John H Murphy
Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
Posted: Fri Nov 02, 2007 11:38 am Post subject: Replacing aluminum panel - with 6061T6 |
I'm installing a EIS to replace the altimeter, cgt, & egt on my FS.
Aircraft Spruce has aluminum called 6061T6 in 2x2 sheets. Would this do the trick for a replacement panel?
jindoguy(at)gmail.com Guest
Posted: Fri Nov 02, 2007 4:40 pm Post subject: Replacing aluminum panel - with 6061T6 |
John, 6061-T6 is a good grade of aluminum, about 20% less tensile as 2024-T3, but much better corrosion resistance. It'll make a fine panel.
Rick
On 11/2/07, John H Murphy <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)> wrote:[quote] --> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)>
rowedenny(at)windstream.n Guest
Posted: Fri Nov 02, 2007 8:49 pm Post subject: Replacing aluminum panel - with 6061T6 |
Yep.
