		Dana
				 Posted: Tue Jan 01, 2008 8:46 pm    Post subject: Cuyuna oil ratio, injection |
				OK, so I'm using 40:1 oil ratio (Pennzoil air-cooled oil) per the Cuyuna
 ULII-02 manual.  However, I'm toying with the idea of installing an
 automatic oil mixer made by OMC (Evinrude).  The "Accu-Mix R" goes in the
 fuel line, and is pulse driven, unlike the Rotax gear driven oil injection
 systems, so it can be adapted to any engine.  The only thing is, it's fixed
 at 50:1 ratio.  Some people say the lighter oil ratio is OK with modern
 oils, but I dunno... I like the Pennzoil, it's not a modern synthetic oil
 but it's kept my paramotor engine happy for well over 300 hours... but I
 also like the idea of flying to another airport and being able to refuel
 without the hassle of calculating and mixing oil, and also not worrying
 about the age of the premix.
 So, whatcha think?  50:1 OK?  Need to alter the jetting?  Or is there
 another aftermarket oil injection alternative for the Cuyuna?
 -Dana
   Assassins do it from behind.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		apilot(at)surewest.net Guest
				 Posted: Tue Jan 01, 2008 9:05 pm    Post subject: Cuyuna oil ratio, injection |
				You can't beat Penns Oil as long as it does not sit for a year or so and coagulate.  Evenrude knows what they are doing too, but they tend to lean toward water cooled engines.
		The BaronVonEvil
  Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
				 Posted: Wed Jan 02, 2008 12:11 am    Post subject: Cuyuna oil ratio, injection |
				Hi Dana,
 I have a 430 Cuyuna on a Maxair Drifter and am running it at 50:1. I work as
 a boat mechanic for an formerly OMC now BRP dealership and have installed
 the Accumix system on a number of boats. They were mostly used for the
 trolling motors to allow tapping in to the main fuel system of an I/O drive.
 The Accumix works ok but maybe a little fragile for this application. I have
 seen allot of them leak at the bottom usually because the plastic mixer
 housing has cracked.
 A new Accumix  tank is allot more expensive now up to a couple hundred
 dollars or so from the past.
 BRP does offer an Mixing cup and it is graduated in a number of ratios and
 varying fuel quantities. It holds about a pint and has a blue lid for
 keeping the bugs & dust out.  I think it runs about 3 bucks.
 The Rotax engine driven oil pump works pretty good and they are also used
 on the late 80's and early 90's  Mercury 2cycle Outboards.  The problem is
 adapting the pump to the Cuyuna.
 Hope this helps
 Carlos G
 AKA
 BaronVonEvil
		Dana
				 Posted: Wed Jan 02, 2008 3:54 am    Post subject: Cuyuna oil ratio, injection |
				At 03:10 AM 1/2/2008, Carlos wrote:
  	  | Quote: | 	 		  The Accumix works ok but maybe a little fragile for this application. I
 have seen allot of them leak at the bottom usually because the plastic
 mixer housing has cracked.
 Thanks Carlos,
 Do you know how long they were in service before they started
 leaking?  Does leaking mean a failure to deliver oil or just a leak?  For
 obvious reasons I'm more concerned about a sudden failure than a slow leak
 that can be attended to.
 An aircraft might not be as tough an environment, not getting the constant
 pounding of a boat in the waves... but OTOH it would be constantly running,
 not just occasionally as if it were just the trolling motor.  Also do you
 know if the small Mikuni fuel pump has enough pressure?  (I know the mixers
 need an Evinrude high volume pump or something like that.)
 I can get one, brand new, for $50, from a guy who bought it (for his plane)
 but never installed it.
 -Dana
   Hit any key. With what?
		The BaronVonEvil
				 Posted: Wed Jan 02, 2008 10:39 am    Post subject: Cuyuna oil ratio, injection |
				Hi Dana,
 I couldnt tell you how long it was before the accumix had problems as not
 many customers tracked their boat operating time. I would guess calendar
 wise maybe a couple of years.
 The way they usually failed was to leaking around the fittings at the bottom
 of the tank . Another failure mode was to start adding too much oil to the
 fuel,usually indciated by too much smoke, fouling plugs.
 I haven't seen one fail do to lack of oil but if the tank starts leaking oil
 it would be easier to suck air than oil through the lines. I dont know if
 the Mikini Fuel pump is adequate for the accumix.
 Dana, I would be reluctant to bet my engine and my butt with an accumix
 onboard my aircraft is what Im saying.  As always the choice is up to you.
 Happy New Year
 Carlos G.
		Dana
				 Posted: Thu Jan 03, 2008 5:04 am    Post subject: Cuyuna oil ratio, injection |
				At 01:38 PM 1/2/2008, Carlos wrote:
 The way they usually failed was to leaking...<snip>...I would be reluctant
 to bet my engine and my butt with an accumix onboard my aircraft...
 Thanks Carlos, that's the kind of information I needed.  Everything else
 I've heard was of the "I knew a guy who heard from a guy who..." nature.  I
 think I will go with my original plan of premix, and a calibrated third
 tank so I can accurately determine how much fuel I'm pumping.
 -Dana
   OK, I'm weird! But I'm saving up to be eccentric.
				 Posted: Thu Jan 03, 2008 6:22 am    Post subject: Cuyuna oil ratio, injection |
				I
  	  | Quote: | 	 		   think I will go with my original plan of premix, and a calibrated third
  -Dana
 Dana:
 I am glad you made that decision.
 Back in the 80's, I was very fortunate to be able to do a lot of long
 distance cross country flying in my 447 powered Fire Star.  I never
 considered any other method but pre-mix or mix in the tank.  That's all that
 was available.
 Each extended trip started out with 3 gals of Pennzoil in 1 quart
 containers, along with my camping gear and personal gear.  Doesn't take long
 to become very good at estimating fuel burn when flying cross country, using
 the hour meter and a fuel burn of 3.5 to 3.75 gph.  I dumped the oil in the
 tank first, grabbed a lift strut to roll the FS back and forth to mix the
 oil and gas, then filled the tank.  Never had a fuel/oil mix ratio problem
 that I could determine in many hours of cross country flying.
 At home it was a no brainer because I fueled out of 5 gal cans.
 With this method of fueling and mixing oil I was able to fly in all the
 States east of the Mississippi and some west of the Mississippi River.  We
 also got into Canada far enough to say we had flown over Canadian soil, but
 never attempted to land there.
 mkIII - 15F at hauck's holler, alabama
  _________________ John Hauck
Titus, Alabama |
		rowedenny(at)windstream.n Guest
				 Posted: Thu Jan 03, 2008 7:39 am    Post subject: Cuyuna oil ratio, injection |
				 	  | Quote: | 	 		   john h
  Crap,
 Thats what the temp here in western PA is this morning!  I did not think it
 ever got that cold in the deep South.
 Dennis Rowe
		a58r(at)verizon.net Guest
				 Posted: Thu Jan 03, 2008 11:56 am    Post subject: Cuyuna oil ratio, injection |
				Think it was +15F, not -15F at Hauck's Hollow...a hyphen vs. a minus
  regards,
 Bob N.    FireFly 070 Old Kolb
				 Posted: Thu Jan 03, 2008 1:54 pm    Post subject: Cuyuna oil ratio, injection |
				Hi Grey Baron:
  Felt like it anyhow.
  mkIII +15F, but felt like -15F.
  [quote]    Think it was +15F, not -15F at Hauck's    Hollow...a hyphen vs. a minus
       regards,
Titus, Alabama |
