rlaird
Posted: Fri Oct 26, 2007 11:05 am Post subject: Ivo Props |
Once I had to replace a blade on my Ivo... the replacement blade was sent back with a document that said in big letters, "don't use this prop without the spacer blocks!" or something to that effect.
-- R
On 10/26/07, Eugene Zimmerman <ez(at)embarqmail.com (ez(at)embarqmail.com)> wrote:[quote] --> Kolb-List message posted by: Eugene Zimmerman <ez(at)embarqmail.com (ez(at)embarqmail.com)>
IVO users,
In my opinion Lucien is right about the risks involved in running an
IVO without the filler blocks installed.
Here is why I believe it is unsafe.
When the bolts are tightened the two bolts without the spacer blocks
will cause the aluminum faceplate to warp. This distortion of the
face plate compromises the "uniform" clamping pressure on the prop
blade root. As Lucien said this distortion can be prevented by
stacking washers of the same thickness as the blade root.
If you do decide to run a two blade IVO without the spacer blocks or
washers, do your lawyer a favor. Make certain you first get a signed
approval document from IVO .
Gene
On Oct 26, 2007, at 10:05 AM, lucien wrote:
Quote: | --> Kolb-List message posted by: "lucien" <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)>
jindoguy(at)gmail.com wrote:
> Lucien, Unless someone at 1-800-367-7767 gets a charge out of
> answering the phone, "Ivo Prop", and somehow knew it was Ron I was
> going to be asking for, I'm pretty sure it was the right number.
> Rick
Quote: | Well regardless of what they told you, the hub if run with 2 blades
and no other support in the gaps WILL dramatically increase the
likelihood of a very expensive and possibly dangerous accident.
Again, the hub secured only with 2 blade roots is NOT strong enough
to hold together reliably under the normal conditions of usage in
flight. Do NOT try to fix this by torquing the remaining bolts down
more than 200 in/lbs, or by installing and torquing the other two
bolts with no support in the gap!
Again, do NOT ask me why I know this, tho I will merely say that
I've verified this danger first-hand!
You can correct this partially, like I said, with stacks of wide AN
washers as thick as the gap secured by the other two bolts to the
specified torque (200 in/lbs) as a field repair. But the overall
strength of the hub is still compromised somewhat and it really
shouldn't be run like that all the time.
The bumbers, though, do result in a fully secured hub with no
worries and the prop works great thus properly assembled...
Caveat Emptor!
LS
LS
FS II
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Fri Oct 26, 2007 11:47 am Post subject: Re: Ivo Props |
One last thing on this, the last time I read the documentation (such as it is) for the IVO, there was an explicit statement in there that the bumper blocks were needed in the 2-blade config and that it should not be used without it.
If you do try it, you should be able to hear the results as you approach full power. If you miss that queue (and it's unmistably loud) and manage to get off the ground, you might end up using the BRS in short order......
Don't mean to harp on this but I don't want even the _suggestion_ that this _might_ be safe to go uncountered.....
Ok I'm done as I believe this horse is dead by now....
LS
_________________ LS
Titan II SS |
gaman(at)att.net Guest
Posted: Fri Oct 26, 2007 1:13 pm Post subject: Ivo Props |
Let me add one comment before this horse dies.Regarding damage to IVO props in particular.Had a antenna fail and the prop caught the whip as it was leaving the scene.About a 3/16 dent in the leading edge of one blade under the metal taped section. IVO said remove tape,sand dent smooth; clean with acetone,fill with epoxy (JB Weld) after cured,sand with block reapply new tape.That was 3yrs,150 hrs ago.
IVO said I could send it in but that is how they would fix it as well.Could you not repair a Warp or Powerfin this way?
lucien <lstavenhagen(at)hotmail.com> wrote:[quote] --> Kolb-List message posted by: "lucien"
One last thing on this, the last time I read the documentation (such as it is) for the IVO, there was an explicit statement in there that the bumper blocks were needed in the [quote][b]
d-m-hague(at)comcast.net Guest
Posted: Fri Oct 26, 2007 1:26 pm Post subject: Ivo Props |
At 05:12 PM 10/26/2007, gary aman wrote:
Quote: | Let me add one comment before this horse dies.Regarding damage to IVO
The powerfin props have a foam core, so a relatively small undetected crack
could seriously compromise the strength of the thin load bearing skin...
which is what apparently happened to the pilot I knew. The same size
damage would have less effect on a solid prop, which is what I presume Ivo
and Warp props are.
-Dana
But do you trust the _government_ with semi-automatic assault rifles?
herbgh
Posted: Fri Oct 26, 2007 4:02 pm Post subject: Ivo Props |
Gene
When I ran two bladed IVO ..I used a really thick faceplate
washer---5/8th inch thick...... I then took care to do the final torque
on the blade bolts first and then torque the two bolts in the empty
spaces next..
