rge177(at)yahoo.com Guest
Posted: Sat Oct 13, 2007 6:37 pm Post subject: Jab dual throttle |
I found a small issue with the Jab 601XL 3300
firewall forward, dual throttle installation. It
looks like the dual throttle from USJabiru was
designed for the pre- 6B8-11 upper angle, and 6B8-10
forward gusset on the 6B7-1 firewall top stiffener. I
believe these items (bb8-11,6b7-1) were added a couple
of years ago on the 601XL. The center arm of the
throttle bell mechanism, won't extend over the upper
angle. I thought about shortening the center arm a
little, and going through the top stiffener, but I'm
afraid I won't have enough throttle travel. I think I
can fix it by just extending the center arm an inch or
so, but I'm waiting to hear back from USJabiru to see
if they have any ideas or how they've dealt with this.
Has anyone else dealt with this?
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
jeffrey_davidson(at)earth Guest
Posted: Sun Oct 14, 2007 5:18 pm Post subject: Jab dual throttle |
Ron,
I installed my Jabiru 3300 about a year ago. I bought it and the
FWF about two years ago. So I have parts of that vintage. The FWF came
first by several months. I have the dual throttle option. For the center
throttle cable I drilled a hole in the "shelf" with no problems. I used the
thicker XL shelf with the cabin side U channel and the XL gussets between
the shelf and the nose gear channel. The current design in this area has
been enhanced further. I don't have XL plans to follow the current
configuration, but where I had a concern was at the point where the throttle
cables come through the firewall. The FSF package had simple bulkhead
fittings there. When the throttle was moved, it tried to flex the firewall
as the outer arms on the throttle rod over the shelf moved up and down. See
Larry McFarland's web site for the fix using a vertical slot for the
throttle cable through the firewall. I modified the solution a bit, and
will supply pictures if you like, but the basic design is Larry's.
Jeff Davidson
I found a small issue with the Jab 601XL 3300 firewall forward, dual
mosquito56
Posted: Sun Oct 14, 2007 8:03 pm Post subject: Re: Jab dual throttle |
I am planning on ordering the jab3300 with dual throttles tomorrow. Please let me know if Jab answers your problem. Vendors seem more than willing to spend hours talking to you to sell you something but when you buy the item and call for support, they say I will get back to you and never do. This is one reason I decided not to order the new Rans S-19. I had alot of trouble with Rans after I bought my S-12.
Let me know if you get an answer.
Don
Posted: Mon Oct 15, 2007 6:21 am Post subject: Jab dual throttle |
Jeff,
Thanks for the info, and I would like to see some
pics. I'll take a look at Larry's site also.
Mosquito56,
I've had to contact USJabiru 4 or 5 times, and so
far they've been very responsive. I'll let you know
what they say this time.
Ron
601XL-3300
Time: 06:18:32 PM PST US
Subject: RE: Jab dual throttle
Ron,
bought it and the
vintage. The FWF
came
option. For the
center
problems. I
used the
XL gussets
between
design in this area
has
follow the current
point where the
throttle
simple bulkhead
to flex the
firewall
moved up and down.
See
solution a bit,
and
is Larry's.
Jeff Davidson
firewall forward,
dual
lgingell
Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
Posted: Tue Oct 16, 2007 4:20 pm Post subject: Jab dual throttle |
Lance,
The push rod throttle's a good idea. That would
take a little friction out of the system, and be
smoother. I'm still waiting to hear from USJab, but I
may use your idea anyway. That would solve my
problem.
Ron
Time: 09:16:53 AM PST US
Subject: Re: Jab dual throttle
I was unimpressed with the dual throttle that I
received. I changed
quite a few
of the parts, and it works great now.
See my log entry around 8/17/2005 at
http://lancegingell.com/planebuild/constructionlog.asp
to see what I
did.
Cheers,
.lance
Zodiac XL/Jabiru3300
mosquito56
Posted: Tue Oct 16, 2007 8:54 pm Post subject: Re: Jab dual throttle |
When you buy you kit or order your plane, http://lancegingell.com/planebuild/ is the first site you should study. He has everything explained and pictures are excellent. His site is just as good as Zenith construction photo gallery.
WELL DONE LANCE!!!!!!!!!
Don
Zodiac 601 xl firewall and instruments
N601NV reserved
South Texas
_________________ Don Merritt- Laredo, Tx
Gig Giacona
Posted: Wed Oct 17, 2007 5:31 am Post subject: Re: Jab dual throttle |
I got a 403 message on the site.
| mosquito56 wrote: | When you buy you kit or order your plane, http://lancegingell.com/planebuild/ is the first site you should study. He has everything explained and pictures are excellent. His site is just as good as Zenith construction photo gallery.
Don
N601NV reserved
South Texas |
601XL Under Construction
lgingell
Posted: Wed Oct 17, 2007 8:38 am Post subject: Jab dual throttle |
Lance, good to hear from you. how is the plane flying? what are your chts and EGTs like at cruise?
Juan
archerm
Posted: Wed Oct 17, 2007 8:46 am Post subject: Jab dual throttle |
I have had great service from Jabiru. I have called them on numerous
occasions and they have been very helpful. I will say the firewall forward
kit is OK but not the same level of quality that the Zodiac kit was. Hasn't
been a problem since they have always been there to answer questions.
Good Luck
Matt
www.zodiacxl.com
_________________ Matt
www.zodiacxl.com |
dredmoody(at)cox.net Guest
Posted: Wed Oct 17, 2007 9:07 am Post subject: Jab dual throttle |
Matt,
There has been a recent modification (hopefully an improvement) to the Jabiru USA supplied cowl for the CH601XL. They have made room to accomodate a change in the ram air cooling ducts, which in turn were changed to accomodate the new style heads with more and larger cooling fins.
Another thing I was told is that the previous cheek scoops which fed the ram air ducts were not optimally lined up with the airflow from the prop. The new cowl has scoops better aligned and shaped to get more airflow into the cooling ducts.
Also the chin scoop to the oil cooler has been redone to provide better airflow to the oil cooler for more effective oil temp control.
All these changes became available early this year.
Dred
---- Matt & Jo <archermj(at)swbell.net> wrote:
Good Luck
Matt
www.zodiacxl.com
Posted: Thu Oct 18, 2007 5:53 pm Post subject: Jab dual throttle |
I talked to Pete today at USjabiru and he said that
most folks with the upper angle on the firewall shelf,
were running the throttle cable through the shelf like
Jeff did. I asked how much I should worry about the
cable entering the adjuster at an angle (happens at
low throttle settings when cable is pulled) and he
said not to worry about it. He said he isn't aware of
any premature cable wear doing it like that. I'll
probably install it that way, but add some fairlead to
the shelf to keep the cable from rubbing on the side
of the adjuster. If I end up with too much friction,
then I may convert to a push rod system like Lance
Gingell installed (by the way, excellent website
Lance.)
Thanks for all of the input,
Ron
601XL-3300
| Quote: | Ron,
| Quote: | I bought it and the FWF about two years ago. So I
have parts of that vintage. The FWF came first by
the center throttle cable I drilled a hole in >the
"shelf" with no problems...
Jeff >Davidson
| Quote: | I found a small issue with the Jab 601XL 3300
forward gusset on the 6B7-1 firewall top stiffener...
