ez(at)embarqmail.com Guest
Posted: Sun Feb 17, 2008 3:14 pm Post subject: Finally flying my MK III!!! |
On Feb 17, 2008, at 5:07 PM, John Hauck wrote:
| Quote: | I flew down to Lucedale, MS, last week, with a load of barn dust,
bug crap, and cow manure. Did 380 sm in 4.2 hours. Believe if I
cleaned her up I could have done a lot better. Every time I wash my
1992 Dodge/Cummins it seems to run twice as good. Maybe I should
try that with the mkIII.
John,
Just curious, what was the problem with the original gears that were
replaced?
As for a true apples to apples VG test we need to have this settled
once and for all by having a well seasoned kolb pilot try slow flight
to stall with VG's on just one wing. < g >
Posted: Sun Feb 17, 2008 4:48 pm Post subject: Finally flying my MK III!!! |
Gene Z:
There were some isolated cases of gear teeth shedding some metal fragments
that could eventually cause a catastrophic failure if those fragements got
into the gears.
I believe Rotax took a big bracket on each side the failures and mine was
included in that bunch.
My old gears, the gear box, and the crankshaft looked great, just like it
should have.
_________________ John Hauck
Titus, Alabama |
Dana
Posted: Sun Feb 17, 2008 4:50 pm Post subject: Finally flying my MK III!!! |
At 10:47 AM 2/17/2008, John Hauck wrote:
Can't see spending that much on an ASI... I'm not worried about supreme
accuracy; I just want to get the best accuracy out of what I already have.
-Dana
"The difference between death and taxes is death doesn't get worse every
time Congress meets." -- Will Rogers
Possums
Posted: Sun Feb 17, 2008 5:41 pm Post subject: Finally flying my MK III!!! |
At 09:50 AM 2/17/2008, you wrote:
Anybody know how accurate the old Hall (floating disk) airspeed
indicators are? I borrowed one from a friend to check my ASI, but
cold weather has kept me from getting a chance to mount it yet.
-Dana
I've got one on mine - it's more accurate than the one inside at low speeds.
Especially with the windshield off, but I think even with the windshield on
the Hall ASI is the most consistent.
104.46 KB |
408 Time(s) |
_________________ Possum |
herbgh(at)nctc.com Guest
Posted: Sun Feb 17, 2008 6:54 pm Post subject: Finally flying my MK III!!! |
I am reminded of the old Kolb Video, with Dennis Souder flying three
models.. His slow flight in the mark 111 was quite impressive to me..
full flaps... and some power...
I think that sort of maneuverability is what sold a lot of us on
Kolbs in the first place... gotta be light however.. Mine was very
stock and weighed 490 as I recall..I haven't landed any plane that
well since... Never did get around to using the second notch of flaps.. Herb
At 10:24 AM 2/17/2008, you wrote:
I have had an outside static source on my Kolb from the beginning,
so there are no pressure errors in my system. I have also checked
my airspeed readings with the GPS you see in the picture under no
wind conditions, and again everything is accurate.
Precise placement of the VG's has been determined by the
manufacturer, they are not airplane specific, but its about the same
for most general aviation airfoils. The angles of the VG's into the
wind are especially critical as is thier design. I put them on
exactly per the instructions, and the result was an incredible
difference. You can get the VG's at:
http://www.landshorter.com/
There is another Kolb MK III with a 912 based at my field, its "Fat
Albert" as some of you remember that plane. The difference between
landing that plane and landing my plane is huge, the other MK III
has to be landed very fast, and with power to keep it from dropping
hard onto the runway much the same as described by Grant. My MK
III can be landed engine off, approaching at 50 MPH and result in a
soft landing. The "Fat Albert" pilot could not believe the
difference between the two MK III's.
In a nutshell, the VG's eliminate the "Kolb Quit" where the plane
just drops into the runway if you get it to slow. I generally do
three point landings, but many times I touch the tailwheel first at
less than 30 MPH indicated, no problem, the mains just come down
very nicely. I will take some videos of this and post them on You Tube.
