		n8vim(at)arrl.net Guest
				 Posted: Sat Mar 24, 2007 10:23 am    Post subject: Wing Root Connectors |
				Anyone using any wing root connectors (between inboard section of the
 wing and the fuselage) for the wiring?
 If you are, or have thought about using them, which ones are you using?
 I have already decided to have connectors there, so that decision is
 made already. I am just at a loss for what is "standard" for connectors
 there.
 -Jim 40384 (60 Degrees F today, expecting 4" snow tonight... Isn't New
 England wonderful?)
		Tim Olson
				 Posted: Sat Mar 24, 2007 10:43 am    Post subject: Wing Root Connectors |
				I don't know if there is a standard, but I know Randy used the big
 black round CPC connectors.
 Example: http://www.abletronics.com/ampconnectors/cpcseries1.html
 I bought a bunch of various CPC connectors that I had planned to use
 but they're all still sitting in their packages.  I ended up
 in favor of continuous strands.  Some day I'll dig them out and
 itemize them and offer them up for sale.  Mouser.com is a great place
 to buy them.  They aren't really that cheap when you start to add in
 the costs of pins, crimpers, and all the other stuff.  They are
 nice connectors though, if you are going to use them.
 James Hein wrote:
  there.
  England wonderful?)
		LarryRosen
				 Posted: Sat Mar 24, 2007 2:04 pm    Post subject: Wing Root Connectors |
				CPC connectors from mouser.com are great.  I use series 1  free-hanging connectors for all wiring and just normal BNC's for coax.  For the strobes I use 4 pins with the 4th being for the un-insulated wire.  This allows you to wire the whole plane before installing the wings.  I also use these in the
 Wingtips and anywhere else that I want to be able to disconnect in the future to work on stuff.
 Call me if you have more questons about this.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 352-427-0285
		wcurtis(at)nerv10.com Guest
				 Posted: Sat Mar 24, 2007 4:24 pm    Post subject: Wing Root Connectors |
				I know of no standard.  I find Molex connectors to be the easiest to use
 and most of them are keyed so they only plug in one way.  In the wing
 root and tips where they have the possibility of getting wet, I spray
 them liberally with Boshield.
 Linn
 James Hein wrote:
  connectors there.
  England wonderful?)
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Sat Mar 24, 2007 4:32 pm    Post subject: Re: Wing Root Connectors |
				 	  | pitts_pilot(at)bellsouth. wrote: | 	 		    In the wing
 Linn |
 OK I'll bite.  What is Boshield?
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
				 Posted: Sat Mar 24, 2007 4:57 pm    Post subject: Wing Root Connectors |
				orchidman wrote:
   	  | Quote: | 	 		      	  | Quote: | 	 		  --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com> (gary(at)wingscc.com)
         	  | Quote: | 	 		    In the wing
 Linn
 OK I'll bite.  What is Boshield? | 	    | 	   Sorry, non-edible.
  Boshield can be found at any good boat store.  Excellent for use as a moisture shield.  I believe it was developed by Boeing (the 'bo' part but that may be urban legend too) for corrosion/moisture protection.  You can buy it  in spray can or gallon can, and when diluted it makes a great corrosion proofer ala ACF-50 and the like.  Doesn't seem to attract dust/dirt like the CRC line.
  Linn
  [quote]    [b]
		jwt(at)roadmapscoaching.c Guest
				 Posted: Sat Mar 24, 2007 5:19 pm    Post subject: Wing Root Connectors |
				I used the CPC connectors and really like them. Got them from Mouser. Here
 are the art numbers"
 571-2060364                4.260
          AMP Series 1 Two Pie
          RECEPTACLE 16 PIN
 571-2060371              2.820
          AMP Series 1 CPC Cir
          PLUG 16 POSITION
 571-661033                  0.360
          PIN  24-20
 They also have larger AWG pins
 571-661053              0.430
          SOCKET TERM 24-20
 571-2060701                  3.20
          AMP CPC Accessories
          STD CABLE CLAMP 17
 I ended up using 2 connectors on one wing after adding 2 outside air probes
 and 2 magnatometers
 John Testement
 jwt(at)roadmapscoaching.com
 40321
 Richmond, VA
 Paint prep and LOTS of misc stuff
				 Posted: Sat Mar 24, 2007 7:26 pm    Post subject: Wing Root Connectors |
				Boeshield is good but I use the more readily available OX-100 Oxyguard anti oxidant paste available at Loews/HD (aviation) electrical department.http://wcurtis.nerv10.com/08fuselage/images/fuselage35j.jpgWilliamhttp://wcurtis.nerv10.com/  --> RV10-List message posted by: "orchidman" pitts_pilot(at)bellsouth. wrote:> In the wing > root and tips where they have the possibility of getting wet, I spray > them liberally with Boshield.> LinnOK I'll bite. What is Boshield?--------Gary BlankenbillerRV10 - # 40674(N410GB reserved)do not archiveRead this topic online here:http://forums.matronics.com/viewtopic.php?p=102693#1026=====================    [quote][b]
		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Sat Mar 24, 2007 8:07 pm    Post subject: Wing Root Connectors |
				Yes designed by Boeing.  I will be using this  product on interior surfaces instead of primer, after final exterior  finishing.  (Shhhhhhhhh.)
  http://boeshield.com/index.htm
  Dave Leikam
  40496
  [quote]   ---
				 Posted: Sat Mar 24, 2007 8:16 pm    Post subject: Wing Root Connectors |
				I plan on using something that no one else has mentioned.  Where there is a
 simple positive/ negative connection, I plan on using something that is used
 extensively in radio controlled vehicle electrical systems, They are called
 Deen's connectors.
