		tenorio41(at)comcast.net Guest
				 Posted: Fri Feb 10, 2006 3:27 pm    Post subject: Hinge Pin Staking |
				What the best method for staking the pins in my elevator trim hinges?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Vic Baker
  Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
				 Posted: Fri Feb 10, 2006 4:02 pm    Post subject: Re: Hinge Pin Staking |
				Just don't do what my neighbor advised me to do and try to stake them with a punch.  I made a mess of mine.  Ed Downs of Skystar advised just making a 90 degree bend at each hinge pin end.  Maybe John McBean will give us an input here.
  _________________ Vic Baker
Series 7
Carson City, Nevada |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Fri Feb 10, 2006 5:39 pm    Post subject: Hinge Pin Staking |
				Assuming you are not going to remove the pins for inspections etc.  A
 recommended method at Lancair is to cut the pin a little short.  Insert it
 so it is short on both ends in the hinge and then just tap the end a bit
 with a hammer to creat a crimp.
 Lowell
		frank.phyllis(at)mindspri Guest
				 Posted: Sat Feb 11, 2006 8:16 am    Post subject: Hinge Pin Staking |
				I drilled holes in the hinge, cut the pens short, and safety wired them
 for ease of removal.
 Frank
 Series 7
				 Posted: Sat Feb 11, 2006 11:51 am    Post subject: Hinge Pin Staking |
				Frank,
 I like this idea.  Thanks.
 Lowell
		jdmcbean(at)cableone.net Guest
				 Posted: Mon Feb 13, 2006 9:39 am    Post subject: Hinge Pin Staking |
				Sorry for the delay guys.. Been out for a few days...
 I have done this a couple of ways:  Shorter pin and crimped the hinge end ,
 Shorter pin and drilled the hinge to be safetied,  Longer pin with a bend...
 They all worked but I liked the drilled hinge the best so far....  Tried the
 same on the door hinge and installed a stainless wire with 2 bent 90's to
 keep in place.
 Fly Safe !!
 John McBean
 www.sportplanellc.com
 "The Sky is not the Limit...  It's a Playground"
		aldaniels(at)fmtc.com Guest
				 Posted: Mon Feb 13, 2006 2:14 pm    Post subject: Hinge Pin Staking |
				I use hitch pins in the hinges on the doors. That way I can remove them
 in a minute or so.
 jdmcbean wrote:
  	  | Quote: | 	 		  I have done this a couple of ways:  Shorter pin and crimped the hinge end ,
 keep in place.
