n8vim(at)arrl.net Guest
Tim Olson
Posted: Thu Oct 25, 2007 10:01 am Post subject: Static ports |
To me then it sounds as if you have something else wrong in
the system. First, your flat ports had lots more error
than other people with those ports. And now, your domed
ports have a similar amount of further error of of
domed ports. It sounds like there's something else inherent
to your airframe or static system that's causing the problem
right now. Have you thoroughly leak checked it?
Sam Marlow wrote:
| Quote: | I have the new domed set. It helped, from the original flat units, they
were about 15 to 20 kts off. So newer is better, but still not very
close to accurate.
I saw Richard at OSH this year, and ask him about the error, he said the
positioning was just a best guess, and you can put them anywhere if it
works. He didn't have a problem on his 10, he though his was right on
the money. Richard is the kind of guy you can talk to, to bad the people
that answer the support line don't share this attribute.
Tim Olson wrote:
> Qualify that a bit more though. Do you have the OLD Cleveland
> ports with the flat face, or the NEW cleveland ports with the
> domed face? The old ones had that amount of error, but I
> see more like 2Kts with the new.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
> Sam Marlow wrote:
>> I have the Cleveland static ports, they have a 6 to 8 kt error,
>> directly compared to others while formation flying.
>> Sam
>> rv(at)thelefflers.com wrote:
>>> SafeAir has a solution that should work.
>>> What's on my Cherokee is the same valve as the fuel drain.
>>>> From: John Ackerman <johnag5b(at)cableone.net>
>>>> Date: 2007/10/25 Thu AM 09:07:59 EST
>>>> To: rv10-list(at)matronics.com
>>>> Subject: Re: Re: Static ports
>>>> Does anybody have a source for a valve that will open the static
>>>> system (1/4" Tygothane plastic tubing in our case) to cabin air?
>>>> normal position would be "closed" of course, so that the static
>>>> system is only open to the static ports. Alternate position would
>>>> be open to the cabin OR to both the cabin and the static ports.
>>>> I'd like to mount one on the far right side of the panel, but
>>>> can't seem to track down a suitable valve.
>>>> Any leads will be greatly appreciated.
>>>> John and Marlys Ackerman
>>>> 40458 "finishing"
>>>> On Oct 25, 2007, at 4:05 AM, Tim Olson wrote:
>>>>> One pair works fine. What you really want is ALTERNATE static in
>>>>> the cockpit, as a pilot-controllable item. Your friend is
>>>>> right about the tubing routing, however. An alternate static can
>>>>> be installed many ways, but it's just a way of opening the static
>>>>> line from inside the cockpit.
>>>>> Tim
>>>>> AirMike wrote:
>>>>>> I was told that I should put an extra set (making 4) static ports
>>>>>> with two dedicated to the TruTrak autopilot. My A&P friend told
>>>>>> me to
>>>>>> rig each set with the ports on each side of the tail cone and the
>>>>>> connection fittings arching over the top of the tail cone. this arch
>>>>>> prevents water from accumulating in the fittings.
>>>>>> -------- OSH '08 or Bust
>>>>>> Read this topic online here:
>>>>>> http://forums.matronics.com/viewtopic.php?p=141648#141648
joe(at)mile-high-aviation Guest
Tim Olson
Posted: Thu Oct 25, 2007 10:05 am Post subject: Static ports |
Looks like we're going to be blasted by a spammer here.
I see not only do we get the all-caps post, but now we
get more unrequested product info, and I got a personal
email of the same, obviously a harvested address.
When will people learn that this is a sure-fire way
to lose chances at business?
James Hein wrote:
Joe,
I think your CAPS LOCK is stuck on. Perhaps you might want to list a
new keyboard?
Humor intended.
Mile High Aviation wrote:
> <joe(at)mile-high-aviation.com>
> PLEASE CHECK OUT WWW.MILE-HIGH-AVIATION.COM FOR ALL YOUR PILOT AND
> AIRCRAFT
> SUPPLY NEEDS. IF IT IS NOT LISTED I CAN ORDER IT.. NEW PRODUCTS LISTED
> EVERY
> HOUR.
