rsteele(at)rjsit.com Guest
Posted: Mon May 28, 2007 7:41 am Post subject: Noob errors on rudder kit - need help |
I'm working on the rudder kit and have a couple of mistakes that I've
no idea how to fix.
While installing the nose skin, I drilled a hole in the wrong place
while trying to attach the skin to the nose rib. So I have a big
ugly rivet hole just above where the proper rivet line falls.
I also have 2 or 3 holes that don't line up properly with the tail
skin/main rudder spar. (I think the number if suggested clecos to
order with the tail kit is a bit low, BTW. I ordered extras and
still feel I don't have enough). I'm guessing that if I re-drill
these I'll get oversize, oval, holes in the tail skin.
Ron
challgren(at)mac.com Guest
Posted: Mon May 28, 2007 8:17 am Post subject: Noob errors on rudder kit - need help |
On May 28, 2007, at 9:39 AM, Ronald Steele wrote:
. (I think the number of suggested clecos to order with the tail
kit is a bit low, BTW. I ordered extras and still feel I don't
have enough).
Ronald:
I have 450 clecos at present and still run short on my 701 project as
rudder, horizontal stabilizer, wings require clecos even as the rear
fuselage takes a huge number until riveting can begin.
Stan
N701VG
Gig Giacona
Posted: Mon May 28, 2007 8:22 am Post subject: Re: Noob errors on rudder kit - need help |
When you are not actually working on a particular are (and even sometimes when you are) you don't need to keep a cleco in every hole.
| challgren(at)mac.com wrote: | On May 28, 2007, at 9:39 AM, Ronald Steele wrote:
have enough).
Ronald:
Stan
N701VG |
601XL Under Construction
naumuk(at)alltel.net Guest
Posted: Mon May 28, 2007 9:37 am Post subject: Noob errors on rudder kit - need help |
Ron-
Luckily, that's an easy part to fabricate yourself. You'll never be able
to live with the extra hole, because the rudder's the first thing anyone in
the know looks at. Flame on, but it's the truth! (Next is the fiberglass
tips, then the overall rivet lines).
Prepare yourself now. Order an extra full sheet of .016, .025 and 2'x4'
(At least 2'x2') sheets of .032 and .040 from ACS or Wick's. Do it in one
shot now, because it'll save you shipping and you WILL NEED TO FABRICATE
"OOPS" PARTS!! Fact of life.
As far as tools are concerned, there's someone on the list with the
motto "He who dies with the most tools wins". He's right.
Good building!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
planecrazydld(at)yahoo.co Guest
Posted: Mon May 28, 2007 10:44 am Post subject: Noob errors on rudder kit - need help |
while absolutely true, anyone who has spent their life building sheet metal aircraft will tell you the only cleco that does no good is the one in the hole you are working at that exact time. You absolutely cannot have too many clecos - and they never depreciate - they always are sell able.
Gig Giacona <wr.giacona(at)suddenlink.net> wrote:[quote] --> Zenith-List message posted by: "Gig Giacona"
> kit is a bit low, BTW. I ordered Ready for the edge of your seat? [url=http://us.rd.yahoo.com/evt=48220/*http://tv.yahoo.com/]Check out tonight's top picks[/url] on Yahoo! TV. [quote][b]
JERICKSON03E(at)aol.com Guest
Posted: Mon May 28, 2007 12:53 pm Post subject: Noob errors on rudder kit - need help |
In a message dated 5/28/2007 10:42:10 AM Central Daylight Time, rsteele(at)rjsit.com writes:
no idea how to fix.
skin/main rudder spar. |
If it comes to needing to replace skins/spars and so on,, remember that there are a LOT of rudders out there, thanks to the rudder workshops. Someone might be willing to part with a lonesome rudder for a good cause. Never hurts to ask.
Happy Building
See what's free at AOL.com.
lwinger
Posted: Mon May 28, 2007 2:38 pm Post subject: Re: Noob errors on rudder kit - need help |
Ron,
Welcome to the fun of building your own airplane. You've picked a great company (Zenith) with one of the best lists around to support you.
