		barry(at)pgtc.com Guest
				 Posted: Fri Jul 06, 2007 9:23 am    Post subject: Throttle cables |
				Trouble with my Model IV Kitfox with the  912S.  I need to replace the throttle cables.  Has anyone had  experience with replacing the cables without having to replace the whole  mechanism?  Let me know.
  Barry West
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Jul 10, 2007 4:44 am    Post subject: Throttle cables |
				A repeat request.  I have a model IV with the  912 S engine and the throttle without the vernier. Both cables and their  housings come out of the back of the throttle cartridge.  I don't see  anyway to open the back of the cartridge up to replace the cables.  I  wonder if it would be possible to pull the cables through the cartridge with the  throttle rod if the cables were loose from the carburetors.  In order to  check this out I would have to cut the cables because the ends are all spread  out and will not come through the housings.  Then they would no longer be  useable and I would have to buy a whole new cartridge which I would rather not  do.
  Would someone please let me know if the cables will  come out with the throttle rod.  You can email me direct at barry(at)pgtc.com (barry(at)pgtc.com) if you want.
  Barry West
		kitfoxmike
				 Posted: Tue Jul 10, 2007 4:51 am    Post subject: Re: Throttle cables |
				Best thing to do is call John and get a new cable assy.  works great.
		lcfitt(at)sbcglobal.net Guest
				 Posted: Tue Jul 10, 2007 6:17 am    Post subject: Throttle cables |
				Barry,
 I didn't respond earlier because I didn't understand the question.  The
 Model IV throttle assembly has a ridgid rod (wire) from the vernier throttle
 to the center arm on a wide bell crank weldment with arms on each end that
 pass through the firewall to each of the carbs.  From what you describe, the
 throttle has been changed to the version I understand is now used in the
 later model Kitfoxes.  In my mind, this design change was made to eliminate
 some of the welding needed at the factory to simplify kit production.  I
 can't imagine that it was done to simplify or improve throttle performance.
 That said, I suspect that if the throttle you have with a splitter is
 similar to the choke linkage, you would need a total replacement.  Although
 the choke splitter will come apart for repairs, it sounds like yours will
 not.
 Lowell Fitt
 Cameron Park, CA
 Model IV-1200 R-912 UL Warp
 1998 870 hrs.
				 Posted: Tue Jul 10, 2007 9:18 am    Post subject: Throttle cables |
				Lowell, sorry I didn't make it clear at first.  It is easy to replace the
 cable in the choke system and it should be in the throttle.  I disconnected
 the throttle cables this morning and pulled the control rod back out of the
 cartridge as far as I could without removing the little clamps from the
 cables and I believe the rod will come all the way out if I cut the cables.
 But I would like to know for sure before I cut them.  I don't like the cable
 they used, it just does not stay together well and much better cable is
 available.
 Yes, the old way was better.
 Barry
		Giovanni Day
				 Posted: Tue Jul 10, 2007 10:00 am    Post subject: Re: Throttle cables |
				Barry,
 I have a spare old vernier setup including that parts that go on the frame I am willing to sell if you need them.
  _________________ _______________________________________
Giovanni Day
Model 4 speedster 912 |
