rlalonde
Posted: Tue Mar 20, 2007 3:10 pm Post subject: Making an LRI probe |
Hi
Any suggestions on how to make the probe? Drilling 5 7/8 (quite deep)into
the aluminum AND keeping it straight!!
Any suggestions??
Is this a job for a machine shop only?
Really anxious to try this thing out!!!!
Ron
Have Some Fun Out Of The Sun This March Break
http://local.live.com/?mkt=en-ca/?v &cid=A6D6BDB4586E357F!142
secatur
Posted: Tue Mar 20, 2007 3:27 pm Post subject: Re: Making an LRI probe |
Just wondering if it is possible to make the LRI probe out of Aluminiun Tubing ? (Like the Pitot tube only 2 tubes strapped together at proper distances etc.)
Anyone , any ideas ?
Steve
secatur
Posted: Tue Mar 20, 2007 4:05 pm Post subject: Re: Making an LRI probe |
Sorta like this ?
Description: |
Filesize: |
65.67 KB |
Viewed: |
460 Time(s) |
Posted: Tue Mar 20, 2007 4:26 pm Post subject: Making an LRI probe |
Hi Steve,
I suppose it would be possible to redesign the LRI probe, but I don't
know how you plan to make it work correctly. I looked at my probe
for a while and learned (I think) that the critical part of the probe
is the ridge formed by the leading corner of metal. It is this
structure that divides the airflow into two parts for sampling at the
two input holes.
The tube design would be OK for conducting the pressure to the gauge,
but you still need a way to get the differential pressure sample from
the airflow.
I don't think it is all that hard to drill the holes in the solid
aluminum as shown in the LRI drawing. I did it in an hour or two
with a drill press and hand held drill. I don't remember what kind
of drill bits I used, but it might have included some of those 6"
"Aircraft" drills.
Good luck,
Paul
XL fuselage
At 03:27 PM 3/20/2007, you wrote:
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
secatur
Posted: Tue Mar 20, 2007 5:00 pm Post subject: Re: Making an LRI probe |
Hi Paul,
I don't think it is all that hard to drill your design either, and if you are correct about the differential pressure bit, you are probably right about a lot of stuffing around to get something that works correctly.
However, I'm sure it can be made to work, and as I have an "Enigma" EFIS that has the LRI/AOA Gauge built in I'm gonna experiment a bit with it. ('Cos I'm like that! LOL!)
Cheers,
Steve
paulrod36(at)msn.com Guest
Posted: Wed Mar 21, 2007 2:39 pm Post subject: Making an LRI probe |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Re the "sorta like this", illustration, I also made a lot of aluminum shavings, trying to properly drill the *&^%$ probe. I think, though, that the magic comes from the differential pressure generated by the square nose of the probe, with the inlets on upper and lower sides of the corner of the block of aluminum. I put mine on the shelf for a while, but I plan to make a probe equivalent to my longest drill's flutes, and then mount it with tubes held rigidly. May not work, but worth a try.
Paul Rodriguez
601XL/Corvair
taffy0687(at)yahoo.com Guest
Posted: Wed Mar 21, 2007 3:24 pm Post subject: Making an LRI probe |
I am going to drill mine from each end, than weld one end closed. A
Fritz
paulrod36(at)msn.com wrote:
[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Re the "sorta like this", illustration, I also made a lot of aluminum shavings, trying to properly drill the *&^%$ probe. I think, though, that the magic comes from the differential pressure generated by the square nose of the probe, with the inlets on upper and lower sides of the corner of the block of aluminum. I put mine on the shelf for a while, but I plan to make a probe equivalent to my longest drill's flutes, and then mount it with tubes held rigidly. May not work, but worth a try.
Paul Rodriguez
601XL/Corvair
rjscep(at)yahoo.com Guest
Posted: Wed Mar 21, 2007 8:50 pm Post subject: Making an LRI probe |
Quote: | Greetings. I drilled a solid piece of aluminum like
the drawing said, however I did find that the 1/8
hole drilled out for the 3/16 hole was in the wrong
place. The dim. says drill it a half inch from the
bottom and it doesn't come out in the right place,
so I made it 3/4 of an inch from the bottom. I used
a #60 drill bit for a starter and drilled it
straight first and then changed the angle to get my
45 degree hole. I also got brass fittings, they are
a better fit on the bar. As far as making the face
on the guage is concerned, I hand painted the
markings red, yellow and green. I used ordinary
hobby paints and I masked out the positions with
contact paper, using an exacto knife I peeled away >
each part of the paper and painted that area,
Quote: | letting it dry and then proceeded with the other
places. If yoiu used the markings on the original
plate it helps a lot to draw out the areas to be
painted and a French curve to get the proper arc too
--- paulrod36(at)msn.com wrote:
[quote] Re the "sorta like this", illustration, I also made
Paul Rodriguez
601XL/Corvair
cgbrt(at)mondenet.com Guest
Posted: Fri Mar 23, 2007 8:27 pm Post subject: Making an LRI probe |
Yes, Bend the lower one 30 degrees down; top as normal pitot.
Carl
701
