Yak 18T prop
Francois Davel
PostPosted: Sun Oct 02, 2011 9:15 pm    Post subject: Yak 18T prop Reply with quote
Hi there Friends
My prop is coming up for overhaul, and it will have to go to the guys here in South Africa, there is only one place that will do it....the sad news, I have heard of hassles being had after the overhaul....
I am wondering what are the tricks to this overhaul? are the seals very specific? Is there anything that needs to be checked on before and after the work is done so I can be sure that the work has been done correctly!
Cheers and thanks
Francois Howick South Africa
Round Engines RULE!
CD 2.0
PostPosted: Sun Oct 02, 2011 9:23 pm    Post subject: Re: Yak 18T prop Reply with quote
Francois.... what propeller and aircraft models are you referring to?
This would help to provide a more specific answer to your question.
Carl
Francois Davel wrote:
Hi there Friends
Cheers and thanks
Francois Davel
PostPosted: Mon Oct 03, 2011 2:22 am    Post subject: Re: Yak 18T prop Reply with quote
Hi there, my apologies.....it is the standard 2 blade wooden prop.
My Prop log book says model V530TA-D35
Cheers
Francois
Round Engines RULE!
cjpilot710(at)aol.com
PostPosted: Mon Oct 03, 2011 3:56 am    Post subject: Yak 18T prop Reply with quote
Hope they don't put the "V" seals in backwards!! Smile
Pappy
GeorgeCoy
PostPosted: Mon Oct 03, 2011 4:21 am    Post subject: Yak 18T prop Reply with quote
We have hub parts including new seals, piston assemblies, cylinder dome
assemblies, pitch change blocks and thrust bearings in stock if needed.
viperdoc(at)mindspring.co
PostPosted: Mon Oct 03, 2011 8:40 am    Post subject: Yak 18T prop Reply with quote
Pappy,
The Contact name at Aerostar is Christian Dragori. I have lost his #’s though.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Monday, October 03, 2011 6:54 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Yak 18T prop
Pappy
dsavarese0812(at)bellsout
PostPosted: Mon Oct 03, 2011 9:48 am    Post subject: Yak 18T prop Reply with quote
For those that are wanting to do this, it is a simple fabrication. The
nose case must have the left side (as seen from the cockpit) round
access panel. Usually found on Series II engines. But not always
associated with Series II.
Obtain a piece of clear Plexiglas, 1/4" thick, large enough to cover the
opening in the nose case when the round access panel is removed. Cut the
Plexiglas to size and secure it to the nose case with the screws/bolts
removed from the metal access panel. You will need a new gasket. That's it.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 10/3/2011 11:37 AM, Roger Kemp M.D. wrote:
Pappy,
The Contact name at Aerostar is Christian Dragori. I have lost his #�s
though.
Doc
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of
*cjpilot710(at)aol.com
*Sent:* Monday, October 03, 2011 6:54 AM
*To:* yak-list(at)matronics.com
*Subject:* Re: Re: Yak 18T prop
Pappy
pfstelwagon(at)earthlink.
PostPosted: Mon Oct 03, 2011 3:44 pm    Post subject: Yak 18T prop Reply with quote
Great idea, but I think I would use Lexan- a lot tougher. TAP Plastic shops usually have small pieces.
Frank CJ-6A
PostPosted: Mon Oct 03, 2011 4:13 pm    Post subject: Yak 18T prop Reply with quote
Agree.
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Frank CJ-6A
CD 2.0
PostPosted: Mon Oct 03, 2011 5:23 pm    Post subject: Re: Yak 18T prop Reply with quote
Francois, sorry I didn't realize you mentioned the name of the aircraft in the title of the thread.
Have you considered the option of doing the overhaul overseas and then just installing the finished product in SA? Just PM you some detailed info that should be quite helpful if you consider that option.
Carl
Cheers
Francois
