ppeerenbo(at)charter.net Guest
Posted: Thu Jun 01, 2006 3:27 am Post subject: Cracked Eng Mount |
I have a Model IV with a 912UL 360TT. I found a eng mount crack on the short
tube that connects the top mounts, left side. The crack looked like a stain
on the powered coated mount that wiped off. I cleaned the paint off and the
tube is cracked half way around. Can any one give me information on the
mount? Wall thickness, any weld repair advice is welcome.
Paul N102DG
Jim Shumaker
Posted: Thu Jun 01, 2006 5:11 am Post subject: Cracked Eng Mount |
Paul
I just found a crack on my model III 912ul. It was on the top of the ring tube of the dynafocal mount. When I pulled the engine, one of the short tubes was also cracked. I have not even done a complete inspection yet. Will keep you informed as to what I find.
Even with two cracked tubes on the mounts the engine felt tight and secure on the frame.
Jim Shumaker
Paul N102DG
_________________ Jim Shumaker |
jimmieblackwell(at)sbcglo Guest
Posted: Thu Jun 01, 2006 7:24 am Post subject: Cracked Eng Mount |
This the third engine mount problem, (including mine), with the 912 UL in the last two weeks. I wanted to ask Jim and Paul to post a picture of their cracked mounts on Sportflight and let's try to determine if there is are some common denominators such as torque or total hours on the mount when it fails. Looks like Paul and I had about the same amount of hours when the failure occurred.
My rubber engine mount pads had been changed within 15 hours of when my engine mount broke. When changing the rubber pads I torgued all the hardware according to the latest Model IV building manual. I can't help but wonder if the torque settings may be wrong or if there was a batch of bad engine mounts produced at some point. Hopefully, some of you with more experience and knowledge can help us figure out what is causing the engine mount failures before someone hurts their Kitfox or worse, themselves.
Jimmie
James Shumaker <jimshumaker(at)sbcglobal.net> wrote:
Paul
Jim Shumaker
Paul
Paul N102DG
smokey_bear_40220(at)yaho Guest
Posted: Thu Jun 01, 2006 7:58 am Post subject: Cracked Eng Mount |
Jimmie and all,
I do not have the 912, but wonder after reading other
posts on this list if it isn`t a problem with start
and shutdown shaking from the high compression.
Unless you have inflight vibration that occurs at rpms
you should stay away from, it would seem the biggest
vibration is durning starting and stopping. Different
props would likely mean different running vibrations,
so unless your props are the same, that should not be
the problem.
Do you have clutches installed?
How much does the plane shake when you start?
Do you notice inflight vibs?
Have you had exhaust cracks that would indicate
running vibs?
Carbs falling off?
These questions have been raised before on the list
and there may be a connection.
Kurt S. S-5/NSI turbo
--- Jimmie Blackwell <jimmieblackwell(at)sbcglobal.net>
wrote:
| Quote: | This the third engine mount problem, (including
Posted: Thu Jun 01, 2006 3:01 pm Post subject: Cracked Eng Mount |
I will take a picture this weekend. I have had a carb come off 200 plus hrs
ago, balancing carbs, new carb sockets, and spring kit seams to have taken
care of that. 100 plus hrs ago I did the mod to stiffen the eng mounts
(shorten the bushings). Its more than likely that this has been cracked for
a wile. Its appears to emanate from the weld and I would say it went aft
first and could go unnoticed easily. I am an airline mechanic for 27 years,
including time as a level II NDT, PT, UT, ET & PM. If I had just wiped the
stain and not go further with power coat removal, it would go till the next
annual inspection, this is a very fine tight crack. I do not have a slipper
clutch, and the 912 does shake if you don't get a clean start. The start
procedure that was on this list of using choke with the ignition off and let
sit, then set the throttle seams to work better than the primer system. ( I
took that off) I have never had exhaust or any real fretting problems, when
running the 912 is awsom powerplant.
Paul N102DG
mike Guest
Posted: Thu Jun 01, 2006 4:43 pm Post subject: Re: Cracked Eng Mount |
another thing to be concerned about is shut down. What I do is run the rpm's up to about 3000 and then turn off the mags and pull back on the throttle as far as it will go at the same time.
Jim Shumaker
Posted: Thu Jun 01, 2006 9:51 pm Post subject: Cracked Eng Mount |
I'll try to get pictures up this weekend also.
My guess is that it is the shaking of the engine. There is not any distortion associated with the cracks on my engine and they are not cracked all the way around.
Jim Shumaker
Paul N102DG
gjglh(at)cebridge.net Guest
Posted: Fri Jun 02, 2006 5:38 pm Post subject: Cracked Eng Mount |
I had to pull my engine because of a cracked motor mount. Facing the engine the top
left verticle downward tube broke of 3/4" above rubber mounts and the right side of
the cross tube for the upper mounts had a crack 1/2" in. I put an outer tube layer
on each tube to give added strength.
Gary
M-IV Speedster
On Fri Jun 2 1:48 , James Shumaker <jimshumaker(at)sbcglobal.net> sent:
around.
Jim Shumaker
Paul N102DG
Jim Shumaker
Posted: Sat Jun 03, 2006 6:16 am Post subject: Cracked Eng Mount |
The cracks on my mounts seem to be in the same places.
Jim Shumaker
Gary
M-IV Speedster
On Fri Jun 2 1:48 , James Shumaker sent:
around.
Jim Shumaker
Paul N102DG
pwmac(at)sisna.com Guest
Posted: Tue Jun 06, 2006 3:10 pm Post subject: Cracked Eng Mount |
There are many examples of cracked mounts before Skystar came up with
the heavy wall mount $$. Most of the cracks were in the tubing - not
even close to the welds. Guys with powder coated mounts found the
cracks were hidden by the coating because the coating is so flexible.
I would strongly recommend removing the coating on all the upper
tubes from weld to weld and making a close examination. When the
repair is complete don't powder coat use and enamel paint which is
brittle and will reveal a crack as soon as it happens. White is the
best color for showing cracks.`
BTW, there are several reports of the Skystar repairs failing again,
but fix I used is much better than the temporary fix that Skystar was
using and did not work.
If you want the details on how to do a DIY beefup/repair let me know
and I will PM you with pics and specs which Frank Miller gave me.
This info is applicable for the M4 mount which was a Skystar design.
If the newer models use the Rotax style with the circular /ring mount
then I would be of no help.
I hesitate to post the long winded message on the list so If someone
else wants the info I will send it to them as well.
Avoid cracks by using a protocol for start and shutdown that
eliminates engine shake, but, that is another thread.
Regards, Paul W
Paul N102DG
