barry(at)pgtc.com Guest
Posted: Fri Jul 06, 2007 9:23 am Post subject: Throttle cables |
Trouble with my Model IV Kitfox with the 912S. I need to replace the throttle cables. Has anyone had experience with replacing the cables without having to replace the whole mechanism? Let me know.
Barry West
Posted: Tue Jul 10, 2007 4:44 am Post subject: Throttle cables |
A repeat request. I have a model IV with the 912 S engine and the throttle without the vernier. Both cables and their housings come out of the back of the throttle cartridge. I don't see anyway to open the back of the cartridge up to replace the cables. I wonder if it would be possible to pull the cables through the cartridge with the throttle rod if the cables were loose from the carburetors. In order to check this out I would have to cut the cables because the ends are all spread out and will not come through the housings. Then they would no longer be useable and I would have to buy a whole new cartridge which I would rather not do.
Would someone please let me know if the cables will come out with the throttle rod. You can email me direct at barry(at)pgtc.com (barry(at)pgtc.com) if you want.
Barry West
kitfoxmike
Posted: Tue Jul 10, 2007 4:51 am Post subject: Re: Throttle cables |
Best thing to do is call John and get a new cable assy. works great.
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jul 10, 2007 6:17 am Post subject: Throttle cables |
Barry,
I didn't respond earlier because I didn't understand the question. The
Model IV throttle assembly has a ridgid rod (wire) from the vernier throttle
to the center arm on a wide bell crank weldment with arms on each end that
pass through the firewall to each of the carbs. From what you describe, the
throttle has been changed to the version I understand is now used in the
later model Kitfoxes. In my mind, this design change was made to eliminate
some of the welding needed at the factory to simplify kit production. I
can't imagine that it was done to simplify or improve throttle performance.
That said, I suspect that if the throttle you have with a splitter is
similar to the choke linkage, you would need a total replacement. Although
the choke splitter will come apart for repairs, it sounds like yours will
not.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 870 hrs.
Posted: Tue Jul 10, 2007 9:18 am Post subject: Throttle cables |
Lowell, sorry I didn't make it clear at first. It is easy to replace the
cable in the choke system and it should be in the throttle. I disconnected
the throttle cables this morning and pulled the control rod back out of the
cartridge as far as I could without removing the little clamps from the
cables and I believe the rod will come all the way out if I cut the cables.
But I would like to know for sure before I cut them. I don't like the cable
they used, it just does not stay together well and much better cable is
available.
Yes, the old way was better.
Barry
Giovanni Day
Posted: Tue Jul 10, 2007 10:00 am Post subject: Re: Throttle cables |
Barry,
I have a spare old vernier setup including that parts that go on the frame I am willing to sell if you need them.
_________________ _______________________________________
Giovanni Day
Model 4 speedster 912 |
