poneill(at)irealms.com Guest
Posted: Sun Jan 06, 2008 7:47 pm Post subject: Kitplane's article, Ly-Con's case closed. |
I haven’t decided on a primer yet. I’m still in the process of tearing it down so that I can alodine it.
Best Regards,
Patrick #40714 / N690CT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Sunday, January 06, 2008 12:02 PM
Subject: Re: Kitplane's article, Ly-Con's case closed.
This has turned out to be another great alternative engine war. Anybody care to offer opinions on the best primer to use on the outside of the engine, alternative or otherwise?
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 6, 2008, at 2:42 PM, LES KEARNEY wrote:
Peter
As I mntioned in my post to Kelly, I am not an engine expert / guru / authority by any stretch. Below is an exract from Ross Farnham's website: http://www.sdsefi.com/air7.html
Many lay people often point out that automotive engines are not designed for continuous high output applications and will blow up when installed in an aircraft. This view is a result of complete ignorance in my opinion and is not supported by any credible facts. Modern automotive engines make use of the latest advances in computer design and modeling to optimize the design of everything from port flow, port resonance tuning, combustion chamber characteristics, vibrational node analysis and mechanical stresses. Machining and metallurgy technology is far superior to the old days when the air cooled, flat engines were developed. Technology has indeed progressed on automotive engines in the last 40 years.
Automotive engines are routinely tested during development at full power and maximum rpm for periods of up to 1200 hours on a dynomometer. These engines must be able to withstand whatever stresses a customer might inflict on them such as flat out cruising on the autobahn or endurance racing, without failure. Manufacturer's limits are conservative to guarantee longevity and reliability. The engineering and capital investment that goes into a new engine release dwarfs any similar development by any piston aircraft engine manufacturer. The testing and validation methods FAR exceed those required on piston aircraft engines. In Europe, cars are routinely cruised at speeds (RPMs and load) 50-100% higher than what we see in North America with no ill effects in life span. This is real world, long term hard use.
Just one example of the demonstrated real world reliability on the popular Subaru EJ22 engine was the 1989 record set by 3 Legacy's at an Arizona test track. These cars were run flat out for 17 days straight without failure at an average speed of over 138 mph. Similar records have been set by Saab and Chevrolet. How many people reading this article think that most aircraft engines would survive at 100% takeoff power for 400 hours? Subaru now offers the production 2.5L turbo STI rated at 300 hp, With the popularity of showroom stock endurance racing in the last decade, we get to see just how good the design and engineering is on modern cars. Thousands of Hondas, Toyotas, Oldsmobiles, Chevrolets, Mitsubishis, VWs etc. are mercilessly flogged to the rev limiter at full throttle for hundreds of hours between rebuilds. A very small fraction of these ever suffer a serious failure. Aircraft use does not put this kind of cyclic stress on an engine, being a constant load, relatively low rpm situation. Most modern car engines outlast the chassis without ever being removed. This performance can be equated into lifespans of between 4000 and 8000 hours. Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use.
Cheers
Les
simon(at)sertech.com.au Guest
Posted: Mon Jan 07, 2008 1:22 am Post subject: Kitplane's article, Ly-Con's case closed. |
I have been reading the engine debate with some interest. There are pros and cons to all types.
Just to stir the pot a little more!!!! have a look at this South African development.
http://www.adeptairmotive.com/site/default.asp
It hasn't even flown yet, but it is running. It has been designed from the ground up as a GA engine.
Turbocharged, 320hp at 5500 rpm, 70% 210hp at 2300 rpm, Integrated PSRU, Liquid cooled, Compatible with Avgas OR Mogas, FADEC, 130kg (287lb).
Targeted TBO is in excess of 2000 hours. The engine has a fairly oversquare bore/stroke ratio (98mm x 70mm) in order to keep piston speed low, as well as fairly short con rods Now before anybody has a go at the revs, the average piston speed is actually lower than conventional GA engines because of the oversquare setup.
It is a 120 degree V6 of 3.2 litre capacity. Real smooth.
Just for those with a little experimentation in their blood. Attached is a picture.
