norton(at)optonline.net Guest
Posted: Wed Mar 21, 2007 9:34 am Post subject: aluminum verses composite |
I am about to start the rudder for a scratch built 601XL (Corvair?).
However, yesterday I heard of a 3/4 completed Vision homebuilt that was
for sale. (The builder had died). This project is a composite plane
and total estimated time for a scratch build is 3000 hours. I have not
seen any estimates of how long a scratch build is for the 601. My
question is this? Has anyone worked on both metal and composite? What
are the advantages and disadvantages of each? I realize this is a
Zenith (metal built planes) site and that the people who are here have
decided that is the way to go. At 59, I suspect this will be the only
plane I'll have. I'm taking flying lessons now so I don't have a much
experience in that area either. I would assess my building skills as
well above average and have space and tools to build about anything. I
would just like to hear what others had considered when they chose their
project.
Posted: Wed Mar 21, 2007 10:04 am Post subject: aluminum verses composite |
Some of the down-sides to composite construction are the need for a
temperature-controlled space to build in where fumes won't bother someone
else. Also the skills take longer to acquire for a klutz like me. Composite
planes look prettier but a well designed and built metal plane can be just
as light.
One side point to think about. The FWF package for the XL and a Corvair is
well developed with the nose bowl and motor mount available. If you want to
use a Corvair in the Vision you will need to do a lot of the development
yourself (although I bet you could make William's nose bowl work on the
Vision). I don't know the Vision's numbers but the Corvair may also not be
suitable.
-- Craig
agustafson(at)chartermi.n Guest
Posted: Wed Mar 21, 2007 10:15 am Post subject: aluminum verses composite |
METAL
work on it anywhere (no stink)
few special tools
health hazards: metal cuts
fast planes or STOL
clean the shop by sweeping up the cutoffs and rivet mandrels
COMPOSITE
temperature criticle shop
more special tools
health hazards: epoxy sensitivity, fiberglass cuts and slivers
usually fast planes ie. long runways=hanger rent
clean the shop by grinding the drips off the floor
BTW: you are really looking at two very different planes. The XL is an LSA
while Vne on the Vision is 207 mph. The Vision is a new design with only a
few flying while there are hundreds of XLs flying. You should decide what
kind of builder and pilot you are and what "missions" you will be flying.
*Then* choose a plane.
-- Craig
zodierocket(at)hsfx.ca Guest
Posted: Wed Mar 21, 2007 11:02 am Post subject: aluminum verses composite |
Jim , there are many considerations for Aluminium over Composite. I'm
only going to touch on three, the listers may be able to provide the
several hundred or more other issues.
Composite requires humidity and temperature control to be exact during
the whole process; this can sometimes be a problematic situation.
In an accident situation I have seen where a composite ,which I thought
did not land particularly hard come apart totally and all shards of
glass became daggers into the occupants. This should have easily been a
walk away incident but ....well you get the picture, glass fibers in a
situation can be deadly.
My NUMBER 1 reason for not building a fiberglass plane is the itch
factor, every night you go to bed scratching, I have woken up several
mornings red and swollen from glass fibers, wife has also woken up in
similar shape and she wasn't in the workshop. Precautions can be made to
eliminate the issue, but in metal planes it is a non factor. The only
thing I brought to bed in my metal plane was a completed Rudder ! Wife
was not impressed ! You would think she would have expected the
Stabilizer ! Nope it was couch time once again !
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
jhstarn(at)verizon.net Guest
Posted: Wed Mar 21, 2007 12:19 pm Post subject: aluminum verses composite |
Subject: Fw: aluminum verses composite
Great post... (BUT I did add a few things)
KABONG Do Not Archive HRII N561FS & Corvette driver
Quote: |
FROM: Zenith-List message posted by: "Aaron Gustafson"
<agustafson(at)chartermi.net>
METAL
few special tools
health hazards: metal cuts & cleco cramps
fast planes or STOL
clean the shop by sweeping up the cutoffs and rivet mandrels (once a week
paint it any color
park it outside option
COMPOSITE
temperature critical shop
more special tools
health hazards: epoxy sensitivity, fiberglass cuts and slivers = ITCH
usually fast planes ie. long paved runways
vaccum up the "powder" daily (unless you like the Peanuts "Pig Pen" look
as you walk thru the shop)
paint choices..: White, off-white & egg shell
gotta have a hanger
AND the 3 S's....Sanding, sanding & SANDING
Original post:
project.
pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Wed Mar 21, 2007 12:28 pm Post subject: aluminum verses composite |
I would have to emphatically concur with Craig.
" You should decide what kind of builder and pilot you are and what
-- Craig"
Here is my discussion with Mark Townsend about the plane and pilot thing. I
hope he doesn't mind the posting of our private conversation, but I think it
highlights' the issues to settle before you choose metal or plastic.
