Steve Boetto
Posted: Wed Oct 03, 2007 6:11 pm Post subject: Grand Vortex Generator Challenge |
In a message dated 10/3/2007 3:24:40 P.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | I typically fly my approaches power clear back to idle stop, 65-70 MPH diving like a bat out of hell
Glad to hear that Mike, sounds like you are on the ball. Coming from a high inertia low drag aircraft to a low inertia high drag aircraft was a big adjustment for me.
Steve B
Firefly 007/Floats
Make AOL Your Homepage.
JetPilot
Posted: Wed Oct 03, 2007 6:35 pm Post subject: Re: Grand Vortex Generator Challenge |
If you saw what was on the approach end of the runway, I have a choice of power lines, various chain link fences, or a bunch of Palm trees in the nursery Engines like to quit at idle sometimes, so I try to pull the power off with the idea that it might not come back.
I did not know you were flying other airplanes Steve, what were you flying before the Kolb ?
Mike
Kolb MK-III Xtra, 912-S |
Posted: Thu Oct 04, 2007 2:18 am Post subject: Grand Vortex Generator Challenge |
I know it is difficult for VG'ers, but over the years and hours, I have not found a requirement for VGs on Homer's airplanes. >>
Hi ,
Depends on `requirement`. To fly the way Homer intended I am sure that VG`s are not required. The plane is obviously great and fills most peoples requirements without them. Just look at JH`s flights for starters. John is obviously a master of the plane and I am sure there are many others
However in the UK for the Extra to qualify as a `microlight` (not exctly the same as your Ultralight) you MUST have the VG`s fitted or the stalling speed will be too high. In the face of the testing that was done to establish this it is foolish to maintain that VG`s make no difference. If that was the case there would be no Xtra flying in the UK.
Hope to be back flying myself soon. All paperwork issued. Test Pilot booked for 19th Oct. Hope the weather holds. Its great today, blue sky, no wind. I may do some taxying later to try to get my hand in again. Must make sure that I do not accidentally taxy too fast .......?
Pat
Steve Boetto
Posted: Thu Oct 04, 2007 5:09 am Post subject: Grand Vortex Generator Challenge |
In a message dated 10/3/2007 10:38:09 P.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | I did not know you were flying other airplanes Steve, what were you flying before the Kolb ?
Mike |
Long EZ N27SB. 90 Kts in the pattern, 70 Kts on Final with the nose high and everything hanging out. It is about as far away from a Firefly you can get.
steve
See what's new ="_blank">Make AOL Your Homepage.
Dennis.Kirby(at)kirtland. Guest
Posted: Thu Oct 04, 2007 8:39 am Post subject: Grand Vortex Generator Challenge |
Rick Neilsen wrote: << The challenge showed me a few things.
John is a great pilot which allowed him to fly his plane as slow as
Richard Pike in spite of the weight differences. What was significant to
me was that the claimed benefit of the VG just wasn't there. >>
John and Richard's Mark-IIIs are very different from each other. This
makes it difficult to compare specific flight characteristics
attributable to the vortex generators.
It seems to me that a more "objective" comparison of VGs versus no-VGs
would be to have one pilot fly the SAME AIRPLANE with and without VGs.
Then see what he thinks. I nominate Hauck as our test pilot.
I purchased a set of the LandShorter VGs, but have not yet installed
them on my Mark-III. How's this for a plan: Next May, and the 6th
annual Monument Valley fly-in, I'll let John fly my plane with a clean
wing. Then, we'll install the VGs (it should only take an hour or two,
especially with all the available help), and let John fly it again.
It'll be interesting to see if he notices any difference. Not trying to
convince John that he should install these on Miss P'Fer - just looking
to see if he detects any slow flight performance improvements on this
Mark-III.
I've been enjoying this thread ...
Dennis Kirby
New Mexico
Posted: Thu Oct 04, 2007 9:05 am Post subject: Grand Vortex Generator Challenge |
Thanks, but no thanks.
You are more than qualified to fly your own test and make your own
decisions.
I can assure you, I have no desire or requirement to fly any slower than I
was flying off Richard Pike's wing last Saturday afternoon. That flight
convinced me there was no appreciable difference in slow flight capability
between the two mkIII's.