Simon Wilson
Description: |
Filesize: |
54.79 KB |
Viewed: |
336 Time(s) |
GRANSCOTT(at)aol.com Guest
Posted: Mon Jan 07, 2008 6:22 am Post subject: Kitplane's article, Ly-Con's case closed. |
In a message dated 1/7/2008 3:24:40 AM Central Standard Time, simon(at)sertech.com.au writes:
Quote: | Just to stir the pot a little more!!!! have a look at this South African development. | Their strategy is to price this experimental engine...unproven ...at Lycoming and Continental's current prices, because they say it will weight less than current engines. Apparently they do not intend to have it certified.
So let me understand...they want what the current certified guys want for engines, they want the experimental builders pay extra for a weight difference and the experimenal operators, take all the risk; plus they are based in a country where you can't take any legal action if this engine poops out and kills you...sounds like a deal to me...
Start the year off right. Easy ways to stay in shape in the new year.
Posted: Mon Jan 07, 2008 6:33 am Post subject: Kitplane's article, Ly-Con's case closed. |
In a message dated 1/6/2008 1:48:30 PM Central Standard Time, Kearney(at)shaw.ca writes:
Quote: |
Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use. Cheers
Les
Les,
What do you think this belief in 1000 hours is based on?
johngoodman
Posted: Mon Jan 07, 2008 7:52 am Post subject: Re: Kitplane's article, Ly-Con's case closed. |
Aaahh, Engines! If you want to get real exotic, try these:
The StarRotor Corp. Brayton cycle engine
http://www.starrotor.com/Engine.htm
The Beare Six Cycle engine
http://www.sixstroke.com/index.html
The infamous Axial Vector Engine Corp.
http://www.axialvectorengine.com/index.html
The Air Force HTRE-3 nuclear aircraft engine
http://members.tripod.com/airfields_freeman/ID/Airfields_ID_N.htm
My favorite is electric drag racing.
http://www.nedra.com/
These guys are actually breaking track records. They use electric fork lift motors with lots of batteries.......I think I'm going to need a larger battery tray than the one Van sent me.......
_________________ #40572 Phase One complete in 2011 |
apilot2(at)gmail.com Guest
Posted: Mon Jan 07, 2008 7:50 pm Post subject: Kitplane's article, Ly-Con's case closed. |
Heck you are missing the DynaCam, which IS a certified engine, that is
always going into production "next" year. Or you could totally ignore
Vans and mount up an Orenda engine that also is certified at somewhere
around 5-600hp.
n212pj(at)gmail.com Guest
Posted: Tue Jan 08, 2008 10:27 am Post subject: Kitplane's article, Ly-Con's case closed. |
Oh, gawd help me, but I cannot stop myself. Here goes.
I wrote awhile back that I'm going to stick to Ly-Con because I didn't know enough to know what questions to ask. Now, I know that was a somewhat stupid statement, especially because I could find out, given my research background, but the point was, and this verbiage below confirms it, I have no clue when enough testing is enough, or enough failures are too many. I am not an aeronautical or mechanical or anything engineer. The one thing I cannot abide are statements that say almost nothing, but sound like they have expertise. "A very small fraction of these ever suffer a serious failure." Ok then, what's the fraction and how does that compare to the current crop of Ly-Con's. What's a serious failure? What were the outcomes? Did the car quit running? Did the people slam into a concrete wall at 100 mph, because that's what an aviator would essentially do, and whomever else was onboard, and that's why the family scenario keeps coming up.
Putting an "experimental" engine into a four place aircraft is fine. As I said before I'm all for moving the bar forward. I don't know what engineering good or bad has gone into the certified Ly-Cons. I do know that the expensive certification process has kept them from easily making these engines more "advanced." The final testing that goes into the auto conversions, however, is left to those who are flying them. It was the same way when the Ly-Cons were first being put out. If the auto conversion folks put their designs through thousands of hours of testing in conditions that simulate what a real plane goes through, then fine. Show the data. Show the process. If they are doing so and I'm naive in what I'm saying, fine, correct me. But so far, the only statements I've seen are the obfuscating statements (crap, really) that I typically put into a report when I don't know the answer.
