		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Sun Feb 10, 2008 12:15 pm    Post subject: Dimmers |
				I can't find that much on this subject via 'Search' so I am asking the experts
 I am at the point of identifying what type of dimmer(s) I am going to go with.  Van's has a single channel for $20 and a 4 channel for $115.  The catalog lists the 4 channel as a Pulse Width Modulation which sounds good but in the archives here there is one comment about a PWM unit having problems with a 430W.  Paul says that they have a dual channel unit for $75 and it sounds like it is a voltage regulation type.
 Price wise the Van's single unit is the cheapest available but it doesn't say anything about if it is a PWM or a standard type voltage regulation unit.
 My questions are, which method of control is better, voltage regulation or PWM, and how many circuits are people usually going with?
 I will have a dual AFS system, 430W, SL40, 327, PM8000B, TT ADI and other rather standard cockpit lights.
 Thoughts please.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
				 Posted: Sun Feb 10, 2008 3:01 pm    Post subject: Dimmers |
				I had a nice schematic for a transistor dimmer, but I can't find it.
 Here's a more complex but very workable design from Aeroelectric.com.
 http://www.aeroelectric.com/articles/Dimmers/9013_Ins.pdf
 Linn
 orchidman wrote:
 I can't find that much on this subject via 'Search' so I am asking the experts  [Laughing]
 Thoughts please.
 Gary Blankenbiller
 RV10 - # 40674
 Fuselage SB
 (N410GB reserved)
 http://forums.matronics.com/viewtopic.php?p=163325#163325
		orchidman
				 Posted: Sun Feb 10, 2008 3:58 pm    Post subject: Re: Dimmers |
 I have seen this but I was hoping that I would not have to 'role my own'.  Plus this one requires a heat sink equaling heat and higher wattage consumption.
 My hope is that I could get some discussion about the Pulse Width Modulation types and if there are any negatives.
RV10 - # 40674
(N2GB Flying) |
				 Posted: Sun Feb 10, 2008 6:11 pm    Post subject: Dimmers |
				orchidman wrote:
   	  | Quote: | 	 		      	  | Quote: | 	 		  --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com> (gary(at)wingscc.com)
 pitts_pilot(at)bellsouth. wrote:
 I have seen this but I was hoping that I would not have to 'role my own'. | 	    | 	   I think Aeroelectric sells it built.  Or maybe they used to.
   	  | Quote: | 	 		      	  | Quote: | 	 		  |   Plus this one requires a heat sink equaling heat and higher wattage consumption. | 	    | 	   The power has to go somewhere.  The old potentiometer type dimmers were a really high watage variable resistor that also got pretty hot ....
   	  | Quote: | 	 		      	  | Quote: | 	 		  | My hope is that I could get some discussion about the Pulse Width Modulation types and if there are any negatives. | 	    | 	   The only negative I can think of is that switching on/off like that  might produce ripple (read noise) on the power bus.  You can use a 555 timer (Radio Shack) to drive a power transistor (the 555 won't handle a lot of current), but we're back to the heat sink if there's a lot of incandescent lamps.  If you go to LED lighting, the power consumption will be less, and lessen the need for a heatsink.
  [quote]    [b]
		Tim_Lewis(at)msm.umr.edu Guest
				 Posted: Sun Feb 10, 2008 6:39 pm    Post subject: Dimmers |
				I'm using the $115 one from Vans.  The instructions include a very
 modest modification (2 resistors, one capacitor, details at
 http://fdatasystems.com/Manuals/LC-40_Garmin.pdf) to use the PWM signal
 with the Garmin 400/500 series units.  I elected to follow the dimmer
 manufacturer's suggestion, however, and just use the built in photocell
 in my 530W to dim the unit automatically.  I can always tie it in to the
 dimmer later if desired.
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1000 hrs
 RV-10 #40059 under construction
 orchidman wrote:
  Thoughts please.
  Gary Blankenbiller
  RV10 - # 40674
  Fuselage SB
  (N410GB reserved)
		Tim Olson
				 Posted: Sun Feb 10, 2008 6:42 pm    Post subject: Dimmers |
				Van's, and Stein both sell some dimmers that work well for
 most instrument and radio lighting.  Especially if you use
 LED's, it's not like you're going to be drawing a lot of
 power.  I'm sure all of my dimmable circuits likely come to
 less than 1A by a fair margin.
 Make sure you evaluate your panel in full before worrying
 too much about dimmers. I have 2 dimmers, small ones, and
 they are for instrument lights, and one for the overhead
 lights.  Most avionics will auto-dim, or have their own
 adjustment.  So, you're only really looking at things
 like the compass, ADI, CDI, and perhaps one or two other
 small things that will even have a dimmer hooked up to it.
 >> Linn
 > Gary Blankenbiller
 > RV10 - # 40674
 > Fuselage SB
 > (N410GB reserved)
 > http://forums.matronics.com/viewtopic.php?p=163369#163369
		orchidman
				 Posted: Sun Feb 10, 2008 7:23 pm    Post subject: Re: Dimmers |
				 	  | Tim_Lewis(at)msm.umr.edu wrote: | 	 		  I'm using the $115 one from Vans.  The instructions include a very
 dimmer later if desired. |
 Tim, thanks for the link.  That lead me also to the main manual.  Both have given me the information I need to evaluate this option.  Looks good.
RV10 - # 40674
(N2GB Flying) |
		tdawson-townsend(at)auror Guest
