kolbmark3
Joined: 10 Jan 2006 Posts: 40 Location: Mt Clemens, MI
Posted: Sun Sep 09, 2007 12:56 pm Post subject: Taxiway landings |
flykolb wrote:
| Quote: | "As far as landing on a taxiway, that is a HUGE NO NO
I seem to remember that Lakeland used the taxiway as the main landing
strip during SnF. Is my memory wrong?"
You memory is good. I remember being told by the control tower at one
airport to land my *Cessna* on the taxiway. I don't remember why .
Jim
Kolb Mark 3
During SNF, the taxiway is designated as an official runway. IIRC, the
main & taxiway 'runways' are actually marked with an L or R, as
appropriate. As far as the FAA is concerned, during SNF (OSH does the
same thing) the taxiway is no longer a taxiway; it's a runway. No one
actually taxis on the 'narrow runway' during SNF.
I would think that the thing to remember is the 'why'. If the taxiway
isn't designated as a landing zone, other pilots will not be expecting a
plane to arrive on it from the sky & might taxi into your path.
I have a neighbor whose flown a SuperCub in some pretty windy
conditions. He once had to depart a controlled field in wind so strong
that he was literally taxi-ing in overlapping circles to get to the
actual runway. He asked the tower for permission to depart from an
intersecting taxiway instead of the runway. The tower's answer was that
they couldn't authorize it, but he could exercise his authority as pilot
in command to take whatever action was necessary for safe flight at that
time. He departed using the taxiway. Note that there was no other
traffic at the time. It's very unlikely that the tower would have given
him that leeway if there had been heavy traffic around the field at that
time.
Charlie
Richard Pike
Posted: Sun Sep 09, 2007 3:27 pm Post subject: Taxiway landings |
Exactly right. Years ago, Albany, GA had a closed runway 9-27 that was
fairly grown up with grass, and had been closed for years. The Rockwell
factory on the field made Thrush cropdusters, and the test pilots all had
the callsign of "Toughbird," which was what Rockwell was using as a promo
for their airplanes at that time. Well, Toughbird 6 was coming back from an
evaluation of a new Thrush Commander, and the wind was something like
270(at)35. The normal runways were 22 or 34, so either one would have been a
huge crosswind component. I gave him the wind, and he came right back with
"Toughbird 6 requests to land on closed runway 27 as traffic permits, I
realize you can't give me a landing clearance, I understand that landing
will be at my own risk."
Obviously he had read the manual, FAA 7110.65, paragraph 3-3-2 which said -
If an aircraft requests to takeoff, land, or touch-and-go on a closed or
unsafe runway, inform the pilot the runway is closed or unsafe, and
a. If the pilot persists in his/her request, quote him/her the appropriate
parts of the NOTAM applying to the runway and inform him/her that a
clearance cannot be issued.
b. Then, if the pilot insists and in your opinion the intended operation
would not adversely affect other traffic, inform him/her that the operation
will be at his/her own risk.
PHRASEOLOGY- RUNWAY (runway number) CLOSED/UNSAFE.
If appropriate, (quote NOTAM information),
UNABLE TO ISSUE DEPARTURE/LANDING/TOUCH- AND-GO CLEARANCE.
DEPARTURE/LANDING/TOUCH-AND-GO WILL BE AT YOUR OWN RISK.
My reply? "Toughbird 6, no traffic, proceed as requested, contact ground
121.7 after completing your landing roll."
And that's how it's done. Easy as pie.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
JetPilot
Posted: Sun Sep 09, 2007 7:42 pm Post subject: Re: Taxiway landings |
Special events are just that, special events. Sometimes taxiways become runways, and sometimes runways become parking ramps for airplanes, so what ?? To think that this transfers to normal operations, and makes it " OK " to land on the taxiway once in a while is just insane.
Im sure it is very possible that some small uncontrolled airport somewhere may like, or be setup for the ultralights to land on the taxiway. But again, for some ultralight guy to think that this makes it ok to go to other airports and land on taxiways is wrong. Keep on landing on them taxiways, and let us know what happens when you get caught.
Mike
Kolb MK-III Xtra, 912-S |
JetPilot
Mike
Steve Boetto
Posted: Mon Sep 10, 2007 7:44 am Post subject: Taxiway landings |
In a message dated 9/9/2007 11:49:14 P.M. Eastern Standard Time, orcabonita(at)hotmail.com writes:
| Quote: | | Special events are just that, special events. Sometimes taxiways become runways, and sometimes runways become parking ramps for airplanes, so what ?? |
Mike, I believe that was my point.
Steve
Firefly 007/Floats
See what's t="_blank">Make AOL Your Homepage.
Snoopy Baxley
jlsk1(at)frontiernet.net Guest
Posted: Mon Sep 10, 2007 5:53 pm Post subject: Taxiway landings |
Dang it all, now I`m worried about taxiing on a runway!!! Jim
