		| Author | Message |
		| craigb(at)onthenet.com.au Guest
				|  Posted: Fri Jul 26, 2013 3:00 pm    Post subject: G Load testing |   |
				| I have seen a few photos on the group over the years with
a/c inverted and bags of sand, concrete, gold coins etc stacked
 evenly on the wings to simulate the G loading, question is how are
 people supporting the weight for this test through the fuselage itself
 obviously the top of the cockpit would be insufficient to take such a load
 of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on
 this
 my thoughts were it may be easier to keep the A/C upright and load the
 weight
 into the cockpit with the whole lot supported by cradle and a few extra
 supports under each wing
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Sat Jul 27, 2013 12:46 am    Post subject: G Load testing |   |
				| wrong thought Craig. It has to be done the standard way. Design load is 4.5 G (from dilute memory)
Don't try it without a qualified Inspector, easy to break something.
 Graham
 Sent: Saturday, 27 July 2013, 0:00
 Subject: Europa-List: G Load testing
 -->  Europa-List message posted by: "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)>
 this
 weight
 into the cockpit with the whole lot supported by cradle and-> http://forums.matronics.comhttp://www.======================
		| Back to top |  |
				|  Posted: Sat Jul 27, 2013 2:52 am    Post subject: G Load testing |   |
				| Yes but doesn’t there have to be a 50% safety margin on g load
After all you could pull nearly 6 g in a turn (80 degrees bank) taking
 Evasive action for example.
 But back to the original question how does one support the a/c adequately for the testing in the inverted
 position
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
 Sent: Saturday, July 27, 2013 6:44 PM
 Subject: Re: G Load testing
 Graham
 Subject: G Load testing
 this
 weight
 0123456789 	  | Quote: |  	  | http://www.matronics.com/Navigator?Europa-List |
 Checked by AVG - www.avg.com
 07/26/13
		| Back to top |  |
		| Gilles.Thesee(at)ac-greno Guest
				|  Posted: Sat Jul 27, 2013 4:06 am    Post subject: G Load testing |   |
				| craig a écrit :
  	  | Quote: |  	  | Yes but doesn’t there have to be a 50% safety margin on g load
 Graig and all,
 The 50 % margin is for calculation only, especially in a homebuilt.
 Contrary to popular belief, the 4.5 g load for instance, is a
 once-in-a-lifetime limit not to be inflicted on the airframe repeatedly.
 Safe load is considered to be approximately 80% of certified load.
  	  | Quote: |  	  | After all you could pull nearly 6 g in a turn (80 degrees bank) taking
 Any airplane can break in flight if mishandled.
 It would take a really ham fisted pilot to reach as high as 6g.
 Additionally in peacetime I would advise to only perform avoiding
 actions
 Best regards,
 Gilles
 http://contrails.free.fr
		| Back to top |  |
