Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Mon Aug 06, 2007 6:44 am Post subject: BATTERY MASTER SWITCH |
Cheers,
I'm still searching for that elusive device - in an attempt to avoid
the cost of an ampere or two of contactor current - which will control a
primary battery source and another for secondary battery source.
I have found several which meet one criterion or another, but not
all:
[a] should carry as much current as a contactor for that job;
[b] needs to be an up-down rather than rotary type switch;
[c] should be on a remote(able) stalk so I can undo the connection to
remove the instrument panel ;
[d] cost less than the usual contactor - or at least be competitive.
I have devised a system to isolate the controls from wandering
fingers so am not fussy about security. I'm not sure what a "Kill switch" is
really.
Any help would be most appreciated.
Ferg
Classic 914 CS prop mono
PS: My server is down for the last 2 days, so my thanks will be
delayed.........
rampil
Posted: Mon Aug 06, 2007 9:55 am Post subject: Re: BATTERY MASTER SWITCH |
Fergus,
I use a solid state contactor, the EV200 which meets some of your
criteria. It can handle 500A (enough to start a cold 914 or even a 912s),
has a hold current of 0.125. It is not cheap however at $90, but it is
less weight on the firewall.
rob(at)hyperion-ef.com Guest
Posted: Mon Aug 06, 2007 1:38 pm Post subject: BATTERY MASTER SWITCH |
Rob Housman a écrit :
Indeed, it is a mechanical contactor, and it is not light either.
I installed two of them in our dual battery project. No problem with the
contactors themselves, but I suspect their command circuit sends some
perturbation in the ship's circuit, and I experienced some problems with
my low voltage warning module.
http://contrails.free.fr/elec_lvwm_en.php
Best regards,
Gilles
rampil
Posted: Mon Aug 06, 2007 5:22 pm Post subject: Re: BATTERY MASTER SWITCH |
OK, the EV200 has mechanical contacts, but a) there is nothing inherently
wrong with mechanical contacts, and b) the hold current is, as I said
1/8 or less than that of a conventional solenoids.
Giles, I have a Nuckolls, LVBM circuit in my plane and have not noted
any interaction. Why do you suspect the EV200?
Posted: Mon Aug 06, 2007 11:41 pm Post subject: BATTERY MASTER SWITCH |
Ira and all,
That's why I chose these contactors.
| Quote: | Giles, I have a Nuckolls, LVBM circuit in my plane and have not noted
Some info at http://contrails.free.fr/elec_lvwm_en.php
When the EV 200 are replaced with a standard contactor the problem
vanishes...
Best regards,
Gilles
rampil
Posted: Tue Aug 07, 2007 6:14 am Post subject: Re: BATTERY MASTER SWITCH |
Rob,
The solid state relay you point to has a max current rating of 25A.
This is about 1/4 that needed to function as a true master contactor
and handle starting load for the engine.
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Thu Aug 09, 2007 3:13 pm Post subject: BATTERY MASTER SWITCH |
Hi Ferg,
I used an EV200 in my Europa and it worked fine until I had my "hit by
lighting" incident. It turned the electronics into a small charred spec and
obviously didn't work anymore. Of course this left me flying at 9500' with
the master contactor turned off. Fortunately I have my system set up with
an essential buss that can be feed directly for the battery. I guess it was
some real world testing.
Anyhow, as part of my repairs while I was "on the road" so to speak I
installed a contactor from a NAPA auto parts store for $16.50 and there it
has stayed from that day to this. It was smaller and lighter than the EV200
and it didn't cost $90... I assume that if I get hit by lightning again
(perish the thought) then it will probably continue to work.
I did try a solid state 1600A device for a while. It worked fine until the
engine kicked back and it went the same way as the EV200 electronics. Pity
really because it only weighed a few ounces and I didn't have to pay a one
amp penalty when it was energized.
So, in conclusion, go down to the local NAPA store and by a low tech
contactor or a battery isolator switch, sometimes simple is best.
Paul
raimo.toivio(at)rwm.fi Guest
Posted: Fri Aug 10, 2007 9:41 am Post subject: BATTERY MASTER SWITCH |
Dear Ferg
here is my solution.
I divided the electrical consumption in two as follows:
1) starter, trimming devices, stall warning, gear warning,
door warnings, clock, Dynon back-upp charger, burglary-alarm etc.
This is handled by full mechanic main-swithch
which is installed over the glove shelf (it does not
prevent removing the panel, it is light weight, cheap
and solid and it is operated w/o el pwr).
The switch is about similar somebody has installed
to the co-pilot´s head rest in the case his accu is in the back.
Price was about 15 euros.
2) all the rest is handled by small automotive type relay
http://www.biztee.com/Products/2649.html
using about 30 mA. It handles 40A which is enough for me.
I use it by "master switch" in my panel´s left side.
Price was about 5 euros.
- normally # 1 is always open and # 2 is closed
(trim CB must open also separately!).
- when flying both are closed (ON) of course.
- in the case of emergency landing I open # 2 and
leave # 1 closed - so I am still able to start, use trim
and have all the warnings I am used to (and clock is in time!)
- during long (more than two weeks) staying period I open (OFF) both
This was simple, cheap, lightweight, prctical and safe solution for my purposes.
Wishes, Raimo
