Dana
Posted: Tue Jan 01, 2008 8:46 pm Post subject: Cuyuna oil ratio, injection |
OK, so I'm using 40:1 oil ratio (Pennzoil air-cooled oil) per the Cuyuna
ULII-02 manual. However, I'm toying with the idea of installing an
automatic oil mixer made by OMC (Evinrude). The "Accu-Mix R" goes in the
fuel line, and is pulse driven, unlike the Rotax gear driven oil injection
systems, so it can be adapted to any engine. The only thing is, it's fixed
at 50:1 ratio. Some people say the lighter oil ratio is OK with modern
oils, but I dunno... I like the Pennzoil, it's not a modern synthetic oil
but it's kept my paramotor engine happy for well over 300 hours... but I
also like the idea of flying to another airport and being able to refuel
without the hassle of calculating and mixing oil, and also not worrying
about the age of the premix.
So, whatcha think? 50:1 OK? Need to alter the jetting? Or is there
another aftermarket oil injection alternative for the Cuyuna?
-Dana
Assassins do it from behind.
apilot(at)surewest.net Guest
Posted: Tue Jan 01, 2008 9:05 pm Post subject: Cuyuna oil ratio, injection |
You can't beat Penns Oil as long as it does not sit for a year or so and coagulate. Evenrude knows what they are doing too, but they tend to lean toward water cooled engines.
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Wed Jan 02, 2008 12:11 am Post subject: Cuyuna oil ratio, injection |
Hi Dana,
I have a 430 Cuyuna on a Maxair Drifter and am running it at 50:1. I work as
a boat mechanic for an formerly OMC now BRP dealership and have installed
the Accumix system on a number of boats. They were mostly used for the
trolling motors to allow tapping in to the main fuel system of an I/O drive.
The Accumix works ok but maybe a little fragile for this application. I have
seen allot of them leak at the bottom usually because the plastic mixer
housing has cracked.
A new Accumix tank is allot more expensive now up to a couple hundred
dollars or so from the past.
BRP does offer an Mixing cup and it is graduated in a number of ratios and
varying fuel quantities. It holds about a pint and has a blue lid for
keeping the bugs & dust out. I think it runs about 3 bucks.
The Rotax engine driven oil pump works pretty good and they are also used
on the late 80's and early 90's Mercury 2cycle Outboards. The problem is
adapting the pump to the Cuyuna.
Hope this helps
Carlos G
AKA
BaronVonEvil
Dana
Posted: Wed Jan 02, 2008 3:54 am Post subject: Cuyuna oil ratio, injection |
At 03:10 AM 1/2/2008, Carlos wrote:
| Quote: | The Accumix works ok but maybe a little fragile for this application. I
have seen allot of them leak at the bottom usually because the plastic
mixer housing has cracked.
Thanks Carlos,
Do you know how long they were in service before they started
leaking? Does leaking mean a failure to deliver oil or just a leak? For
obvious reasons I'm more concerned about a sudden failure than a slow leak
that can be attended to.
An aircraft might not be as tough an environment, not getting the constant
pounding of a boat in the waves... but OTOH it would be constantly running,
not just occasionally as if it were just the trolling motor. Also do you
know if the small Mikuni fuel pump has enough pressure? (I know the mixers
need an Evinrude high volume pump or something like that.)
I can get one, brand new, for $50, from a guy who bought it (for his plane)
but never installed it.
-Dana
Hit any key. With what?
The BaronVonEvil
Posted: Wed Jan 02, 2008 10:39 am Post subject: Cuyuna oil ratio, injection |
Hi Dana,
I couldnt tell you how long it was before the accumix had problems as not
many customers tracked their boat operating time. I would guess calendar
wise maybe a couple of years.
The way they usually failed was to leaking around the fittings at the bottom
of the tank . Another failure mode was to start adding too much oil to the
fuel,usually indciated by too much smoke, fouling plugs.
I haven't seen one fail do to lack of oil but if the tank starts leaking oil
it would be easier to suck air than oil through the lines. I dont know if
the Mikini Fuel pump is adequate for the accumix.
Dana, I would be reluctant to bet my engine and my butt with an accumix
onboard my aircraft is what Im saying. As always the choice is up to you.
Happy New Year
Carlos G.
Dana
Posted: Thu Jan 03, 2008 5:04 am Post subject: Cuyuna oil ratio, injection |
At 01:38 PM 1/2/2008, Carlos wrote:
The way they usually failed was to leaking...<snip>...I would be reluctant
to bet my engine and my butt with an accumix onboard my aircraft...
Thanks Carlos, that's the kind of information I needed. Everything else
I've heard was of the "I knew a guy who heard from a guy who..." nature. I
think I will go with my original plan of premix, and a calibrated third
tank so I can accurately determine how much fuel I'm pumping.
-Dana
OK, I'm weird! But I'm saving up to be eccentric.
Posted: Thu Jan 03, 2008 6:22 am Post subject: Cuyuna oil ratio, injection |
I
| Quote: | think I will go with my original plan of premix, and a calibrated third
-Dana
Dana:
I am glad you made that decision.
Back in the 80's, I was very fortunate to be able to do a lot of long
distance cross country flying in my 447 powered Fire Star. I never
considered any other method but pre-mix or mix in the tank. That's all that
was available.
Each extended trip started out with 3 gals of Pennzoil in 1 quart
containers, along with my camping gear and personal gear. Doesn't take long
to become very good at estimating fuel burn when flying cross country, using
the hour meter and a fuel burn of 3.5 to 3.75 gph. I dumped the oil in the
tank first, grabbed a lift strut to roll the FS back and forth to mix the
oil and gas, then filled the tank. Never had a fuel/oil mix ratio problem
that I could determine in many hours of cross country flying.
At home it was a no brainer because I fueled out of 5 gal cans.
With this method of fueling and mixing oil I was able to fly in all the
States east of the Mississippi and some west of the Mississippi River. We
also got into Canada far enough to say we had flown over Canadian soil, but
never attempted to land there.
mkIII - 15F at hauck's holler, alabama
_________________ John Hauck
Titus, Alabama |
rowedenny(at)windstream.n Guest
Posted: Thu Jan 03, 2008 7:39 am Post subject: Cuyuna oil ratio, injection |
| Quote: | john h
Crap,
Thats what the temp here in western PA is this morning! I did not think it
ever got that cold in the deep South.
Dennis Rowe
a58r(at)verizon.net Guest
Posted: Thu Jan 03, 2008 11:56 am Post subject: Cuyuna oil ratio, injection |
Think it was +15F, not -15F at Hauck's Hollow...a hyphen vs. a minus
regards,
Bob N. FireFly 070 Old Kolb
Posted: Thu Jan 03, 2008 1:54 pm Post subject: Cuyuna oil ratio, injection |
Hi Grey Baron:
Felt like it anyhow.
mkIII +15F, but felt like -15F.
[quote] Think it was +15F, not -15F at Hauck's Hollow...a hyphen vs. a minus
regards,
Titus, Alabama |
