jimmieblackwell(at)austin Guest
Posted: Mon Jan 07, 2008 3:24 pm Post subject: Wing Tank Fuel Finger Strainers |
My Kitfox was originally built in 1994. So, I think it is about time to remove and check the finger strainers in the wing tanks. Has anyone on the list removed their finger strainers from the fiberglass wing tanks and if so are there any issues of concern getting the strainers out without damaging the tank threads?
Jimmie
Lynn Matteson
Posted: Mon Jan 07, 2008 6:06 pm Post subject: Wing Tank Fuel Finger Strainers |
I removed mine when I did the flush and re-kreeme job, Jimmie. I
didn't have any problem. I reinserted the finger strainers, using a
Permatex Aviation product...just can't recall the proper name of
it...some kind of gasket maker stuff.
Lynn Matteson
flying w/450+ hrs
Jimmie
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Mon Jan 07, 2008 6:40 pm Post subject: Wing Tank Fuel Finger Strainers |
At 12:36 PM 1/7/2008, you wrote:
Quote: | Has anyone on the list removed their finger strainers from the
Jimmie,
I did it repeatedly during the first 40 hours and a few more
times after trying to find a sealant that would work. You're right
about the threads and that concern prompted me to leave them in at
the last annual. The answer obviously depends on what sealant was
used to install them. If they were epoxied in, you're probably stuck
with them. (Bad pun intended.) (It's possible the brass will release
from the epoxy, but unlikely. More likely the epoxy will ball-up,
distorting the hole significantly. Nearly any other sealant should
shear before the glass and brass so you should be able to remove them
without trouble. Don't heat the tank to soften the sealant, not just
because of the gas inside, but because the vinyl-ester resin used to
make them is not intended for high temperatures.
By the way, the only sealant I've gotten to work with 100LL
is two-part polysulfide:
(http://www.aircraftspruce.com/catalog/cspages/proseal.php)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
trevorkebb(at)earthlink.n Guest
Posted: Mon Jan 07, 2008 6:54 pm Post subject: Wing Tank Fuel Finger Strainers |
Jimmie:
My '94 strainers were installed with Permaseal (Permatex?) aviation gasket
goo. I gently heated up the strainers and tank area around them with a heat
gun (no fuel in the tanks, caps off, it takes a bit of time) and the
strainers very easily came right out. Before heating they were rock solid
and I was afraid of damaging the threads. Heating would work with most
sealants I would suspect.
Hope this helps.
Robert Beck
Jimmie
wingsdown(at)verizon.net Guest
n981ms(at)yahoo.com Guest
Michel
Posted: Tue Jan 08, 2008 5:56 am Post subject: Wing Tank Fuel Finger Strainers |
While on the subject; I have no reason to believe I have problems with my finger strainers but ... it could be nice to check that are not halv cloted, right? But I don't really want to remove them. Isn't it possible to suck fuel from the refueling cap side and hold a hose close to the strainer to see if some dirty stuff of particles is being sucked? Has anyone tried that?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
Posted: Tue Jan 08, 2008 7:54 am Post subject: Wing Tank Fuel Finger Strainers |
Maybe some enterprising young man with all sorts of testing equipment
and ability...Lowell, are you listening?...could do a test of the
amount of fuel that the finger strainers will pass. Maybe using a
cut-away tank. This info could be a start towards at least gaining
some insight to what is needed for flow. Of course, if the original
builder actually DID a flow check as suggested, and that info is
available to the subsequent owner (if that is the case), this would
help. I know that there are entirely too many variables at work here,
but it'll get people thinking.
Lynn Matteson
flying w/450+ hrs
On Jan 8, 2008, at 8:46 AM, Michel Verheughe wrote:
Quote: | While on the subject; I have no reason to believe I have problems
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
pwmac(at)sisna.com Guest
Posted: Tue Jan 08, 2008 11:37 am Post subject: Wing Tank Fuel Finger Strainers |
My take is that if the gravity flow from the tank meets your needs or
the guidelines from the FAA then removal should not be necessary. Its
not rocket science. Seems like a simple test could be conducted when
the flex hose - strainer to the header is replaced annually it would
be pretty easy to do a flow test once the details are worked out of
emptying the tank refilling etc. With all that trouble then removing
and examining might be easier. I would not worry about the threads as
they can easily be repaired or the next size adapter can be used. If
the wing closeout blocks removal then mod is required to access the plumbing.
