there would be some balance issues to address, but I'm wondering if it's been
 done.
     Rich Iverson
     Stevens Point, WI
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		JetPilot
				 Posted: Thu Jan 12, 2006 6:33 pm    Post subject: Re: glider wings on UltraStar? |
				There would be a LOT of drag issues.  Its not just the wings, you need a new fuse also...   In the end, you are better off just building a glider from the ground up if that is what you want.
 If you try to make a powered ultralight into a glider, you will end up putting a huge amount of work into it and still have a dog that will not glide well.   That is a really bad idea...
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		rswiderski(at)earthlink.n Guest
				 Posted: Thu Jan 12, 2006 8:07 pm    Post subject: glider wings on UltraStar? |
				Hey Rich,
 	I often thought about doing what you are thinking with my old US.  I
 could catch thermals with engine off here in FL & get 100-150 fpm lift
 sometimes, but usually it wasn't enough to get too far.  I came close to
 adding 3ft wing extensions using a piano hinge connection, but ended up
 selling it, (I still wake up crying about that.)  I was raised in Mosinee,
 just north of you & still have family up there.  -Richard Swiderski