Why is one PSRU better than another? Why did Jan declare that everyone must change to the new one? Stronger? How? Is the prop/PSRU combination the issue? Was there a harmonic issuer? Was the metallurgy on the gears better? Were the gears cracking? When you check your PSRU oil, will it tell you that there's a hairline crack in a gear? How will the engine hold up if you get a coolant leak? Will it stop working or get you to a safe landing? How will you know you have a coolant leak while in flight? I am sure that all those who are becoming Subaru test pilots for free will have asked these and thousands of other questions and gotten very good answers. I haven't ever seen anyone come back with a list of these questions and the answers and posted them, but since I'm not following the postings on these lists, maybe they have. Hope so. Now, this is not to say that every and all Ly-Con's shouldn't be taken to task with the thousands of questions that an auto conversion should be, with each question answered by test results. We should all be wanting to know what's the deal. Why do Ly-Con's develop hairline cracks in their jugs after 500 hours? Etc. We have a very large number of very good engine build specialists out there with good knowledge and experience and the willingness to share information (and Ly-Con will share some test results).
I want Les to succeed. I want Jan, even though I have reservations about the person, to succeed. I want the folks from South Africa to build the best darn engine that has come along in a long long time. Just don't rely on non-critical statements. If you deal with a person who won't back up their claims with facts and thorough testing, walk away, which is what I did with Jan. And don't subject anyone else to your test bed. And, one more thing, make sure that when it fails, and it will, they all will, that the manufacturer is the type that will come, take the engine back, go over it with a fine toothed gizmo, do root cause analysis until the cows come home, and help the NTSB determine if the fault was the engine and why, and not just walk away and say it wasn't their fault. You've taken it upon yourself to be their test bed, they might as well admit to that and be part of it contractually. I know they won't, but to me, that is the reality of it and that's why I'll go the route that seems to be working. Ly-Con's with annuals. Annuals because I know the environment and how they are run are going to cause problems, eventually, sometimes sooner than later, and that's why we do annuals, not because the technology is so old or bad that we shouldn't have to need them. We do them because when our engine quits, we cannot pull off to the side of the road, we get to do what race car drivers do, we get to plow into the barrier at speeds that do not usually guarantee happy outcomes in a vehicle built out of aluminum, sans safety cage.
Les, I met you once in Oregon and have followed your comments on this list and I've always been impressed with your care and thoroughness and intelligence. Please help us all out as you go through this journey and document as much as possible, especially in terms of the questions that you have asked and the answers given. That baby is going to run smooth as silk when you first fire it up, I'm sure. But I'd be doing an annual's worth on it every 50 hours for the forseeable future, until you and the fleet of similar installations are sure you have a winner. Good luck!
John Jessen
40328.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY
Sent: Sunday, January 06, 2008 11:42 AM
Peter
Just one example of the demonstrated real world reliability on the popular Subaru EJ22 engine was the 1989 record set by 3 Legacy's at an Arizona test track. These cars were run flat out for 17 days straight without failure at an average speed of over 138 mph. Similar records have been set by Saab and Chevrolet. How many people reading this article think that most aircraft engines would survive at 100% takeoff power for 400 hours? Subaru now offers the production 2.5L turbo STI rated at 300 hp, With the popularity of showroom stock endurance racing in the last decade, we get to see just how good the design and engineering is on modern cars. Thousands of Hondas, Toyotas, Oldsmobiles, Chevrolets, Mitsubishis, VWs etc. are mercilessly flogged to the rev limiter at full throttle for hundreds of hours between rebuilds. A very small fraction of these ever suffer a serious failure. Aircraft use does not put this kind of cyclic stress on an engine, being a constant load, relatively low rpm situation. Most modern car engines outlast the chassis without ever being removed. This performance can be equated into lifespans of between 4000 and 8000 hours. Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use. Cheers
Les
Posted: Tue Jan 08, 2008 3:55 pm Post subject: Kitplane's article, Ly-Con's case closed. |
Someone pointed out to me that people might have mistaken my use of Ly-Con. I meant the Lycoming / Continental engine makers and not the rebuilders. Sorry if I didn't use this correctly.
