Corrosion Treatment Primer Suggestions
Goto page 1, 2  Next
jesse(at)saintaviation.co
PostPosted: Fri Feb 01, 2008 8:42 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
Primer war coming right up. I can't imagine there isn't much in the archives, because there have been so many posts regarding primers in the past. Now people shy away from primer e-mails like the plague.
In short, there is no agreement as a group as to whether or not to prime, whether or not to alodine, and what primer to use if you are going to prime.
I have used several primers and am happiest with the Akzo Nobel apoxy primer that Spruce sells. It is tough as nails when it cures. A lot of people are quite happy with rattle cans of self-etching primer they get at Sherwin Williams or your local Auto Parts store. Others won't prime because the aluminum has the alclad surface. It's all up to you.
The Akzo Nobel stuff is probably one of the more complicated to apply, since it requires mixing and a spray gun, whereas the rattle can you just shake and apply. With primer that you have to mix, you will want to prepare as many parts as you can and then prime them at once, making sure that you mark them well so as not to confuse which part goes where.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Feb 1, 2008, at 11:07 AM, Chuck Henry wrote:
I have been working on the tail kit with great excitement. I did see the first of the parts get clecoed together which brought about my question. Section 5A of our builder’s manual has several suggestions for priming the inside parts of the aircraft structures. When I looked through the archives I found little in the way of recommendations. Is there a primer system that is better suited than the others that the group has some agreement on based upon ease of preparation and application, better protection and costs?
Chuck Henry
#40806 – Vertical Stabilizer
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
rv10builder(at)verizon.ne
PostPosted: Fri Feb 01, 2008 8:58 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
and so the primer war begins!
Chuck- look through the archives and www.vansairforce.net forums for everyone's opinion on primers. I can tell you that the easiest for me was the Sherwin Williams DTM wash primer. It has worked well for me as it does not require any mixing and it is water soluble so less toxic with soap and water clean-up.
There are more durable 2 part primers but I didn't want that hassle.
Pascal
Tim Olson
PostPosted: Fri Feb 01, 2008 9:19 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
I'd answer, but Jesse said exactly what I'd say. No wars from
me on this one.
going to prime.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
Cell: 352-427-0285
Fax: 815-377-3694
> Thanks,
> Chuck Henry
> *http://www.matronics.com/Navigator?RV10-List
gerf(at)gerf.com
PostPosted: Fri Feb 01, 2008 10:34 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
And if you don't find any other notes on it - take a look at Stewart Systems Ecko Etch and Sealer/Primer - water borne, easy cleanup. So far I'm very pleased with it.
g
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chuck Henry
Sent: Friday, February 01, 2008 9:32 AM
Subject: RE: Corrosion Treatment Primer Suggestions
Ugh, didn’t mean to start something bad. I did find some information on the vansairforce website which provided some direction. Thanks for the suggestions.
Chuck
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, February 01, 2008 11:51 AM
Subject: Re: Corrosion Treatment Primer Suggestions
Pascal
Kearney(at)shaw.ca
PostPosted: Fri Feb 01, 2008 10:56 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
Chuck
6nbsp;
Welcome!
6nbsp;
You didn 7t say anything bad E What no one will tell you is that the absolutely best way to prime is to first 6nbsp; 6lt;(* 5(at) 5)* 6amp; 5 4(at) 3 6amp;^* 6amp; 5* 6amp; 5 6amp; 6amp;878G 6amp;^ 6amp;* 6amp;6 a portion of this message was 6nbsp;lost in transmission ---- 6nbsp;thereby giving 6nbsp;really great resuls E
6nbsp;
Cheers
6nbsp;
Les Kearney
340643
C-GCWZ reserved
poneill(at)irealms.com
As this can be a volatile topic, this is not a suggestion but just a description of what I did.
I used the Akzo 2-part epoxy primer on all interior surfaces (excluding those which would receive the final interior paint). I didn’t use it because I consider priming a necessity, but because I really like the material. It is fantastic stuff. I started to also Alodine parts in the beginning but ended up abandoning that by the end of the Horizontal Stab in favor of just a simple application of Akzo.