Mark wrote...
Craig, I hope you don't find me prying, but once in awhile I get a feeling
that I need to talk to someone a little more about there decision. I am
getting this feeling right now. Please don't feel I'm prying or in any way
trying to influence your decisions. However, I wish to make you think and
consider your decision a little further.
Believe it or not I have less of a desire to sell you a plane then I do have
to ensure that you finish a plane and realize your dreams. This is by far
more important to me, I want to ensure that you know everything involved in
your decisions and that you have a clear picture of the adventure in front
of you.
Would you mind telling me a little more about yourself and the process that
you went through to arrive at your decision of the CH640.
Once again, if I am invading your privacy or prying too much then I will
hold all comments and questions and do what you ask for specifically.
Nevertheless, I would rather be a friend over a salesman and help in your
decision. It is just who I am, it takes a lot more of my time but on a whole
any customers who I have engaged in this type of conversation have been
grateful.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
My reply to Mark was.....
I have 400 hrs in high wing SELAs, Roughly half in 172, half in 182 turbo
G1000. Recently instrument rated, I'd like to be able to fly myself and my
wife with a real life load of baggage. Missions to include all weekend and
vacation travel, with possible business travel. Flight to Bahamas, Canada,
AK possible. Aircraft must be capable of operation in IMC. Long haul
comfort, and economical operation.
I have a serious desire to continue flying, but can't afford the costs of
new certified aircraft and their maintenance. I have a hangar at Livingston
county airport, many shop tool including a gas and mig welding, Smithy type
combination lathe/mill, drill press, air compressor, pneumatic tools,
conventional mechanics tools.
I'm a licensed electrician, I work in skilled trades at Ford/Wixom. I was a
radar/fire control technician in the NAVY, where I learned my trade, working
on radar systems/electromechanical drives and military computers. In high
school I took shop classes, and my father was a civil engineer who loved to
teach me concepts of physics and engineering.
I first was thinking of building a Sportsman 2+2, (high wing transition,
very similar to 182 in capability and performance. Recent events in auto
industry have limited future overtime income. More spare time-less income.
So Sportsman really is more expensive, and working with glass is totally
beyond my experience, and it looks like there are a lot of environmental
controls involved in the construction process that increase the cost/effort.
Next I found the 801 after some poking around, not as fast as the Sportsman
but it met my useful load requirements, which is my key parameter for
aircraft capability. After further surfing the zenith pages, I started
looking at he 640. At first I didn't consider a low-wing, but the increase
in cruise speed for a minimum of cost, and the fact that my wife didn't like
the idea of bush-type flying pushed the scale in favor of the 640.
In summary, I felt that the 640 best met my needs for useful load, and the
cost/value/skill/time envelope. Another factor was the ability to have an
aircraft with exactly what equipment/power plant I wanted, within the
airframe limitations of course.
Hope that sheds some light.
Craig Smith
Lastly, I chose metal construction because there are fewer environmental and
housekeeping issues associated with that construction, as well as IFR
lightning protection. The additional steps to introduce the conductive grid
into the airframe on a composite construction is complicated and would add
significantly to cost/time/expertise to complete.
Hope this is a frame work from which you can make your own decisions.
Craig Smith
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
John Bolding
Posted: Wed Mar 21, 2007 12:41 pm Post subject: aluminum verses composite |
First off , at 59 this will probably NOT be your last homebuilt, started my first one at 29 and now 61 and have several more planned when the 701 is finished.
Have built both alum and glass airplanes and everything that has been said so far is right on.
There is glass and there is glass, The Vision is moldless and will require a bunch, repeat BUNCH of finish work, depending on how perfect you want the airplane. This may or may not be something you like to do. Glass airplanes CAN be as light as alum but RARELY are as it requires prepreg, ovens,vacuum, carbon, MUCH engineering to get minimum layup schedules etc.
Having inspected dozens of projects that were "75-90% finished" I'd say to get someone that's completed a Vision, or at least to the point your potential project is, to comment on pictures you send him if time in construction means that much to you.
Inspecting someone's glass work is difficult at best, one of the early Glasairs came apart in flight when the leading edge of the wing opened up due to upper and lower panels being joined improperly, impossible to determine after the fact, but readily apparent when the pieces were exposed.
Having built both, plus rag and tube, I like aluminum.
LOW&SLOW John Bolding
[quote] I am about to start the rudder for a scratch built 601XL (Corvair?).
project.
raymondj(at)frontiernet.n Guest
Posted: Wed Mar 21, 2007 1:05 pm Post subject: aluminum verses composite |
Depending on the skill of the builder, it is very easy to add a significant
amount of weight to an airframe with improper lay-up. Unless you know how
much the airframe should weigh at a particular point in the building process
it is hard to detect.
Raymond Julian
Kettle River, MN.
