rowedenny(at)windstream.n Guest
Posted: Wed Sep 19, 2007 3:36 am Post subject: 582 ignition trigger wires |
Folks,
My buddy Dave who recently bought the Slingshot has discovered that the red/white ignition trigger wires coming out of the 582 have insulation that has turned soft, almost gummy. Does not appear to have been caused by high current but seems to maybe be a chemical reaction.
Has anyone else with a 582 seen this happen? Its only the trigger wires, the other wires coming out of the engine have good insulation. It seems like Rotax used crappy wire for their ignition triggers at some point.
Denny Rowe, Mk-3, PA
jlsk1(at)frontiernet.net Guest
Posted: Wed Sep 19, 2007 4:10 am Post subject: 582 ignition trigger wires |
I`ve been having an intermittent tach problem, & upon close examination on my 582, the yellow/black & Black/yellow wires are now so soft, I can induce fraying rubbing hard with my fingers! I`m having them replaced tommorrow eve on my 582. I can`t speak about the red ones yet though. Jim
Posted: Wed Sep 19, 2007 5:22 am Post subject: 582 ignition trigger wires |
Jim:
You all spoke with Kodiak about the problem?
To me, that is a serious one.
Some years ago Kodiak went through a alternator stator exchange program because of improper insulation on wiring.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Sep 19, 2007 8:42 am Post subject: 582 ignition trigger wires |
John, I have a Rotax trained tech coming Thurs PM to look at this. This engine was overhauled by Ronnie at South Ms Light Aircraft Dec 2006 & was put into service this May. Ronnie called it "0" timed". Ronnie came highly recommended.
When I installed it, both Oil injection lines leaked, they had not been replaced.Now, the wiring condition is suspect. I will go to another service agent in the future. I`ll pick your brain next week after I get a verdict thursday PM on these wires. Thanks for the input, Jim---
Posted: Wed Sep 19, 2007 9:16 am Post subject: 582 ignition trigger wires |
Sounds like this might be one of those John, I'll try to get the S/N from Dave tonight and call Kodiak.
Denny
Posted: Fri Sep 21, 2007 6:28 am Post subject: 582 ignition trigger wires |
Well, I had my Rotax guy come look at my wiring on my 582 last night, & I showed him these posts. He agreed that I should start by calling Rotax & see about the replacement Stator. Also of note , the gray Tach wire showed a 0 Ohm reading.
Called Lockwood, they said that Stator / bad wiring situation was on 912`s ONLY, a few years back, and the best thing to do was to clip the connectors off the wires, sleeve them with heat shrink tubing to re-insulate them & fly on. Then when I mentioned the Bad Ohm reading on the meter, he said that there was indeed a bad coil in the stator & If I wanted that fixed the only was was to replace the stator.
Over $600. & I hope to have it installed in time for a Flight to London KY next week.
Jim
Posted: Fri Sep 21, 2007 6:44 am Post subject: 582 ignition trigger wires |
Jim K:
Probably find a used one. However, I would feel better with a new one even even though it was overpriced.
[quote] Over $600. & I hope to have it installed in time for a Flight to London KY next week.
Jim
Titus, Alabama |
Posted: Fri Sep 21, 2007 6:55 am Post subject: 582 ignition trigger wires |
I Never thought about a used one, but, I guess I would always wonder about its condition. Anyway, the new one is supposed to be here Tuesday, my rotax guy sez he`s very busy next week, but I hope he'll work me in. Jim
Malcolmbru(at)aol.com Guest
Posted: Fri Sep 21, 2007 11:59 am Post subject: 582 ignition trigger wires |
the tac wires on my 582 went bad ( no or low rpm readings ) you can get proper tac readings from other wires on the stator so I stopped using the gray tac wires and my motor has ben running fine for over 70 hrs now. how much do you want for your old stator? malcolm michigan
See what's new at AOL.com and .
Richard Pike
Posted: Fri Sep 21, 2007 12:52 pm Post subject: 582 ignition trigger wires |
Lockwood said the same thing to me when my tach quit working, and implied that the tach stator failure was a fairly common problem. Got a Tiny Tach that wraps it's sensing wire around the spark plug wire and have been well satisfied. Except for the funny looking Tiny Tach on my panel where the original tach use to be...
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Fri Sep 21, 2007 4:48 pm Post subject: 582 ignition trigger wires |
make an offer, Jim