Not enough hours,100 or so, for a scientific study...but had no
problems ...
By the way....anyone with a two blade hub for GSC? I have two left
hand tractor blades...64 inch Herb
On Fri, 26 Oct 2007 13:21:37 -0400 Eugene Zimmerman <ez(at)embarqmail.com>
writes:
IVO users,
Gene
JetPilot
Posted: Sat Oct 27, 2007 1:52 pm Post subject: Re: Ivo Props |
gaman(at)att.net wrote: |
First, my warp drive has nickel leading edges, so damage would have been far less, and it would have gotten me home.
Second, with what these airplanes cost, I would much rather spend 200 bucks for a new blade than try to repair an old one, I would always wonder if it would fail in flight. A prop failure usually results in total disaster, so I would have not enjoyed the 3 years and 150 hours flying on a repaired prop.
A new blade for the warp drive is around 200 bucks when all is said and done. If 200 dollars for a new blade is a reason to use a substandard prop, then you probably are to poor to fly safely.
Kolb MK-III Xtra, 912-S |
Posted: Sun Oct 28, 2007 10:02 am Post subject: Ivo Props |
Yea your right,why use common sense when you can throw money at it.Works for the government.
JetPilot <orcabonita(at)hotmail.com> wrote:[quote] --> Kolb-List message posted by: "JetPilot"
First, my warp drive has nickel leading edges, so damage would have been far less, and it would have gotten me [quote][b]
planecrazzzy Guest
Posted: Sun Oct 28, 2007 11:04 am Post subject: Re: Ivo Props |
I've fixed chips/nicks in IVO's ...two different ways....
One way was ...Superglue & Baking Soda.....
Another way was , I cut some fiberglass matting.....Chopped it up...
Mixed it with the Fiberglass resin & Hardener....
Both process were sanded smooth after hardened....
Never had a problem with any repairs....
Gotta Fly...
Mike & "Jaz" in MN
JetPilot
Posted: Sun Oct 28, 2007 3:36 pm Post subject: Re: Ivo Props |
Its not a matter of repairing your prop or not, its a matter of the prop not comming apart in flight when something bigger hits it ( Like a Muffler ). Your reasoning of using an IVO because it is repairable and might save you a couple hundred dollars is very poor judgement.
Just a couple months ago, a kolb went down when the oil cap hit the prop and the resulting prop damage caused the pilot to land, and flip the plane. Had that been a warp drive, it would have not been an emergency, no off airport landing, and a much better and cheaper outcome.
There is just as much a chance that something bigger could depart the plane and the warp would stay together where the IVO comes apart.
Its a safety issue, not " throwing money at it ".
planecrazzzy Guest
Posted: Sun Oct 28, 2007 5:16 pm Post subject: Re: Ivo Props |
If your muffler goes thru your prop.....???
Oh , that's good...
We must be talking about "Blind" no preflighting, Pilots now....
I was only talking about how I fixed a few nicks....
Had NOTHING to do with why I bought the prop....
What'a maroon...
ElleryWeld(at)aol.com Guest
Posted: Sun Oct 28, 2007 7:34 pm Post subject: Ivo Props |
In a message dated 10/28/2007 6:37:39 PM Eastern Standard Time, orcabonita(at)hotmail.com writes:
Quote: | Just a couple months ago, a kolb went down when the oil cap hit the prop and the resulting prop damage caused the pilot to land, and flip the plane. Had that been a warp drive, it would have not been an emergency, no off airport landing, and a much better and cheaper outcome. |
Hold on a min the 1st mistake was the pilot was to blame when he didn't tighten or check the oil cap on preflight
2nd the pilots poor judgment with an emergency landing is what caused the plane to flip no matter what Prop he had the results would have been the same
the way I see it anyhow
Delete button ready for your response
Ellery in Maine
possums(at)bellsouth.net Guest
Posted: Sun Oct 28, 2007 8:03 pm Post subject: Ivo Props |
At 11:33 PM 10/28/2007, you wrote:
Quote: | In a message dated 10/28/2007 6:37:39 PM Eastern Standard Time, orcabonita(at)hotmail.com writes: Just a couple months ago, a kolb went down when the oil cap hit the prop and the resulting prop damage caused the pilot to land, and flip the plane. Had that been a warp drive, it would have not been an emergency, no off airport landing, and a much better and cheaper outcome.
the way I see it anyhow |
I don't know how many of you guys have really had stuff fall off and come thru your prop.
I fly a Warp Drive and little things, like muffler springs, don't seem to matter - later on you
land and there is a nick in your prop, so what. Any body that has had a "big chunk" knocked out
of their prop knows that they are about to have the ride of their life!
