orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sun Feb 10, 2008 12:15 pm Post subject: Dimmers |
I can't find that much on this subject via 'Search' so I am asking the experts
I am at the point of identifying what type of dimmer(s) I am going to go with. Van's has a single channel for $20 and a 4 channel for $115. The catalog lists the 4 channel as a Pulse Width Modulation which sounds good but in the archives here there is one comment about a PWM unit having problems with a 430W. Paul says that they have a dual channel unit for $75 and it sounds like it is a voltage regulation type.
Price wise the Van's single unit is the cheapest available but it doesn't say anything about if it is a PWM or a standard type voltage regulation unit.
My questions are, which method of control is better, voltage regulation or PWM, and how many circuits are people usually going with?
I will have a dual AFS system, 430W, SL40, 327, PM8000B, TT ADI and other rather standard cockpit lights.
Thoughts please.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Posted: Sun Feb 10, 2008 3:01 pm Post subject: Dimmers |
I had a nice schematic for a transistor dimmer, but I can't find it.
Here's a more complex but very workable design from Aeroelectric.com.
http://www.aeroelectric.com/articles/Dimmers/9013_Ins.pdf
Linn
orchidman wrote:
I can't find that much on this subject via 'Search' so I am asking the experts [Laughing]
Thoughts please.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=163325#163325
orchidman
Posted: Sun Feb 10, 2008 3:58 pm Post subject: Re: Dimmers |
I have seen this but I was hoping that I would not have to 'role my own'. Plus this one requires a heat sink equaling heat and higher wattage consumption.
My hope is that I could get some discussion about the Pulse Width Modulation types and if there are any negatives.
RV10 - # 40674
(N2GB Flying) |
Posted: Sun Feb 10, 2008 6:11 pm Post subject: Dimmers |
orchidman wrote:
| Quote: | | Quote: | --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com> (gary(at)wingscc.com)
pitts_pilot(at)bellsouth. wrote:
I have seen this but I was hoping that I would not have to 'role my own'. | | I think Aeroelectric sells it built. Or maybe they used to.
| Quote: | | Quote: | | Plus this one requires a heat sink equaling heat and higher wattage consumption. | | The power has to go somewhere. The old potentiometer type dimmers were a really high watage variable resistor that also got pretty hot ....
| Quote: | | Quote: | | My hope is that I could get some discussion about the Pulse Width Modulation types and if there are any negatives. | | The only negative I can think of is that switching on/off like that might produce ripple (read noise) on the power bus. You can use a 555 timer (Radio Shack) to drive a power transistor (the 555 won't handle a lot of current), but we're back to the heat sink if there's a lot of incandescent lamps. If you go to LED lighting, the power consumption will be less, and lessen the need for a heatsink.
[quote] [b]
Tim_Lewis(at)msm.umr.edu Guest
Posted: Sun Feb 10, 2008 6:39 pm Post subject: Dimmers |
I'm using the $115 one from Vans. The instructions include a very
modest modification (2 resistors, one capacitor, details at
http://fdatasystems.com/Manuals/LC-40_Garmin.pdf) to use the PWM signal
with the Garmin 400/500 series units. I elected to follow the dimmer
manufacturer's suggestion, however, and just use the built in photocell
in my 530W to dim the unit automatically. I can always tie it in to the
dimmer later if desired.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
orchidman wrote:
Thoughts please.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
Tim Olson
Posted: Sun Feb 10, 2008 6:42 pm Post subject: Dimmers |
Van's, and Stein both sell some dimmers that work well for
most instrument and radio lighting. Especially if you use
LED's, it's not like you're going to be drawing a lot of
power. I'm sure all of my dimmable circuits likely come to
less than 1A by a fair margin.
Make sure you evaluate your panel in full before worrying
too much about dimmers. I have 2 dimmers, small ones, and
they are for instrument lights, and one for the overhead
lights. Most avionics will auto-dim, or have their own
adjustment. So, you're only really looking at things
like the compass, ADI, CDI, and perhaps one or two other
small things that will even have a dimmer hooked up to it.
>> Linn
> Gary Blankenbiller
> RV10 - # 40674
> Fuselage SB
> (N410GB reserved)
> http://forums.matronics.com/viewtopic.php?p=163369#163369
orchidman
Posted: Sun Feb 10, 2008 7:23 pm Post subject: Re: Dimmers |
| Tim_Lewis(at)msm.umr.edu wrote: | I'm using the $115 one from Vans. The instructions include a very
dimmer later if desired. |
Tim, thanks for the link. That lead me also to the main manual. Both have given me the information I need to evaluate this option. Looks good.
RV10 - # 40674
(N2GB Flying) |
tdawson-townsend(at)auror Guest