 Link:
 http://www.heli-world.com/detail.aspx?ID=418
 I've used them in my sailplane
 JOhn G. 409
  	  | Quote: | 	 		  From: James Hein <n8vim(at)arrl.net>
 Subject: Wing Root Connectors
 Date: Sat, 24 Mar 2007 14:20:56 -0400
 Anyone using any wing root connectors (between inboard section of the wing
 I have already decided to have connectors there, so that decision is made
 already. I am just at a loss for what is "standard" for connectors there.
 England wonderful?)
		owl40188(at)yahoo.com Guest
				 Posted: Tue Mar 27, 2007 7:57 am    Post subject: Wing Root Connectors |
  Which crimping tool did you use?
  Niko
  40188
				 Posted: Tue Mar 27, 2007 11:57 am    Post subject: Wing Root Connectors |
				The one that Stein sells for $31 or so.  It seems to work great with the open pins, which Series 1 CPC’s are.  If you are going to have all small wires, then going with Series 2 is “better” because they have barrel pins, but then you have to do something else with your strobes, landing lights, pitot heat, etc, so you are really stuck with the Series 1 for the wing root.  Stein sells it as a crimper for Molex type pins, which the CPC’s look like, but are better.  Also, there are 3-4 different qualify of CPC pins and I get the best or second best of two sizes, 18-16 and 24-20.  The pins are the most expensive part of the system (and arguably by far the most important).
 Jesse Saint
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Niko
  Sent: Tuesday, March 27, 2007 11:56 AM
  Subject: Re: Wing Root Connectors
 Niko
 40188
				 Posted: Tue Mar 27, 2007 3:55 pm    Post subject: Wing Root Connectors |
				I don't know the model  but bought the crimp tool for various sizes of molex pins from Stein. I would  call SteinAir.com for the crimpers,
   John Testement
 jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
 40321
  Richmond, VA
  Niko
  40188
  -----  Original Message ----
 From: John Testement  <jwt(at)roadmapscoaching.com>
 Sent:  Saturday, March 24, 2007 9:16:11 PM
 Subject: RE: Wing Root  Connectors
  --> RV10-List message posted by: "John Testement"  <jwt(at)roadmapscoaching.com>
 571-2060364                4.260
          RECEPTACLE 16  PIN
 571-2060371              2.820
          PLUG 16  POSITION
 571-661033                  0.360
           PIN  24-20
 571-661053              0.430
          SOCKET TERM  24-20
 571-2060701                  3.20
           AMP CPC Accessories
          STD  CABLE CLAMP 17
 and 2 magnatometers
 John  Testement
 40321
 Richmond, VA
 -----Original  Message-----
 [mailto:owner-rv10-list-server(at)matronics.com]  On Behalf Of James Hein
 Sent: Saturday, March 24, 2007 2:21 PM
 --> RV10-List message posted by: James Hein  <n8vim(at)arrl.net>
 England  wonderful?)
 4:36 PM
 4:36
 Checked by AVG  Release  Date: 3/26/2007 2:31 PM
  3/26/2007 2:31 PM
				 Posted: Wed Mar 28, 2007 5:22 am    Post subject: Wing Root Connectors |
				I am going to use the Series 2 for the autopilot servo and Series 1 for the Lights etc as you mention.  Thanks for the info.
  Niko
  40188
				 Posted: Wed Mar 28, 2007 3:19 pm    Post subject: Wing Root Connectors |
				Niko,
  Just in case you didn't  realize it you can use the series 1 for multiple size pins. I used one connector  for lights, pitot and servos and a 4 pin Molex for the strobe (ran the wiring  separated from the rest).
   John Testement
 40321
  Richmond, VA
  Niko
  40188
  do not  archive
 From: Jesse Saint jesse(at)saintaviation.com (jesse(at)saintaviation.com)
  UNKNOWN { 	FONT-FAMILY: Tahoma; panose-1: 2 11 6 4 3 5 4 4 2 4 } P.MsoNormal { 	FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { 	FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { 	FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { 	COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { 	COLOR: blue; TEXT-DECORATION: underline } A:visited { 	COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { 	COLOR: blue; TEXT-DECORATION: underline } PRE { 	FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New" } SPAN.EmailStyle18 { 	COLOR: navy; FONT-FAMILY: Arial } UNKNOWN { 	MARGIN: 1in 1.25in } DIV.Section1 { 	 }
 Jesse  Saint
  3/27/2007 4:38 PM
