		John H Murphy
  Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
				 Posted: Fri Nov 02, 2007 11:38 am    Post subject: Replacing aluminum panel - with 6061T6 |
				I'm installing a EIS to replace the altimeter, cgt, & egt on my FS.
 Aircraft Spruce has aluminum called 6061T6 in 2x2 sheets. Would this do the trick for a replacement panel?
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jindoguy(at)gmail.com Guest
				 Posted: Fri Nov 02, 2007 4:40 pm    Post subject: Replacing aluminum panel - with 6061T6 |
				John, 6061-T6 is a good grade of aluminum, about 20% less tensile as 2024-T3, but much better corrosion resistance. It'll make a fine panel.
 Rick
 On 11/2/07,  John H Murphy <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)> wrote:[quote] --> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)>
		rowedenny(at)windstream.n Guest
				 Posted: Fri Nov 02, 2007 8:49 pm    Post subject: Replacing aluminum panel - with 6061T6 |
				Yep.