> 401-228-6677
Tim Olson
Posted: Thu Oct 25, 2007 10:21 am Post subject: Static ports |
Joe, if you're legit, why spam everyone one every list and everyone to
their personal emails as well, AND, at the bottom of the email, you
don't even have a valid and legitimate Unsubscribe link.
This is the kind of thing that will bring you a very bad name.
Also, nice that you know enough to be "Joe AT mile-high-aviation.com"
to try to keep YOUR name off the spammer's lists, but when YOU'RE
the spammer, you'll harvest them all. Joe(at)mile-high-aviation.com
This kind of business posting isn't the kind people are looking for.
LMAO.. Thanks for the information.. I will list one today. If any of you
need ANY product please give me an email or call I will gladly help.. and my
prices are not to be beaten.
Joe AT mile-high-aviation.com 401-228-6677
rvbuilder(at)sausen.net Guest
Posted: Thu Oct 25, 2007 10:31 am Post subject: Static ports |
Yep, I'll never use them. I shot an email to Matt and I suggest others do also so he get's banned before we get much more. I also submitted the domain to my blacklist providers.
acs(at)acspropeller.com.a Guest
Posted: Thu Oct 25, 2007 12:37 pm Post subject: Static ports |
In Australia, Tc'd or otherwise a set of balanced static ports satisfies the
requirement for alternate air ( IFR). It would surprise me if we didn't copy
that info from the FAR's somewhere.
John 40315
deej(at)deej.net Guest
Posted: Thu Oct 25, 2007 12:48 pm Post subject: Static ports |
Tim Olson wrote:
Tim, I couldn't agree more. When I saw the first posting, I was a bit
annoyed. When I saw that a few other mailing lists that I am on also
got spammed by the same message, I got downright ticked off. Joe, or
whomever you might really be, this is definitely one way to ensure you
won't get any business from the people on these mailing lists. SPAM ==
EVIL. Please stop.
-Dj
Kellym
Posted: Thu Oct 25, 2007 7:02 pm Post subject: Static ports |
Who says you have to build to part 23 requirements? CAR3 didn't require
either one, and neither does Part 91. From what I see, as long as you
meet Part 91 requirements you are good to go. I flew a CAR3 plane IFR
for years without alt static and with plain old copper tube pitot . My
Mooney has heated pitot, but no alternate static, and is IFR certified.
As long as the static source is as called for on the RV-10 with a port
on each side and connecting tube arching up to top of fuselage, it will
take an awful lot to block both ports.
GRANSCOTT(at)aol.com wrote:
| Quote: | In a message dated 10/25/2007 9:52:30 A.M. Central Daylight Time,
Tim(at)MyRV10.com writes:
You need a heated pitot tube (FAR 23.1323d) and an alternate static
source (FAR 23.1325 (b)(3)) for IFR flight. Wonder how many
people building an IFR aircraft are taking this into consideration...
Tim,
Hard to break the face plate on the VSI as an alternate static air if
you have all glass!
Patrick
See what's ne
KCHD |
dlm46007(at)cox.net Guest
Posted: Thu Oct 25, 2007 7:43 pm Post subject: Static ports |
If you want alternate static air and have an EFIS, use a curtiss valve on
the panel into an AN female pipe thread T fitting. This will allow nylon
pipe thread to standard nylon lines into the static system. See attached
picture. See the valve to the left of the Chelton PFD.
543.45 KB |
1008 Time(s) |
darnpilot(at)aol.com Guest
Posted: Fri Oct 26, 2007 2:40 am Post subject: Static ports |
Very nice panel. One question: your switches and cb's seem kind of random...how did you determine what you wanted where? I would have thought the switches would be grouped together and the cb's all together too?
That said, I really like it. Thanks for the photo.
Jeff
hotwheels
Posted: Fri Oct 26, 2007 8:26 am Post subject: static ports |
check the blue fitting
125.85 KB |
399 Time(s) |
