				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| Fergus Kyle
				|  Posted: Mon Aug 06, 2007 6:44 am    Post subject: BATTERY MASTER SWITCH |   |
				| Cheers,
I'm still searching for that elusive device - in an attempt to avoid
 the cost of an ampere or two of contactor current - which will control a
 primary battery source and another for secondary battery source.
 I have found several which meet one criterion or another, but not
 all:
 [a]	should carry as much current as a contactor for that job;
 [b]	needs to be an up-down rather than rotary type switch;
 [c]	should be on a remote(able) stalk so I can undo the connection to
 remove the 	instrument panel ;
 [d]	cost less than the usual contactor - or at least be competitive.
 I have devised a system to isolate the controls from wandering
 fingers so am not fussy about security. I'm not sure what a "Kill switch" is
 really.
 Any help would be most appreciated.
 Ferg
 Classic 914 CS prop mono
 PS: My server is down for the last 2 days, so my thanks will be
 delayed.........
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| rampil
				|  Posted: Mon Aug 06, 2007 9:55 am    Post subject: Re: BATTERY MASTER SWITCH |   |
				| Fergus,
 I use a solid state contactor, the EV200 which meets some of your
 criteria. It can handle 500A (enough to start a cold 914 or even a 912s),
 has a hold current of 0.125.  It is not cheap however at $90, but it is
 less weight on the firewall.
 Ira N224XS
		| Back to top |  |
		| rob(at)hyperion-ef.com Guest
		| Back to top |  |
		| Gilles.Thesee(at)ac-greno Guest
				|  Posted: Mon Aug 06, 2007 1:38 pm    Post subject: BATTERY MASTER SWITCH |   |
				| Rob Housman a écrit :
 Indeed, it is a mechanical contactor, and it is not light either.
 I installed two of them in our dual battery project. No problem with the
 contactors themselves, but I suspect their command circuit sends some
 perturbation in the ship's circuit, and I experienced some problems with
 my low voltage warning module.
 http://contrails.free.fr/elec_lvwm_en.php
 Best regards,
 Gilles
		| Back to top |  |
		| rampil
				|  Posted: Mon Aug 06, 2007 5:22 pm    Post subject: Re: BATTERY MASTER SWITCH |   |
				| OK, the EV200 has mechanical contacts, but a) there is nothing inherently
wrong with mechanical contacts, and b) the hold current is, as I said
 1/8 or less than that of a conventional solenoids.
 Giles, I have a Nuckolls, LVBM circuit in my plane and have not noted
 any interaction.  Why do you suspect the EV200?
 Ira N224XS
		| Back to top |  |
				|  Posted: Mon Aug 06, 2007 11:41 pm    Post subject: BATTERY MASTER SWITCH |   |
				| Ira and all,
  	  | Quote: |  	  | b) the hold current is, as I said 1/8 or less than that of a conventional solenoids.
 That's why I chose these contactors.
  	  | Quote: |  	  | Giles, I have a Nuckolls, LVBM circuit in my plane and have not noted any interaction.  Why do you suspect the EV200?
 Some info at http://contrails.free.fr/elec_lvwm_en.php
 When the EV 200 are replaced with a standard contactor the problem
 vanishes...
 Best regards,
 Gilles
		| Back to top |  |
		| rampil
				|  Posted: Tue Aug 07, 2007 6:14 am    Post subject: Re: BATTERY MASTER SWITCH |   |
				| Rob,
 The solid state relay you point to has a max current rating of 25A.
 This is about 1/4 that needed to function as a true master contactor
 and handle starting load for the engine.
 Ira N224XS
		| Back to top |  |
		| paul.mcallister
				|  Posted: Thu Aug 09, 2007 3:13 pm    Post subject: BATTERY MASTER SWITCH |   |
				| Hi Ferg,
 I used an EV200 in my Europa and it worked fine until I had my "hit by
 lighting" incident.  It turned the electronics into a small charred spec and
 obviously didn't work anymore.  Of course this left me flying at 9500' with
 the master contactor turned off.  Fortunately I have my system set up with
 an essential buss that can be feed directly for the battery.  I guess it was
 some real world testing.
 Anyhow, as part of my repairs while I was "on the road" so to speak I
 installed a contactor from a NAPA auto parts store for $16.50 and there it
 has stayed from that day to this. It was smaller and lighter than the EV200
 and it didn't cost $90... I assume that if I get hit by lightning again
 (perish the thought) then it will probably continue to work.
 I did try a solid state 1600A device for a while.  It worked fine until the
 engine kicked back and it went the same way as the EV200 electronics.  Pity
 really because it only weighed a few ounces and I didn't have to pay a one
 amp penalty when it was energized.
 So, in conclusion, go down to the local NAPA store and by a low tech
 contactor or a battery isolator switch, sometimes simple is best.
 Paul
		| Back to top |  |
		| raimo.toivio(at)rwm.fi Guest
				|  Posted: Fri Aug 10, 2007 9:41 am    Post subject: BATTERY MASTER SWITCH |   |
				| Dear Ferg
 here is my solution.
 I divided the electrical consumption in two as follows:
 1) starter, trimming devices, stall warning, gear warning,
 door warnings, clock, Dynon back-upp charger, burglary-alarm etc.
 This is handled by full mechanic main-swithch
 which is installed over the glove shelf (it does not
 prevent removing the panel, it is light weight, cheap
 and solid and it is operated w/o el pwr).
 The switch is about similar somebody has installed
 to the co-pilot´s head rest in the case his accu is in the back.
 Price was about 15 euros.
 2) all the rest is handled by small automotive type relay
 http://www.biztee.com/Products/2649.html
 using about 30 mA. It handles 40A which is enough for me.
 I use it by "master switch" in my panel´s left side.
 Price was about 5 euros.
 - normally # 1 is always open and # 2 is closed
 (trim CB must open also separately!).
 - when flying both are closed (ON) of course.
 - in the case of emergency landing I open # 2 and
 leave # 1 closed - so I am still able to start, use trim
 and have all the warnings I am used to (and clock is in time!)
 - during long (more than two weeks) staying period I open (OFF) both
 This was simple, cheap, lightweight, prctical and safe solution for my purposes.
 Wishes, Raimo
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