I have no slow flight control problems in my mkIII that need fixing.
The only time I suffer from "Kolb quit" is when I get below the stall speed.
By now, you all are probably, I hope, getting the message that I am not
interested in VG's. Should I ever have another airplane that does not fly
as well as Kolb aircraft, I might investigate the possibility of VG's saving
the day.
_________________ John Hauck
Titus, Alabama |
lcottrell
Posted: Thu Oct 04, 2007 1:08 pm Post subject: Grand Vortex Generator Challenge |
<Dennis.Kirby(at)kirtland.af.mil>
I am curious as to why you believe there was no benefit to the VG's? It
seems to me that if Richard had pulled his flaps he could have flown slower,
or am I missing something there? I consider John a friend of mine and a
exceptional pilot. A bit hard headed on occasion, but then that includes all
of us Alpha types. That John was able to fly his plane at that speed and
configuration is not a surprise to me at all, However you are overlooking
two other factors. Richards lack of a radio causing him to fly blind in a
formation, ( which I understand he has not done before) and the fact that it
was not necessary for him to deploy flaps to fly at a speed which required
that John use them.
If you "have nots" don't want more stability in turns, slow flight,
increased cushion at landing, less bounces, and you are as good a pilot (of
which I have little doubt) as John, then don't put the things on! Just spare
me the rationalization.
Larry, Oregon
neilsenrm(at)comcast.net Guest
Posted: Thu Oct 04, 2007 4:49 pm Post subject: Grand Vortex Generator Challenge |
Hey Larry
Good to hear from you. It was great talking to at Monument Valley.
I will respond to this one LAST time. Would all you VG guys please read my post again before you post. John's plane is a good 20% heaver than Richard's this does increase John's stall speed. I think John's heaver gross weight fairly well balances his use of flaps. OK lets say JUST for argument's sake John's increased weight didn't lower his stall speed at all. His use of flaps doesn't reduce his stall speed by the amount everyone CLAIMS the VGs do. To hear some of you talk you would think VGs would give everyone a 10 MPH stall speed.
In the clip you attached I said that VGs didn't give Richard the "claimed" advantage I didn't say no advantage.
I'm with John's point of view on this one VGs don't appear to give enough benefit on a Kolb that would make me want to put them on my plane. I have a open mind on this and would change my mind if I could see a significat differance. I was there and I just didn't see it.
Rick Neilsen
Redrive VW powered MKIIIC
[quote] --> Kolb-List message posted by: "Larry Cottrell"
> --> Kolb-List message posted by: "Kirby Dennis Contr MDA/AL"
I am curious as to why you be lieve there was no benefit to the VG's? It
that John use them.
which I have little doubt) as John, then don't put the things on! J ust sp [quote][b]
mmatuszczak(at)cfl.rr.com Guest
Posted: Thu Oct 04, 2007 6:53 pm Post subject: Grand Vortex Generator Challenge |
Best $100. I've spent on my FSII. Not for the enhanced performance but for the added safety!!!
MEM FSII 450hrs
Posted: Thu Oct 04, 2007 7:10 pm Post subject: Grand Vortex Generator Challenge |
Hi Mike:
I am the last person I know that would want to drag out the "great VG debate".
However, could you expand on your statement below, please? Telling me you put them on for added safety leaves a lot of questions unanswered. Did you get the added safety you were looking for, and how did that happen?
[quote] Best $100. I've spent on my FSII. Not for the enhanced performance but for the added safety!!!
MEM FSII 450hrs
Titus, Alabama |
1planeguy(at)kilocharlie. Guest
Posted: Fri Oct 05, 2007 6:03 am Post subject: Grand Vortex Generator Challenge |
<SNIP>
For Pete sake…it is kind of like when your wife asks you, “Why do you love me?”…you will get cooked on that question no matter what you say. When you come to the table with your mind made up you will never understand the other point of view.
I had a arrogant (sounding) jerk come up to me at SERFI after seeing the VG’s on my wing and ask, “What aerodynamic problem are these on there to fix?”…I just said the problem of wanting it to stall even slower and more gentle than it already did.
