klr12(at)psu.edu Guest
Posted: Sat Jun 16, 2007 7:37 pm Post subject: Stainless Steel Rivets |
Guys, Just started pulling some rivets this weekend. Everything is going smoothly but I did run into one little snag. The plans call for a Stainless A5 rivet in a few places. I be darned, I looked everywhere but cannot come up with a part number or proper designation for this SS rivet. Can anybody tell me what to order? &nb! sp; Thanks, &nb! sp; Kevin Rupert &nb! sp; 601/Corvair [quote][b]
TxDave
Posted: Sat Jun 16, 2007 10:21 pm Post subject: Re: Stainless Steel Rivets |
Hey Kevin,
I called Zenith with this question last year and they sent me a handful of the correct SS rivets for a couple of bucks including shipping.
Dave Clay
Posted: Sat Jun 16, 2007 10:59 pm Post subject: Stainless Steel Rivets |
Where do the SS rivets go? What plan pages?
-- Craig
dredmoody(at)cox.net Guest
Posted: Sun Jun 17, 2007 2:30 am Post subject: Stainless Steel Rivets |
I don't have the plan page numbers handy but they are used in the elevator horn assembly an dagain to attach the brake pedals to the rudder pedals.
Dred
crvsecretary
Joined: 18 Mar 2007 Posts: 38 Location: Naugatuck, CT
Posted: Sun Jun 17, 2007 4:35 am Post subject: Stainless Steel Rivets |
Hello Listers:
I have plans dated 06/03 for the 601XL and on page 6-T-3 I don't see any reference to SS rivets.
Is this a recent change?
Should I be drilling out rivets rivets this weekend? (OK, next weekend - it's Fathers Day today.....)
Thanks everyone !
Tracy Smith
Naugatuck, CT
601xl N458XL (reserved)
In a message dated 6/17/2007 6:32:04 AM Eastern Daylight Time, dredmoody(at)cox.net writes:
[quote] I don't have the plan page numbers handy but they are used in the elevator horn assembly an dagain to attach the brake pedals to the rudder pedals.
Dred
_________________ Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings |
601zv(at)ritternet.com Guest
Posted: Sun Jun 17, 2007 5:31 am Post subject: Stainless Steel Rivets |
DITTO for my plans dated 04/06/04. 6-T-3 dated 06/03 indicates A-5's for horn attachments, and the Tail Kit Parts List shows only A4's and A5's included. The Controls Kit however included 20 AS5 rivets designated for Rudder Pedals, but with the plans calling for 14 AS5 for the SS Piano Hinge attachments, I have 6 still left.
Robin in AR
N601ZV reserved
lwinger
Posted: Sun Jun 17, 2007 6:58 am Post subject: Re: Stainless Steel Rivets |
For those who don't have the latest revisions, here is a portion of page 6T3 (revision 03/06) showing the bent strip and how you are to install it.
Description: |
 Download |
Filename: |
SS rivets.pdf |
Filesize: |
109.45 KB |
Downloaded: |
454 Time(s) |
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Jeyoung65(at)aol.com Guest
Posted: Sun Jun 17, 2007 7:28 am Post subject: Stainless Steel Rivets |
I have drawing 6-T-3 dated 08-04 and find no ss rivets. Also do NOT have 6-T-3-8. I do have a 6-T-3-6 which is "Elevator Horn Doubler" which use A-5 rivets. Have seen in the past where drawing was changed for the 601-XL but not the 601-HD and the drawing number was not changed. ( NOT GOOD DRAFTING RULES). Jerry-GA
See what's free at AOL.com.
Posted: Sun Jun 17, 2007 7:49 am Post subject: Stainless Steel Rivets |
Hi Ed,
I like your theory about loose rivets, but I have conflicting
information. Alas, it is my memory involved in this question so you
would be foolish to depend on it.
I remember talking to someone at Zenith (Nick?) about the bent strip
on the elevator. He said the strip was added to comply with the LSA
consensus standard and was not really needed. The impression I got
was it had just been added to the design. So, the idea that
observation of long installed strips led to the AS5 rivets is not
consistent with my memory of this discussion. The only alternative I
can come up with is that the small attach area and calculated load
placed on the rivets leads to more strength requirement than the
aluminum A5 rivets can handle.
Best regards,
Paul
XL fuselage
At 07:40 AM 6/17/2007, you wrote:
Quote: | On my 601XL plans dated 08/2005 I noted the following:
First, on 6T3 the AS5 stainless steel rivets are called for to rivet
the bent strip at the aft of the elevator (6T3- to the upper and
lower elevator horns (6T3-4 and -5)
Second, on 6B9 the AS5 rivets are called for to rivet the toe brake
pedal hinge (6B9-2) to the toe brake pedal to the rudder pedals (6B9-1 and -3)
I'm guessing that somewhere along the line they found loose or lost
rivets in those applications. My advice (which is far from
autoritative) is to dril out and replace those rivets since they
remain fairly accessible. A second option would be to monitor them
closely at preflight walk-around.
Happy Fathers' Day
Dred
Posted: Sun Jun 17, 2007 8:02 am Post subject: Stainless Steel Rivets |
Sounds plausible.
Ed
heatonhe36(at)msn.com Guest
Posted: Sun Jun 17, 2007 8:05 am Post subject: Stainless Steel Rivets |
Thanks Larry.
I've been wondering how the strip was attached since I saw the rev in the
drawing updates. For those who haven't seen the rev, look at ....
http://www.zenithair.com/zodiac/xl/data/xl-update-3rd-ed-1st-rev-4-05.pdf
Herb
Colorado
601XL/plans 80% done
Subaru EA81 Turbo
Posted: Sun Jun 17, 2007 8:47 am Post subject: Stainless Steel Rivets |
My 6-T-3 sheet of 06/03 shows only the 6T3-6 ELEVATOR HORN DOUBLER riveted with 7 regular A5's - no AS5 rivets and no 6T-8. I've been planning to get an updated set of plans anyway, and have now moved that to the top of my To-Do list.
zodierocket(at)hsfx.ca Guest
Posted: Sun Jun 17, 2007 9:09 am Post subject: Stainless Steel Rivets |
The LSA standard is the reason for the update, due to it's use in the
flight training category. Other then that the elevator has remained the
same for the last 20 years. IF you don't count the trim tab. Install the
new strip or not, your choice. However, I didn't remove my elevator to
install it and my plane is the Can-Zac demonstrator.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
Posted: Sun Jun 17, 2007 9:38 am Post subject: Stainless Steel Rivets |
Thanks! Looks like an easy add-on.
Do not archive.
Posted: Sun Jun 17, 2007 10:32 am Post subject: Stainless Steel Rivets |
Quote: | Quote: | But Guys,
The original question still begs an answer. What are these Rivets? Are they a
Cherry N, CherryMax, Cherry Q, Avdel Avtex? What? Anybody know?
Kevin R.
601XL/ Corvair |
| [quote][b]
Posted: Sun Jun 17, 2007 11:27 am Post subject: Stainless Steel Rivets |
Best bet is to call the factory and buy them there.
Dred
