rleffler
Posted: Tue Oct 09, 2007 4:00 pm Post subject: Riveting Question |
On page 9-14, when attaching the skins to the E-903 counter balance, I’m having problems figuring out (my complete lack of creativity) how to set the last rivet towards the trailing edge. The rivet on the top skin is set first, but there isn’t ample room to get my no hole in between to the two rivets (top and bottom) to squeeze and clearly any bucking bar is too big.
I’m sure there must be an obvious solution, I’m just not seeing it at the moment.
Bob
_________________ Bob Leffler
N410BL - Phase I
Posted: Tue Oct 09, 2007 4:12 pm Post subject: Riveting Question |
Oldie but a goodie Bob,
I used a cold chisel wedged into the trailing edge with the back rivet under the bottom skin and it came out OK, there are several ways but that was mine, others may chime in.
Posted: Tue Oct 09, 2007 4:19 pm Post subject: Riveting Question |
I don’t know about this specific part, but in cases like this using a pop rivet is probably acceptable.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: Bob Leffler [mailto:rvmail(at)thelefflers.com]
Sent: Tuesday, October 09, 2007 7:59 PM
Subject: Riveting Question
Bob
[quote] [b]
Posted: Tue Oct 09, 2007 4:24 pm Post subject: Riveting Question |
pop rivet with the MK-319-BS - it will be fine structurally.
rleffler
Posted: Wed Oct 10, 2007 2:38 am Post subject: Riveting Question |
Thanks for your comments.
I was starting to come to the same conclusion, since there are a couple of these already on the bottom.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Tuesday, October 09, 2007 8:25 PM
Subject: Re: Riveting Question
----- Original Message -----
Sent: Tuesday, October 09, 2007 4:58 PM
Bob
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | | 0123456789
__________ NOD32 2582 (20071009) Information __________
N410BL - Phase I
johngoodman
Posted: Wed Oct 10, 2007 8:44 am Post subject: Re: Riveting Question |
I see you already have an answer, but I gave up and used a blind rivet (pop).
John
_________________ #40572 Phase One complete in 2011 |