What you fellows saw at the great “test” was 2 different planes, flown in different configurations, at different weights, at different power settings…in other words, from an engineering standpoint you saw nothing!!! The flaps alone can account for a huge increase in max Cl. If the ground rules had been set beforehand, full flaps/no flaps, idle power only, load the planes to similar weights, etc. it would have been in the neighborhood of a valid test, but the true VALID test is flying the same plane WITHOUT them and then WITH them…no other differences except the effect from the VG’s.
I’LL STATE AGAIN…THE “BEST” TEST OF THEIR BENEFIT IS THE COUPLE OF DOZEN GUYS ON THIS LIST ALONE THAT HAVE TRIED THEM AND SAID THEY WOULD NOT TAKE THEM OFF AND THAT IT WAS THE BEST $100 THEY HAD SPENT ON THEIR PLANE…
If you guys that have NOT actually tried them don’t want to then fine, but DON’T say they have no benefits! Us that HAVE actually tried them are not stupid...
I have said several times that the improvement is not just a number on the airspeed indicator but how it “feels” when that airspeed indicator is getting near the bottom. I will guarantee that the absolute bottom number will be lower than before, but that isn’t the major thing.
I just can’t get my head around why you guys are so hell-bent against something you haven’t actually tried…If you try it and can say it was a waste of time,money,etc. then fine you might have a dog in the fight, but why do you even HAVE an opinion of something you have NO EXPERIENCE with? Like the other major “controversy” of the Kolb-list…SEAFOAM…I never say anything about it, cause…you guessed it …I NEVER HAVE TRIED IT!!! Sorry, but it didn’t interest me!!! Oh well!!! But I haven’t had ANYTHING to say about it, pro or con, because I don’t know!!! Nuff said…
Jeremy
P.S. From the way I’m ranting about this, you’d think I sold them…Legal disclaimer…I don’t make a penny off anyone installing them or not
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Posted: Fri Oct 05, 2007 6:04 am Post subject: Re: Grand Vortex Generator Challenge |
I just bought my daughter a car, but, I needed the dealer to find one that met my specs.
I wanted ABS and Side Air Bags. Neither are items "budget cars" like this are found in stock, but they are options.
Added safety - I think so. Does she need to prove it - I hope not.
_________________ Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot
Richard Pike
Posted: Fri Oct 05, 2007 7:57 am Post subject: Re: Grand Vortex Generator Challenge |
Jeremy, I think I may have figured it out -
http://www.ecotopia.com/webpress/nih.htm
Richard Pike
MKIII N420P (420ldPoops)
Posted: Sat Oct 06, 2007 3:28 am Post subject: Grand Vortex Generator Challenge |
Mike
Yes Yes....... We heard all that before. But when it came to a side by side
fly off there was no difference. Sometimes when we invest time and money we
want it to be soooo bad...... I had a actual forced landing in a bean field
a few years ago and Homers design came thru for me just fine.
Yes I know it wasn't a fair test. Lets review flaps verses 20% less weight,
you guys are right John was unfairly challenged. Richard should have carried
more weight. Also Richard said he practiced slow flight on the way to
Homecoming and he came for the day so he didn't have all that camping gear
someone suggested.
Someone said don't knock it till you try it. As sayings go seeing is
believing.
I'm just giving you VG guys a rough time.
For me I still don't see enough advantage and before the test I was about
ready to put them on.
Rick Neilsen
Posted: Sat Oct 06, 2007 7:38 am Post subject: Grand Vortex Generator Challenge |
At 12:26 PM 10/3/07 -0400, you wrote:
believing.
Rick,
I will extend the same proposal to you that I gave to John H.
"If you are up to it, I will supply you with a set of VG's that can be
temporarily mounted with electricians tape. That way you can fly and record
your stall speed, land, tape on the VG's and the fly again to get your new
slower stall speed. When you find that your stall speed is reduced you can
pass them on to the next doubter."
Will you duck and run and hide behind the "Homer" and "stock" word? Or are
you up to the challenge?. Here is a chance to try them at no cost to you,
and as you say "seeing is believing." The best part is that you get to do
it in your own aircraft so there will be no question about aircraft
variations except the without and with VG's.