Check the archives for the unusual attitude gravity flow test
discussion. It was discussed extensively and had inputs from some
knowledgeable fuel system people.
For the guys that are in the construction phase, please do the flow
test and make the strainer accessible.
Regards, Paul
Lynn Matteson
flying w/450+ hrs
>Cheers,
>Michel Verheughe
>Norway
><pre><b><font size color="#000000" face="courier new,courier">
></b></font></pre>
msm_9949(at)yahoo.com Guest
Posted: Tue Jan 08, 2008 1:43 pm Post subject: Wing Tank Fuel Finger Strainers |
Maxwell -
The mesh in those strainers is pretty big. It's a bit like they're designed to keep mice from clogging your fuel system. If fuel is flowing freely and you're not finding smaller stuff in downstream filters/traps, it's a solid bet finger strainers are clean.
I remove and inspect mine annually with no problem. I wouldn't if it meant cutting tho. Have never found anything in them. I burn 93 octane auto.
W Duke <n981ms(at)yahoo.com> wrote:
[quote] Along this thread: Has anyone found any problems when they checked. What type of fuel do they run and at how many hours? I admit to not having checked mine. I am not sure I can get them out without cutting into the butt rib.
Maxwell [quote][b]
JimmieBlackwell(at)austin Guest
Posted: Tue Jan 08, 2008 2:54 pm Post subject: Wing Tank Fuel Finger Strainers |
Wow! Lots of good ideas here, but now I am really wondering if I might be
able to see them with some sort of mirror or small camera without removing
them. Would sure be helpful to know if anyone has found restrictions on the
strainers when they removed them and as someone else suggested a report on
kind of fuel used if a restrictions was found.
Jimmie
rzeppin(at)cox.net Guest
Posted: Tue Jan 08, 2008 4:55 pm Post subject: Wing Tank Fuel Finger Strainers |
Hi All... I'm new to the Kitfox forums, but thought I might add to the
discussion...
Harbor Freight has bore scopes for $170... It's a bit on the pricey
side, but I would imagine there are all sorts of
other uses you could find for it besides checking the finger strainers.
I would think you'd get a much
better idea on the strainers condition using a bore scope than a mirror,
but you're also looking
at a more expensive idea.
Harbor Freight has two different ones, almost a $100 difference in
price. The one for $170 is here...
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94958
It even comes with a 'periscope' attachment for looking at 90 degrees to
the axis instead of straight ahead.
Ron
Jimmie Blackwell wrote:
<JimmieBlackwell(at)austin.rr.com>
might be able to see them with some sort of mirror or small camera
without removing them. Would sure be helpful to know if anyone has
found restrictions on the strainers when they removed them and as
someone else suggested a report on kind of fuel used if a restrictions
was found.
Jimmie
Tom Jones
Posted: Tue Jan 08, 2008 8:01 pm Post subject: Re: Wing Tank Fuel Finger Strainers |
Quote: | Would sure be helpful to know if anyone has found restrictions on the
kind of fuel used if a restrictions was found. |
Jimmie, the design of finger strainers is to prevent large debris such as leaves, butterflies, someone mentioned mice, etc. from blocking the fuel port in the tank.
On the 1998 Alaska trip one of the kitfoxes made one emergency landing due to a rough running engine. They diagnosed the problem as fouled spark plugs. On the next leg he almost had to make another emergency landing due to a rough running engine. They then found the problem was really fuel starvation from large chunks of the dreaded kreem flaking off inside the wing tank and blocking the finger strainer. You can read the story on the "Sportflight web site". here is the direct link. http://sportflight.com/alaska/KingEpilog.htm It is quite interesting how they removed the wing and sloshed the tank with acitone to remove the remaining Kreem.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
bjones(at)dmv.com Guest
Posted: Tue Jan 08, 2008 9:18 pm Post subject: Wing Tank Fuel Finger Strainers |
I Checked my wing tank fuel strainers at about 300 hours, after using mostly
auto gas transferred form 5 gallon cans - both finger strainers were clear,
however I know I could find junk on the strainers at any time if junk got past
the filter in my funnel or if I changed my fueling technique in some other
meaningful way so hours in use may not be very useful. (As an aside, Lockwood
Aviation recommends a specific type of in line filter near the engine as I
recall from their Rotax 912 course.)
