Firewall & bottom skin Pro-Seal
ricksked(at)embarqmail.co
PostPosted: Sun Oct 07, 2007 7:25 pm    Post subject: Firewall & bottom skin Pro-Seal Reply with quote
Gary,
I found the same thing confusing, later it tells you to use the high heat sealant but for the bottom, use proseal. My fix is was to use the high temp proseal from Van's made for selaing the firewall. I used it inside and outside at the relief cuts in the forewall and to make a nice seal around my Koolmat cover on the firewall.
Rick S.
40185
jchang10
PostPosted: Sun Oct 07, 2007 7:36 pm    Post subject: Firewall & bottom skin Pro-Seal Reply with quote
Gary... i believe the main reason is the latter - seal out CO and other
possible combustion gases. i have seen reports of quite a pressure
gradient in other planes. higher forward and lower in the cabin, aft of
the firewall.
thus, for this purpose, proseal was good enough for me.
jae
40533
fuselage gear mounts
On Page 28-13 Step 2: “It is recommended to use a thin layer of Pro-Seal
between the firewall flanges and the fuselage skins. Apply Pro-Seal to
the lower flange of the F-1000A Firewall Bulkhead then cleco the Firewall
Assembly to the F-1072 Fwd Fuse Bottom Skin as shown in Figure 1.�
With all the discussion in the past week about aluminum heat boxes in
front of the firewall, as I read this step it got me to wondering, are
they talking about the regular Pro-Seal or the high heat “Firewall
Sealant� available from Van’s? In the steps, it doesn’t say or I
don’t see any implication as to why they are suggesting the sealant. Is
it to hold the structure solid like the trailing edges of the wings, or is
it to try to seal any engine fumes from making it into the cabin or ????
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=138693#138693
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
jeff(at)westcottpress.com
PostPosted: Mon Oct 08, 2007 8:25 am    Post subject: Firewall & bottom skin Pro-Seal Reply with quote
Hi Gary,
I just asked Vans this same question. Their response: "We used tank
sealant until we learned there was something better. Now we use the
high temp sealant."
Jeff Carpenter
40304
Seal between the firewall flanges and the fuselage skins. Apply
Pro-Seal to the lower flange of the F-1000A Firewall Bulkhead then
cleco the Firewall Assembly to the F-1072 Fwd Fuse Bottom Skin as
shown in Figure 1.”
in front of the firewall, as I read this step it got me to
wondering, are they talking about the regular Pro-Seal or the high
heat “Firewall Sealant” available from Van’s? In the steps, it
doesn’t say or I don’t see any implication as to why they are
suggesting the sealant. Is it to hold the structure solid like the
trailing edges of the wings, or is it to try to seal any engine
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
orchidman
PostPosted: Mon Oct 08, 2007 1:03 pm    Post subject: Re: Firewall & bottom skin Pro-Seal Reply with quote
Thanks for the comments. I suspected it was to seal the cabin from gases and that the normal pro-seal would work. I hate opening a full High Temp Pro-Seal just for this.
Tomorrow evening is our EAA local chapter meeting and I am going to ask this of the 2 tech councilors that normally attend. I need to confirm something one of them said some time ago about RED RTV. I am going to ask about using the RED RTV as the sealant in this case. It is cheaper, no mixing and no waist. Very Happy
Any one see a problem with this in this specific use?
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
