william(at)gbta.net Guest
Posted: Thu Feb 16, 2006 8:28 am Post subject: Tailcone longeron hole clearances |
On page 10-13 steps 4, 6, and 7 we are instructed to drill the end holes of each piece to #12's into the longerons. What is the proper, or acceptable hole clearances (to the edge of the longerons)??? Mine range from 1/4" to 1/8 inch on the closest ones. Is this an acceptable distance or do I need to get new longerons and start over???
Pictures are attached.
Thanks in advance,
Bill Britton
RV-10 Tailcone
45.69 KB |
530 Time(s) |
46.37 KB |
504 Time(s) |
Posted: Thu Feb 16, 2006 3:23 pm Post subject: Tailcone longeron hole clearances |
Without measuring, yours look similar to mine, so it looks like we both followed as per plans. You’ll be putting bolts in those #12 holes.
Rob
#392 Emp Attach
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Thursday, February 16, 2006 10:24 AM
To: RV10-list(at)matronics.com
Subject: Tailcone longeron hole clearances
Thanks in advance,
Bill Britton
RV-10 Tailcone
