tenorio41(at)comcast.net Guest
Posted: Fri Feb 10, 2006 3:27 pm Post subject: Hinge Pin Staking |
What the best method for staking the pins in my elevator trim hinges?
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Fri Feb 10, 2006 4:02 pm Post subject: Re: Hinge Pin Staking |
Just don't do what my neighbor advised me to do and try to stake them with a punch. I made a mess of mine. Ed Downs of Skystar advised just making a 90 degree bend at each hinge pin end. Maybe John McBean will give us an input here.
_________________ Vic Baker
Series 7
Carson City, Nevada |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 10, 2006 5:39 pm Post subject: Hinge Pin Staking |
Assuming you are not going to remove the pins for inspections etc. A
recommended method at Lancair is to cut the pin a little short. Insert it
so it is short on both ends in the hinge and then just tap the end a bit
with a hammer to creat a crimp.
Lowell
frank.phyllis(at)mindspri Guest
Posted: Sat Feb 11, 2006 8:16 am Post subject: Hinge Pin Staking |
I drilled holes in the hinge, cut the pens short, and safety wired them
for ease of removal.
Frank
Series 7
Posted: Sat Feb 11, 2006 11:51 am Post subject: Hinge Pin Staking |
Frank,
I like this idea. Thanks.
Lowell
jdmcbean(at)cableone.net Guest
Posted: Mon Feb 13, 2006 9:39 am Post subject: Hinge Pin Staking |
Sorry for the delay guys.. Been out for a few days...
I have done this a couple of ways: Shorter pin and crimped the hinge end ,
Shorter pin and drilled the hinge to be safetied, Longer pin with a bend...
They all worked but I liked the drilled hinge the best so far.... Tried the
same on the door hinge and installed a stainless wire with 2 bent 90's to
keep in place.
Fly Safe !!
John McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
aldaniels(at)fmtc.com Guest
Posted: Mon Feb 13, 2006 2:14 pm Post subject: Hinge Pin Staking |
I use hitch pins in the hinges on the doors. That way I can remove them
in a minute or so.
jdmcbean wrote:
| Quote: | I have done this a couple of ways: Shorter pin and crimped the hinge end ,
keep in place.
