SkyView power wires
PostPosted: Fri Sep 14, 2012 7:06 am    Post subject: SkyView power wires Reply with quote
Quote from SkyView installation manual:
Power Input
SkyView displays have a primary power input that is compatible with 12 volt and 24 volt systems (10 to 30 volts DC). There are two unterminated solid red primary power input wires (to reduce current loading in each wire—these are not for redundancy and both should be connected to the same power source) and two unterminated solid black primary ground wires.
Ensure that there is an appropriately rated circuit breaker or replaceable fuse on the primary power input. A 5 amp circuit breaker or replaceable fuse is sufficient for the majority of installations. Reference the Power Consumption Section of the System Planning Chapter for more information.
I do not understand the reasoning for using two power wires instead of one larger wire. In fact, it would seem that just one small wire would handle the 5 amp load with ease.
Joe
Joe Gores
grosseair(at)comcast.net
PostPosted: Fri Sep 14, 2012 7:57 am    Post subject: SkyView power wires Reply with quote
Have you asked the SkyView people? The rest of us can only guess at
their rationale for the "why". Personally, I can't imagine any reason,
but I have seen other applications where a larger wire would not fit in
the connector and two smaller wires were used.
John Grosse
> > Power Input
Joe
Joe Gores
PostPosted: Fri Sep 14, 2012 9:27 am    Post subject: SkyView power wires Reply with quote
Joe
That IS a puzzlement . . . I don't recall the first
time I saw doubled-up power and ground wires on
radios . . . but it was some years back. Why
would a designer think that paralleled 20AWG
wires on a 0.5A continuous, 4A intermittent
load be a good thing to do? I think I've
seen it on more than one brand of radio.
Reduced supply impedance? Not very likely.
Increased redundancy? Hmmmm . . . more
plausible. Redundancy is not well addressed
. . . one of the wires could be bad and you\
wouldn't know it. I.e. redundancy that calls
for periodic inspection to retain its value
in the reliability tree. Current sharing on
d-sub pins? Also plausible but again, the pins
are not really being stressed that hard.
The conundrum does not yield to present
reasoning.
If it were my radio, I'd do the paralleling
thing with 6 inch, 22AWG wires in the pins
dropped into a splice with 20AWG lead wire
to power and ground. Robust . . . and doesn't
let a perfectly good ground or power pin go
to waste.