BJ
N154K
443-480-1023
bjones(at)dmv.com
Quoting Rick <wingsdown(at)verizon.net>:
I made that part of my annual. Good thing to check for sure. Should seal
without any sealants, but don't guess it could hurt unless your one of
those anal weight types.
Rick
Glenn Horne
Posted: Wed Jan 09, 2008 1:27 am Post subject: Wing Tank Fuel Finger Strainers |
Screw them out. I did mine and put them back in. No problem.
GLENN HORNE
Kitfox Model II
Michel
Posted: Wed Jan 09, 2008 1:47 am Post subject: Wing Tank Fuel Finger Strainers |
On Jan 8, 2008, at 4:17 PM, Marco Menezes wrote:
Quote: | The mesh in those strainers is pretty big.
Marco, can you give me the approximate size of the mesh, please? I have
never seen one open. Thanks in advance,
Michel Verheughe
Norway
Posted: Wed Jan 09, 2008 4:39 am Post subject: Wing Tank Fuel Finger Strainers |
I am familiar with the strainers. The more people that have checked them and never found anything make me feel better about not checking. Another thought is that since I have 2; the odds of both causing a significant restriction at the same time is low. I do like the bore scope idea though.
Maxwell S6/TD/IO240
Marco Menezes <msm_9949(at)yahoo.com> wrote:
[quote] Maxwell -
I remove and inspect mine annually with no [quote][b]
Posted: Wed Jan 09, 2008 8:02 am Post subject: Wing Tank Fuel Finger Strainers |
Michel - It's been a year since I took them out and my recollection may be somewhat spotty but I'd guess the finger strainer mesh is about 3/32" or larger. As I mentioned, I've never found anything stuck in them although my Purelator-type in-line filters, just a few inches downstream, have trapped alot of small particles.
Jimmie - Seems I also recall trying to look down the filler hole with mirror & light, and that the view is blocked, presumably by baffles. At least that was my experience. I have the 6 gal fiberglass tanks.
Michel Verheughe <michel(at)online.no> wrote:
[quote]--> Kitfox-List message posted by: Michel Verheughe
Marco, can you give me the approximate [quote][b]
Tom Jones
Posted: Wed Jan 09, 2008 8:25 am Post subject: Re: Wing Tank Fuel Finger Strainers |
Quote: | Marco, can you give me the approximate size of the mesh, please? I have
never seen one open. |
Michel, here's a finger strainer picture attached.
Description: |
Filesize: |
815.03 KB |
Viewed: |
576 Time(s) |
Classic IV
Ellensburg, WA |
Michel
Posted: Wed Jan 09, 2008 11:00 am Post subject: Wing Tank Fuel Finger Strainers |
On Jan 9, 2008, at 1:33 AM, Glenn Horne wrote:
Quote: | Screw them out. I did mine and put them back in. No problem.
You probably have built your plane yourself, Glenn. I haven't and I
know that the builder (who has passed away since) of my plane did an
excellent job. It was actually his third Kitfox. I am therefore always
afraid to damage something he did well. Beside that, it looks awkward
to remove mine; the access in the wing root is limited.
On Jan 9, 2008, at 4:55 PM, Marco Menezes wrote:
Quote: | Michel - It's been a year since I took them out and my recollection
Thank you, Marco. My gascolator has also always been free of debris. I
am pretty sure my tanks are clean but ... it's nice if I can positively
confirm it.
On Jan 9, 2008, at 5:25 PM, Tom Jones wrote:
Quote: | Michel, here's a finger strainer picture attached.
Thank you, Tom. From your ruler, I make it about 1 mm mesh. Somewhat
oarser than my gascolator.
Michel Verheughe
Norway