Best Regards,
Patrick #40715 / N690CT
Sent: Friday, February 01, 2008 8:08 AM
Subject: Corrosion Treatment Primer Suggestions
Chuck Henry
jeff(at)westcottpress.com
PostPosted: Fri Feb 01, 2008 11:44 am    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
I'm from the school of "I'll only prime something if I absolutely have to."  So, I'm only priming the steel parts, spot priming scratched Alclad with rattle can Zinc Chromate and plan on a shot of Corrosion X when all is said and done.
That said, I would like to pose a question to those now flying.  Have you found any areas where moisture does accumulate without a quick means of either draining or evaporating?  I remember when I was working on an RV-6 that most everyone drilled a small hole in the lowest spot on the tail to allow for drainage of water that accumulated there.
If there are areas where water collects, I'll want to spot prime them before I really button things up
Jeff Carpenter
40304
N410CF Reserved
Almost through The Dreaded Section 29
Finish Kit on order
Chuck Henry
AV8ORJWC
Surface and corrosion treatments are separate from primers and sealers. The wars begin because people are passionate about there choice. Understanding why some builders would pursue alodine, or anodizing then grasping the difference with wash primers, etching primers, sealers and 2 part epoxy are each important steps in the journey. Understand why and where some builders apply proseal to fayed joints and trailing edge attachments.
The final topcoat selection should always drive the type of primer (Read Kitplanes – March 2008, Page 45). Quality preparation is critical to a lasting topcoat bond. Knowing the thickness of Alclad on the outermost skin and the effort with scotchbrite or sandpaper which removes it can help in choosing products. Many builders can blast right through the Alclad and down to the base without knowing that thickness.
Choose Wisely. Knowledge is not a bad thing. Some paint decisions are made on price or ease of application alone.
John Cox
#40600
Do not Archive     cause few take the time to read old posts
Chuck
Pascal
MauleDriver(at)nc.rr.com
PostPosted: Fri Feb 01, 2008 12:04 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
Welcome aboard Chuck. You probably have no idea what you just stepped on (re primers that is). There are as many different opinions as there are builders.... are you belt, suspender, or belt and suspender guy? Low rider perhaps? Sorry.
Anyway, I used the same stuff that Vans uses on the QB kit - Sherwin Williams Wash Primer. I have no experience to base that on, just selected one from the many options that should be well documented in the archives.
One point most agree with; Vans is pretty much agnostic as far as prime. No primer is required for the most part from there point of view. But where they 'suggest' priming in the plans, it's probably a good idea to definitely prime those (few) parts.
I look back at 1.5 years and marvel at all the energy I put into primer research. I'm pretty confident that any of the approaches taken is sound.
Enjoy!
Bill Watson
40605
Durham NC
millstees(at)ameritech.ne
PostPosted: Fri Feb 01, 2008 12:05 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
I like Akzo Premier from Aircraft Spruce. It's easy to mix (1:1) and has proven very durable.
Steve Mills N750SM (reserved)
RV-10 40486 Slow-build Eggenfellner E-6TI
Naperville, Illinois
Finishing kit, engine install
Sent: Friday, February 01, 2008 10:08 AM
Chuck Henry
Tim Olson
PostPosted: Fri Feb 01, 2008 12:07 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
I'm not seeing any areas of water collecting at all.
But, I have seen others who haven't sealed their rudder
lower fairing fully end up with a rudder fairing full of
water. So, I drilled a hole there preemptively.
Other than that, dry as a bone for me.
Jeff Carpenter
40304
N410CF Reserved
Finish Kit on order
AV8ORJWC
PostPosted: Fri Feb 01, 2008 12:27 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
A 1968 Cessna (some like to reference them), which I completed an Annual on had a draining hole that was plugged from organics. Upon cleaning, the water removed exceeded a gallon and a half. No it was not an amphibian which by the way usually does get alodining during assembly. Tail draggers (Conventional Geared) know the results of condensation. A wood propeller left in a vertical rather than horizontal position can get the same response – Condensate flow.
I am from the school that reading the AC43.13 (which is only advisory) can enlighten this subject. Seeing the insulation that we remove from our airline fleet (each 5500 hours or once a year) then dealing with the corrosion has given me an enhanced opinion on surface preparation and corrosion control.
Once corrosion begins, it is a bear to stop and remediate. Removing and re-skinning aircraft should be left for WWII warbirds. For most RV builders, they will never see their choice not to do corrosion control and just build it. Flying for decades can be done with either course. YMMV.
