ricksked(at)embarqmail.co Guest
Posted: Sun Oct 07, 2007 7:25 pm Post subject: Firewall & bottom skin Pro-Seal |
Gary,
I found the same thing confusing, later it tells you to use the high heat sealant but for the bottom, use proseal. My fix is was to use the high temp proseal from Van's made for selaing the firewall. I used it inside and outside at the relief cuts in the forewall and to make a nice seal around my Koolmat cover on the firewall.
Rick S.
40185
jchang10
Posted: Sun Oct 07, 2007 7:36 pm Post subject: Firewall & bottom skin Pro-Seal |
Gary... i believe the main reason is the latter - seal out CO and other
possible combustion gases. i have seen reports of quite a pressure
gradient in other planes. higher forward and lower in the cabin, aft of
the firewall.
thus, for this purpose, proseal was good enough for me.
jae
40533
fuselage gear mounts
On Page 28-13 Step 2: “It is recommended to use a thin layer of Pro-Seal
between the firewall flanges and the fuselage skins. Apply Pro-Seal to
the lower flange of the F-1000A Firewall Bulkhead then cleco the Firewall
Assembly to the F-1072 Fwd Fuse Bottom Skin as shown in Figure 1.�
With all the discussion in the past week about aluminum heat boxes in
front of the firewall, as I read this step it got me to wondering, are
they talking about the regular Pro-Seal or the high heat “Firewall
Sealant� available from Van’s? In the steps, it doesn’t say or I
don’t see any implication as to why they are suggesting the sealant. Is
it to hold the structure solid like the trailing edges of the wings, or is
it to try to seal any engine fumes from making it into the cabin or ????
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=138693#138693
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
jeff(at)westcottpress.com Guest
Posted: Mon Oct 08, 2007 8:25 am Post subject: Firewall & bottom skin Pro-Seal |
Hi Gary,
I just asked Vans this same question. Their response: "We used tank
sealant until we learned there was something better. Now we use the
high temp sealant."
Jeff Carpenter
40304
On Oct 7, 2007, at 8:11 PM, orchidman wrote:
Seal between the firewall flanges and the fuselage skins. Apply
Pro-Seal to the lower flange of the F-1000A Firewall Bulkhead then
cleco the Firewall Assembly to the F-1072 Fwd Fuse Bottom Skin as
shown in Figure 1.”
in front of the firewall, as I read this step it got me to
wondering, are they talking about the regular Pro-Seal or the high
heat “Firewall Sealant” available from Van’s? In the steps, it
doesn’t say or I don’t see any implication as to why they are
suggesting the sealant. Is it to hold the structure solid like the
trailing edges of the wings, or is it to try to seal any engine
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
