Tailcone longeron hole clearances
william(at)gbta.net
PostPosted: Thu Feb 16, 2006 8:28 am    Post subject: Tailcone longeron hole clearances Reply with quote
On page 10-13 steps 4, 6, and 7 we are instructed to drill the end holes of each piece to #12's into the longerons.  What is the proper, or acceptable hole clearances (to the edge of the longerons)???  Mine range from 1/4" to 1/8 inch on the closest ones.  Is this an acceptable distance or do I need to get new longerons and start over???
Pictures are attached.
Thanks in advance,
Bill Britton
RV-10 Tailcone
 Filesize:  45.69 KB
 Viewed:  521 Time(s)
 Filesize:  46.37 KB
 Viewed:  495 Time(s)
armywrights(at)adelphia.n
PostPosted: Thu Feb 16, 2006 3:23 pm    Post subject: Tailcone longeron hole clearances Reply with quote
Without measuring, yours look similar to mine, so it looks like we both followed as per plans.  You’ll be putting bolts in those #12 holes.
Rob
#392 Emp Attach
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Thursday, February 16, 2006 10:24 AM
To: RV10-list(at)matronics.com
Subject: Tailcone longeron hole clearances
Thanks in advance,
Bill Britton
RV-10 Tailcone