Do it once… do it Right is my mantra. I go nuts doing things twice (or more) and enough of you know I am nuts.
John Cox
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
Sent: Friday, February 01, 2008 11:39 AM
Jeff Carpenter
40304
N410CF Reserved
Finish Kit on order
Chuck Henry
http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
PostPosted: Fri Feb 01, 2008 12:41 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
Yeah, you definitely want a hole in the front bottom of the rudder
bottom fairing. There is no way to keep the water out of it. I also
have not seen any points of accumulation, although the places that
could fit the bill for getting moist and not drying are probably not
places easy to check. For what it's worth, I don't leave a single
metal part of this plane unprimed.
I think the plans specifically say to prime inside and outside of all
control tubes, as well as to prime all places on the wing spar where
there is removal of the anodized surface, like where they are
countersunk for the tank attach screw dimples. I don't remember where
else, but I agree that everything steel should be either powder
coated, greased or primed, depending on where it is and what its
function is.
So far this has been the most friendly primer war I have seen. I
think since so many of us have been through it before and know how
ugly it can get. Remember when the discussion of Inodyne was going
on? Those were the days (the bad old days).
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> accumulated there.
> Jeff Carpenter
> 40304
> N410CF Reserved
> Finish Kit on order
rnewman(at)tcwtech.com
PostPosted: Fri Feb 01, 2008 3:44 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
If you really enjoy your RV-10 building project and are looking for a way to
make it last even longer than just a slow build kit, you may want to
consider the primer system we've used on the 3 Glastars we've build and
presently are using on our RV-10. Deft primer 44-G-11 is a two-part water
reduced epoxy (developed for Boeing) that also requires acid etching and
can really make the project take forever! (oh yeah, the mix ratio is a handy
2 : 1: 4.5.) On the good side, when it cures it's ridiculously hard and
resistant to anything we could do to it. Don't let it get on anything you
don't want it permanently attached to! Sarcasim asside, it appears to be
a terrific primer. 9 years of annual inspections of our oldest Glastar
(often kept near the NJ shore) have shown zero corrison.
Bob Newman
40176 super slow build
daveleikam(at)wi.rr.com
PostPosted: Fri Feb 01, 2008 7:46 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
No primer, except on QB kits (Van's did it) or on bare steel parts. I am using ACF-50, Boeshield or Corrosion-X leaning towards Boeshield. Quick, clean, easy and lite. Wipe a thin coat on interior skin surfaces or any other part not to be painted before or after assembly. Apply liberally after paint.
http://boeshield.com/index.html
http://www.corrosionx.com/aviation.html
http://www.corrosion-control.com/acf50.html
Dave Leikam
40496
johngoodman
PostPosted: Sat Feb 02, 2008 6:11 am    Post subject: Re: Corrosion Treatment Primer Suggestions Reply with quote
Dave,
I'm going to do the same thing you are, but I had pretty well settled for ACF-50 and self spraying. Are you only wiping the Boeshield T-9 on areas that are accessible or is there a way to get it in hard to reach areas? Also, I thought Corrosion-X was a service only package - you have to go to one of their sites to get it done; or can you do it yourself?
John
[quote="daveleikam(at)wi.rr.com"]No primer, except on QB kits (Van's did it) or on bare steel parts. I am using ACF-50, Boeshield or Corrosion-X leaning towards Boeshield. Quick, clean, easy and lite. Wipe a thin coat on interior skin surfaces or any other part not to be painted before or after assembly. Apply liberally after paint.
Dave Leikam
40496
PostPosted: Sat Feb 02, 2008 9:20 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
I purchased a can of Corrosion -x from Aircraft Spruce along with a can of
ACF-50 and Boeshield to try each one. I like ACF-50, but Boeshield seems to
put a thicker coating on a part. I like the way you can just spray a bit on
and then wipe it off gently and leave a nice coat. I have used it on a few
parts and my bottom wing skins but alot else yet. For hard to reach areas,
I would just spray the stuff on. It should penetrate everywhere. This is
the reason to apply it after painting. I will spray it on all exposed and
interior surfaces after final painting. It somewhat dries or becomes like a
very thin waxy coating. Supposedly, if you scratch a coated part, the
products will re-fill in the blemish. I like the concept better than
primer. I may be wrong, but it is the way I am going. ACF-50 is safe on
electronics. At OSH the company had a small circuit with LEDs flashing on
it powered by a AA battery submerged in a jar of the stuff flashing away.