Shake&Bake ,... doesn't even begin to describe what happens at "normal throttle" settings
when you lose a chunk of even "one" blade. I've seen cages cracked after just seconds of full power
settings with a damaged prop. I've listened to my friends tell me that they could not even reach
the kill switch because things were shaking so bad.
I'll be honest - I think a loose oil cap could put you down on take off with full power
even with a Warp. [quote][b]
apilot(at)webtv.net Guest
Posted: Mon Oct 29, 2007 8:05 am Post subject: Ivo Props |
Safety wire is good, nylon electrical ties are good, tape is fair, silicon will hold some things and nlyon string is handy. Some A&Ps have looked at my Suzuki 3 banger and just shook their head. But, everything seems to stay on. I have learned lately that to fly my Kolb in cold weather, it is a good idea to cover about a third of the old Geo Metro radiator. Otherwise, the water temp gets too low and it does not produce peak power. It would be nice to invent something like a cowl flap to control the amount of outside air to the radiator.
Posted: Mon Oct 29, 2007 8:21 am Post subject: Ivo Props |
I drilled a little hole in the oil cap and the radiator cap and made a loop around the neck so that it will turn and come off, but it is never loose to where it can depart the scene.
Sent: Sunday, October 28, 2007 9:04 PM
Subject: Re: Re: Ivo Props
jindoguy(at)gmail.com Guest
Posted: Mon Oct 29, 2007 8:31 am Post subject: Ivo Props |
Vic, Check out how the 18 wheeler guys do it. They have zippered, window blind and venetian blind type radiator covers. the window blind and venetian blind are cable controlled from the cab. Shouldn't be that difficult to make something similar.
Rick
On 10/29/07, Vic Gibson <apilot(at)webtv.net (apilot(at)webtv.net)> wrote:[quote] --> Kolb-List message posted by: "Vic Gibson" <apilot(at)webtv.net (apilot(at)webtv.net)>
biglar
Posted: Mon Oct 29, 2007 2:21 pm Post subject: Ivo Props |
Vic, take a look at heating/air conditioning registers with the
close-able louvers. May be somewhat heavy, but a lever and push/pull
cable shouldn't be too hard to rig. Lar.
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Mon Oct 29, 2007 3:05 pm Post subject: Ivo Props |
Mike,
I just shared an experience I had with an IVO and IVO's response to my inquiry about having it repaired.I don't run a IVO because it's repairable.I run it because it is the only 3 blade that meets the mass inertia limits of a B box.Small injuries like the one I described,might well be repairable.It doesn't take a muffler to destroy any prop,a 3oz spring will do.As for the rest of your assumptions,assume away.
Kolb MK-III Xtra, [quote][b]
Dennis.Kirby(at)kirtland. Guest
Posted: Wed Oct 31, 2007 8:01 am Post subject: Ivo Props |
ElleryWeld wrote: << the 1st mistake was the pilot was to blame when he
didn't tighten or check the oil cap on preflight >>
Agree. I like to think I will perform better preflights in the future.
<< 2nd the pilots poor judgment with an emergency landing is what caused
the same >>
Aw, geez, Ellery - now my feelings are hurt, Amigo!
In retrospect, here's how I summarized the outcome of my "mud flats
landing" event last July: Every emergency is different, and you almost
never know what the outcome might be, due to all the possible variables.
For my case, when the oil cap went thru the prop, I was getting a
vibration from the engine due to the damaged prop blade. My choices
were: 1) try to fly 20 miles back to my home airport (nearest airport),
or 2) do an off-airport precautionary landing as soon as practicable.
I was over some dry lake beds at the time, so I chose to land on it.
Turns out it was muddy below the dry surface crust, so my wheels bogged
down and my Mark-III went on its back. The alternative would have been
to land on the grassy tundra-like terrain surrounding the lake beds.
But on closer inspection, that choice would have been far more
disastrous! What looked like grassy meadow from 1000' agl was in fact
very rough clump grass. I would have ended up with MUCH worse damage to
my plane - bent gear legs, bent frame, etc. There were no nearby roads
to land on, either. I'm glad I chose the lake bed to land on. Damage
was minimal.
Could I have made it back to the airport? Maybe. Maybe not. I did not
want to deal with the possibility of that prop blade failing half way
home, and the potentially disastrous result of that!
So the lesson here is, we have to make the best judgment we can based on
the circumstances apparent to us when faced with an emergency. Your
outcome may vary from the other guy's.
Meanwhile, I am beginning to look more favorably at these ultra-robust
Warp Drive props ...
Dennis Kirby
Feelings not really hurt, in
Cedar Crest, NM
lcottrell
Posted: Wed Oct 31, 2007 2:13 pm Post subject: Ivo Props |
