Fred Klein
Posted: Thu Jul 04, 2013 9:12 am Post subject: windscreen de-fogging |
Gentlemen,
I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job.
If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful
I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK.
Thanks in advance,
Fred
A-194
frans(at)privatepilots.nl Guest
Posted: Thu Jul 04, 2013 9:43 am Post subject: windscreen de-fogging |
On 07/04/2013 07:12 PM, Fred Klein wrote:
Quote: | I'm attempting to select a couple of computer fans to be mounted
I did that too, and despite our damp climate I have used them only twice
(and found out that they didn't contribute much anyway).
You'd probably better save the weight.
Frans
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Jul 04, 2013 9:59 am Post subject: windscreen de-fogging |
Fred Klein a écrit :
Quote: |
Gentlemen,
Hi Fred,
Here is what we did recently :
http://contrails.free.fr/cellule_defog_en.php
Not much weight involved (about 700-800 g) though we feel that our 380
kg four seater is a bit on the heavy side
FWIW,
Best regards,
Gilles
rparigoris
Posted: Thu Jul 04, 2013 10:12 am Post subject: windscreen de-fogging |
Hi Fred
"If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient"
I chose to use four 12 volt mini fans. They are run off a 3 position (low, high and off). If 2 are put in series it's low, and if run off bus voltage, then high. Yes idea as a minimiist demister but also to get heat out from under instrument module. You can find info on what I am doing (I did quite a bit of fooling with different fans. There is also a folder on that page "Panel cooling and demisting ideas by others."
http://www.europaowners.org/main.php?g2_itemId=27305
I am installing temp probes under the instrument module so will be able to see temps.
Ron Parigoris [quote][b]
budyerly(at)msn.com Guest
Posted: Thu Jul 04, 2013 11:35 am Post subject: windscreen de-fogging |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Ron,
I installed both 40 mm and 80 mm computer CPU fans and frankly, the 40s don't move that much air. The 80s do better at venting the hot air out of the panel. Some electronics get quite warm and I wanted to cool the panel, not really defrost. That was a hopeful side effect of the installation of the fans.
The first setup on 12AY I put the fans too far forward and they blow into the windscreen support. To be honest, I can't even feel the air flow moving up the windscreen, it moves sideways. That was a dumb execution of a good idea.
On others, I move the fans as far aft toward the pilot as I can to pull the Garmin 430 and Dynon Skyview heat out of the panel. They both get pretty hot. I have found that the air comes up the windscreen, but is not hot enough or fast enough in the winter to feel like a defogger, but at least it moves the air up the windscreen. If you have an Ameriking type cooling fan, one leg of that would be about as strong as my two 80s...
The Grand Rapids and Becker radios are pretty cool running and frankly the panel only gets about 10 degrees warmer than the cockpit, so without the heat and high forced air flow of an auto type defogger, I do not see it as much help on a cold day at altitude with a quick descent to the warmer air below steaming things up.
Sorry I don't have more info for you. It's just too hot here in Florida. Even in the winter, although my canopy top fogs up and my screen fogs for a second or two, they both clear once the inside and outside temps stabilize.
Bud
kevinmarie(at)blueyonder. Guest
Posted: Thu Jul 04, 2013 11:40 am Post subject: windscreen de-fogging |
I have no fans and it gets a little fogged up on the ground in the winter but I open the door and it clears. I never have any problems in the air and I have no heater.
Kevin Challis
G ODJG
Tri gear 912s
On 4 Jul 2013, at 19:12, Fred Klein <fklein(at)orcasonline.com> wrote:
Quote: |
Gentlemen,
Thanks in advance,
Fred
A-194
rampil
Posted: Fri Jul 05, 2013 3:32 pm Post subject: Re: windscreen de-fogging |
i have read the discussion on the issue of defogging and it appears that
are no actual answers out there yet regarding airflow, temperature, etc.
I will add my meager data to the pool
My bird has a Blue Mountain EFIS 4 series which shuts down at temps
above abt 144F. I have a 24 cfm fan in a convective tower directly
above the EFIS leading into a 3 in louver directed into the plexi.
On a 90F sunny day as so many local days are here on Long Island,
without the fan, the EFIS will blackout within an hour of the plane out
of the hangar, flying or not. The installed fan slows the inexorable rise somewhat
say by 15 min to overheat. Clearly unacceptable cooling. However,
it has actually cleared plexi condensation in two instances where it existed,
in about 5 minutes (this was light grey mist, not dripping condensation).
As I contemplate my move to much warmer clime, i will need to
re-engineer the cooling. These little muffin fans are not likely to be useful
even if ganged together. High velocity outside air is probably the best answer. Actual flight testing is needed.
As usual, your mileage will vary
Ira
Posted: Fri Jul 05, 2013 5:32 pm Post subject: windscreen de-fogging |
You might want to try a couple of the 12v brushless DC fans, they range in
size from 30mm up to about 200mm
They move a lot of air for their size, like the ones you find in your
computer to ventilate the case
I had two network file servers running inside a closed cupboard total load
of about 1000w with a hole in the bottom
Back of the cupboard and one 100mm brushless DC fan to extract the air at
the top and didn't have an issue with them overheating
Worth a look at least, they normally run about $10 each, or free if you can
get your hands on a couple of old computers and pull them apart
To get the fans out of the power supply's
http://www.ebay.com.au/itm/2x-Brushless-DC-Cooling-Fan-12V-120mm-x-120mm-x-2
5m-/180729347608?pt=AU_Components&hash=item2a144efe18
this link just goes to one I found on ebay no doubt you could find your own
regards
craig
Posted: Fri Jul 05, 2013 10:48 pm Post subject: windscreen de-fogging |
Ira, I have a comparable system to keep my Blue Mountain
EFIS happy, although my fan has inlet above pax feet and
outlet through a dozen holes blowing on to pilot screen.
Moderately effective as demister, but EFIS starts to
complain when temps get up into vicinity of 35C (95 in
your old units). I have found that laying a layer of 5mm
neoprene with foil on one side, across top of panel (which
is painted dark blue for visibility) cuts out direct sun
heating and addresses the problem. So I have that Neoprene
sheet available in the back and use it intermittently in
exceptionally hot conditions
Regards, David Joyce, G-XSDJ
On Fri, 5 Jul 2013 16:32:15 -0700
it appears that
temperature, etc.
down at temps
tower directly
the plexi.
Long Island,
of the plane out
However,
need to
needed.
Ira
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=404012#404012
Un/Subscription,
Forums!
Admin.
Duncan McFadyean
Posted: Sat Jul 06, 2013 12:50 am Post subject: windscreen de-fogging |
I took an air feed off the top of one of the side NACA ventilators,
primarily to squirt cool air over the back of the Terra transponder (which
(and the radios too) don't appreciate being cooked behind the standard
sealed Europa panel). There are slots cut in the top of the panel below the
bottom of the windscreen. It's not foolproof for demisting on the ground
(but a wiping cloth is!), but it does keep mist cleared in flight. I had one
computer fan previously, which worked similarly, but I took it out (heavy,
noisy, power consumer).
DMcF.
rampil
Posted: Sat Jul 06, 2013 3:13 pm Post subject: windscreen de-fogging |
The 120mm brushless dc fan I linked to yesterday was supposed to move 25 CFM
and draw about .4 of an amp
Noise level 25db doesn't say what the weight is, but past experience I would
say it would be around 100g