If you do not want to do it, I will understand. I'm just trying to give you
non VG guys a rough time.
Jack B. Hart FF004
Winchester, IN
JetPilot
Posted: Sat Oct 06, 2007 8:25 am Post subject: Re: Grand Vortex Generator Challenge |
| NeilsenRM(at)comcast.net wrote: |
Rick Neilsen
Rick,
Something you should consider, this was ONE test where a pilot who admittedly was distracted and did not try very hard, was trying to out fly the best Kolb pilot in the country.
There have been reports and many scientific tests run by the British CAA, many aircraft manufactures in the US, and a bunch of Kolb pilots that have tested VG's, ALL of them very positive. Yet you are willing to ignore MASSIVE amounts of evidence collected over the years based on ONE test that went badly according to one of the pilots flying it ???
Does that make any sense to anyone ???
Mike
Posted: Sat Oct 06, 2007 8:58 am Post subject: Grand Vortex Generator Challenge |
flying it ???
Mike
Mike B/Jack H/Jeremy C:
I respect your decision to put VG's on your airplanes.
Please be gentlemen and respect my decision not to put them on mine.
I know it is difficult for you all to understand that some of us can and do
safely fly and enjoy our Kolbs without them.
You all are beginning to sound more and more like TV evangelist. Next
you'll be passing the "love offering" bucket.
Titus, Alabama |
JetPilot
Posted: Sat Oct 06, 2007 9:05 am Post subject: Re: Grand Vortex Generator Challenge |
Hi John,
I'm not trying to talk you into put them on miss P'fer. Your flying ability is so good, that you really don't need vortex generators. But as you so clearly demonstrated at the homecoming, the rest of need every advantage we can get
Mike
Posted: Sat Oct 06, 2007 9:34 am Post subject: Grand Vortex Generator Challenge |
| Quote: | I'm not trying to talk you into put them on miss P'fer. Your flying
Mike
Mike B:
Doesn't take much flying ability to pull the flaps down, the throttle back,
and keep the wings level. My mkIII did the performing. I did the riding.
I take no credit for how slowly my mkIII flew. There are no tricks in
keeping a Kolb above the stall, except maybe a gentle control touch. I
don't know of any other way to reduce stall. Guess I could have taken Roger
Lee's advice and hung on my pusher prop.
You said this morning the comparison between my mkIII and Richard P's was
not fair. Sounds like you were making the rules. You did not brief me on
them prior to my flight. What did transpire was pretty simple and the
briefing and agreement took place in about 10 seconds. Richard had already
cranked his 582. We agreed that I would fly off his right wing, start the
run on the runway at 50 mph and slow it down from there. Whoever got to the
east end of the field last was the winner. From my vantage point, which was
the best seat in the house, that is exactly what we did. We both arrived at
the end of the strip at the same time. If Richard could have flown much
slower and didn't is not my concern. The fly off was based on flying
performance demonstrated, not thought about. Seemed fair to me. We were
both sharing the same air at the same time. Could care less the differences
in weight, configuration, etc. We accomplished what we intended to do.
The comparison did not change my mind about putting VG's on my mkIII. I
still have no desire to stick'em on there. Please respect my wishes and
others they are not overpowered by the insistance that they must fly their
Kolbs with VGs. I do not recall insisting you all take them off yours.
Titus, Alabama |
beauford173(at)verizon.ne Guest
Posted: Sat Oct 06, 2007 9:55 am Post subject: Grand Vortex Generator Challenge |
.. fer what it's worth... could use a "Love Offering" down here, Johnny....
how does one go about contracting for one of those...? Do they deliver...?
Also, fer what it's worth, you gents should know that this here Grand Vortex
Generation string is teetering on the cusp of an historic milestone... By
my count, only four more shots on this string (not counting this one, which
is administrative in nature) will eclipse the infamous SEAFOAM string back
in the fall of '98... an extended bit of self-imposed agony which literally
brought tears to the eyes, new scar tissue to the fingers and lowered PH to
the intestinal tracts of Listers for many months afterward....
Historic Beauford
FF076
Brandon, FL