John
Sent: Tuesday, January 08, 2008 10:00 AM
To: 'rv10-list(at)matronics.com'
Subject: RE: Kitplane's article, Ly-Con's case closed.
John Jessen
40328.
Peter
Les
Tim Olson
Posted: Tue Jan 08, 2008 4:57 pm Post subject: Kitplane's article, Ly-Con's case closed. |
John,
That was one of the most well written statements I've read
in a long time on that subject.
Keep in mind that statistics give meaning when you can
determine probabilities, and overall quantities are an
important part of that. With 100 flying Lycomings, if we
had 2 fail, we'd have 2% failure rate, right? But, consider
that the Subaru or other conversions are currently less
than 1% of the installed base of Lycomings (in RV-10's).
That means that, down the road a while as an example,
you may know 10 people who have Lycoming failures, and
perhaps 2 who have had alternative engine failures, you
really need to look at the data pool that the numbers come
from then. If we have 1000 lycomings, and 10 fail, that's 1%.
If we have 1/100th the number of Alternatives, (i.e. 10)
and we have 2 fail, then the failure rate is 20%. But, to
the public, they'll hear lots more bitching on the newsgroup
from the Lycoming crowd....simply because that's where the
larger NUMBER of failures is. From the looks of it,
even once the alternatives get flying in more quantities,
they're going to be less than 5 or 10% of the total RV-10
fleet. So, the failure rates have the possibility to
be many times larger for every failure.
Also, it's just plain not right to consider the statistical
failure rate of AUTO engines in AUTOS as the basis for
what the failure rate will be in aircraft. You absolutely
need to be operating the engines in the airframe to
get anything meaningful to go on.
That means that today, we have very very little statistical
data on the alternatives, and even in number of hours flown,
there are many many times less hours being put on them.
So, a single failure or two is very significant. One of
the large concerns I have is also that those with the
alternatives will tend to be tight-lipped about their
failures...which is understandable, but it just means that
nobody can determine the actual reliability.
Related to the question about PRSU reliability, and why
the new one is being *required*..... If they had only 2 or
3 failures, think about what that means as a portion of the
total. And then think about what that would mean if you
scaled that percentage up to the same overall quantities
as the number of lycomings flying. 2 or 3 PRSU failures
could mean 2000, or even 10,000 failures in Lycoming
quantities. Over time, there will be a trend, but until
the same unit gets lots of time on it, we'll never know.
That's the other sad thing about the alternatives. For
instance, the Subie being sold in 2008 is NOT the same as
the ones sold in 2007. So, how are people to determine
the long term reliability?
Still, it's a builders prerogative to choose their engine,
and I'm glad we have the option. The real hope is that
the alternatives can build on a design that they find
to work well, and put lots of operational time on it so
that some day it can become a larger and larger share of
the overall market. Given some high reliabilities, I
would think that many engines could be great choices, but
for today, that choice is for those who are willing to
accept a much greater share of uncertainty.
I'm also uncertain if my engine, or my engine operational
styles are going to cause me any grief down the road, but
at least there's a pretty good pool of operational data
that we can look at to give a general feel of the outlook.
John Jessen wrote:
[quote] Oh, gawd help me, but I cannot stop myself. Here goes.
sound like they have expertise. "/A very small fraction of these ever
suffer a serious failure." /Ok then, what's the fraction and how does
luck!
John Jessen
40328.
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *LES KEARNEY
*Sent:* Sunday, January 06, 2008 11:42 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Kitplane's article, Ly-Con's case closed.
Peter
/Many lay people often point out that automotive engines are not
last 40 years./
/Automotive engines are routinely tested during development at full
effects in life span. This is real world, long term hard use./
/Just one example of the demonstrated real world reliability on the
at least 1000 hours in aircraft use./
Cheers
Les
Tim Olson
Posted: Tue Jan 08, 2008 7:27 pm Post subject: Kitplane's article, Ly-Con's case closed. |
John,
That was a well-thought post.
luck!
John Jessen
40328.