Option 1: The idea of buying someone else's rudder, while not a bad one considering how many are just collecting dust, doesn't do much for your education. If you don't work through these issues on your rudder, you will likely find yourself repeating the same kind of mistakes on your horizontal stabilizer. Use this as a great learning opportunity and invest some time (and money) into your education as a craftsman.
Option 2: If there is any way you can attend a Rudder Workshop, I would advise it. You're going to spend a fair amount of money just replacing parts, so why not start from scratch under the watchful eye of the good folks at Zenith. I'm sure you would see your confidence soar.
Option 3: If that doesn't work for you, I would encourage you to watch "Metal Working 101 with Rudder Workshop" from www.homebuilthelp.com. It's a lot cheaper than traveling to Mexico, MO or Cloverdale, CA and you can benefit from some excellent instruction in the privacy of your home. Then when the replacement parts arrrive, you'll feel better prepared to tackle the job.
Option 4: Build your rudder (or at least the replacement parts) from scratch. You have everything you need on the plans you received, and for a very few dollars you can buy the sheet aluminum and make your own parts. If you decide to go this route (which I have), I would suggest that you watch and re-watch "Scratch Building Basics for Metal Aircraft," also from www.homebuilthelp.com. You might be amazed how easy it is, once the guys from Can-Zac have taken all the mystery out of scratch-building.
Whatever your choice, know that you will never regret the time you spend educating yourself and remaking each part until you can be absolutely convinced of its airworthiness. That is time well spent.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Posted: Mon May 28, 2007 2:55 pm Post subject: Noob errors on rudder kit - need help |
Ron-
I second the HH recommendation.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Mon May 28, 2007 3:42 pm Post subject: Noob errors on rudder kit - need help |
Thanks to all who responded. What a great group.
Sigh, sounds like my best bet is to just start over. The DVDs sound
like a good idea too. While I'm quite comfortable with the
engineering issues, this is the first time I've ever worked with
sheet metal or used a cleco. I have to admit I'm not all that
comfortable with the build quality of the rest of rudder either so a
new kit is probably in order. I definitely want to have confidence
in what I'm building!
As far as fabricating parts, I feel like it would just take to
long. While I do enjoy this sort of work, and I find the process
fascinating, the point is to have a plane to fly. I'm in my 50's
and a student pilot - and I absolutely love flying. Another couple
of years of build time for fabrication sounds like forever right
now. I may invest in some aluminum stock anyway just to see how it
goes.
So, anybody have a rudder kit laying around they would like to
offload ?
Ron
On May 28, 2007, at 6:38 PM, lwinger wrote:
Ron,
you.
confidence soar.
the job.
building.
Larry Winger
Tustin, CA
601XL #6493 from scratch
Control surfaces and wing spars complete
http://forums.matronics.com/viewtopic.php?p=115255#115255
Posted: Mon May 28, 2007 5:31 pm Post subject: Noob errors on rudder kit - need help |
Ron-
Invest in the DVDs and the materials to make a new one. It will work out
to about the same cost as a new rudder kit and take just a hair longer.
Fact of life- you're going to have to make some components on your own
sooner or later. Might as well get the confidence and satisfaction of doing
it from scratch early on. My best advice is to remove your clocks and ignore
your checkbook register.
By the way- I'm building from a kit, in my 50's, and hope to finish my
project while I can still pass a medical. Of course, Sport Pilot is plan B.
As far as a plane to fly, rent.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon May 28, 2007 6:54 pm Post subject: Re: Noob errors on rudder kit - need help |
It would be useful to see a pix of your errors. If you have a hole in the wrong place you can often just fill it with a rivet. If your holes do not match up quite perfectly drill them out with a #20 drill bit and install an A5 rivet.
Accept the fact that you are going to make mistakes and that in most cases they can be repaired in a very satisfactory manner. If your goal is to make a "perfect" plane you can give it up right now. Feel free to contact me off list if you have other questions.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