*(The previous statement is not necessarily the opinion of other builders on
this list, their sponsors or affiliates and should not be taken as the
gospel truth. Any unauthorized use of this opinion is perfectly OK with me.
Good luck!)
Dave Leikam
40496
n212pj(at)gmail.com
PostPosted: Mon Feb 04, 2008 1:39 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
Chuck, don't listen to a word these poor, misguided "builders" are saying! Heck, they are so full of the perverbial "bull" that it's hard to walk through their hangers without, well, you know, getting a little stinky. Let me set you right.
On the subject of priming, all you have to do is listen to me and you'll be all set. First you get yourself one of them big windex refill bottles, which you can get at any store, as long as it's blue, the liquid, not the bottle. Empty half of it, pour in half a bottle of 409 and mix well. Add a couple tablespoons of lye. Best stand back a little. Then empty that into a half gallon container. Add a bottle of liquid wax, any brand will do. Top off with some denurtured alcohol. Shake. Then get yourself a nice spray gun and, after scratching off all the aluminum coating with some hand soap with pumice in it, spray it on! Last forever. Not much weight, either. Oh, and don't forget to rinse after using the soap before spraying.
I'm very satisfied with this approach and can tell you without hesitation that it works for me.
John J
40328
do not archive, please
Chuck Henry
bbreckenridge(at)gmail.co
PostPosted: Mon Feb 04, 2008 2:12 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
OH MY GOSH! Chuck, you should really see this guy's work. Let's just say, "I have" and I'll leave it at that. I've never heard of such a technique before, and, as a Matronics reader since 2003, and an occasional contributor (since I started building) since 2005, I can personally vouch for John and every word he says. Especially the part about the stinky bull. What I can't believe is that he spaced on one of the ingredients: Once you're done with the batch, add 1 part per hundred Gorilla Glue. This readily dissolves in the mixture as long as it's above 60 F and adds the extra touch of adherence we're all looking for.
Good luck
Bruce Breckenridge
40018 Wings
Please, by all means, DO NOT ARCHIVE - it's Monday!
On Mon, Feb 4, 2008 at 1:34 PM, John Jessen <n212pj(at)gmail.com (n212pj(at)gmail.com)> wrote:
John J
40328
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Chuck Henry
I have been working on the tail kit with great excitement. I did see the first of the parts get clecoed together which brought about my question. Section 5A of our builder's manual has several suggestions for priming the inside parts of the aircraft structures. When I looked through the archives I found little in the way of recommendations. Is there a primer system that is better suited than the others that the group has some agreement on based upon ease of preparation and application, better protection and costs?
Chuck Henry
==== get="_blank">http://www.matronics.com/Navigator?RV10-List a>http://forums.matronics.com _blank">http://www.matronics.com/contribution [/b]
apilot2(at)gmail.com
PostPosted: Mon Feb 04, 2008 4:38 pm    Post subject: Corrosion Treatment Primer Suggestions Reply with quote
If that mixture is a bit thick to spray, just add a quort of acetone and a quart of MEK...then it will be thin and stinky and seep into all the seams for best penetration.
Did someone mix up 4/1/08 with 2/4/08, or just practicing?
Definitely
DO NOT ARCHIVE
On Feb 4, 2008 3:08 PM, bruce breckenridge <bbreckenridge(at)gmail.com (bbreckenridge(at)gmail.com)> wrote:
[quote] OH MY GOSH! Chuck, you should really see this guy's work. Let's just say, "I have" and I'll leave it at that. I've never heard of such a technique before, and, as a Matronics reader since 2003, and an occasional contributor (since I started building) since 2005, I can personally vouch for John and every word he says. Especially the part about the stinky bull. What I can't believe is that he spaced on one of the ingredients: Once you're done with the batch, add 1 part per hundred Gorilla Glue. This readily dissolves in the mixture as long as it's above 60 F and adds the extra touch of adherence we're all looking for.
Good luck
Bruce Breckenridge
40018 Wings
Goto page 1, 2  Next
Page 1 of 2