"NO FEAR" - If you have no fear you did not go as fast as
you could have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=164578#164578
grantr
JetPilot
Posted: Sun Feb 17, 2008 10:56 pm Post subject: Re: Finally flying my MK III!!! |
| NeilsenRM(at)comcast.net wrote: | Grant
VGs likely help but don't help as much as you are being led to believe. In a
recent side by side fly off the difference wasn't real noticeable.
The pilot flying with the VG's was distracted, and did not fly the plane well, which he admitted here on the list. You statement here is nothing short of misleading and bordering on dishonest. Also, not all VG's installations are equal. VG's made out of alumimum with the " That looks about right" technique might not work as well. Placement and angles are VERY critical, if VG's were not installed in a very precise and accurate manner, their effects will be drastically reduced.
John H correctly made a point that airspeed indicators in Kolbs can be
inaccurate and at higher angles of attack they get even more so.
Did you not read my post, I have a separate static source and back up the airspeed with GPS as can be seen in my picture, again your statement is nothing short of misrepresenting the facts to make your point. Look at the attached picture and try to explain the GPS speed as instrument error.
The term I hear "kolb quit" is plain and simple a stall no matter how much
these newbies want to believe otherwise.
No I don't have VGs. Three point landings are easer
for me and I land slower so....
As usual the advice is worth what you paid for it.
Rick Neilsen
Redrive VW powered MKIIIC
Kolb quit is a very real fact, and it bends a lot of gear on landing. VG's practically eliminate this bad behavior. I dont care what theory may or not apply, I would rather have my Kolb land in a docile manner, and be forgiving of less than perfect technique. Pilots are human, from time to time you will have a bad landing, I dont want an airplane that will bite me and be easily damaged on a less than perfect landing.
There is a huge amount of evidence and testimonials on the positive effect VG's here on the list. I have not always had VG's, I have flown my plane with and without them, and I am giving my results backed up with pictures and numbers. I do not sell VG's, and I have no reason to mislead anyone here. I am posting information on VG's here because some Kolbers took the trouble to tell me about the benefits of VG's, so im passing it along to others that can benefit also.
Your catchy little one liner is nothing more than an attempt to distract readers from the facts here. All Rick has here is some very biased opinions, and has done nothing short of mislead and misrepresent the facts to make his point. Look at the pictures, look at the facts, and then make your choice.
Mike Bigelow
193.31 KB |
425 Time(s) |
Kolb MK-III Xtra, 912-S |
pj.ladd(at)btinternet.com Guest
Posted: Mon Feb 18, 2008 1:38 am Post subject: Finally flying my MK III!!! |
recent side by side fly off the difference wasn't real noticeable.>>
Hi Rick,
on this side of the pond the engineering department of the PFA carried out
very stringent tests and the answer as far as stall speed is concerned is
`They work`. The proof is that the Xtra would not make the stalling speed
required to qualify as a `microlight` without the VG`s. With the VG`s
fitted it dropped the stalling speed by enough to enable the Xtra to make
the grade.
Any further so called benefits in cruise and handling are pretty sibjective
I think but the lowering of the stall speed is unquestionable. Here you
will not get a Certificate to Fly without the VG`s fitted.
Cheers
Pat
Posted: Mon Feb 18, 2008 7:07 am Post subject: Finally flying my MK III!!! |
your choice.
Mike B:
Rick Neilsen was on the ground at London observing the flyoff between
Richard Pike and me. His comments are not biased opinions, and he is not
trying to mislead and misrepresent the facts to make his point.
I flew as slow as Rev Pike with a mkIII that was "probably" much heavier
than his mkIII equipped with VG's. Was Richard distracted? Hell, I don't
know, or do I understand why that would have anything to do with his minimum
flight speed. The wings are going to fly until they quit, whether you are
having a good day or bad.
I am extremely happy you have a static source for your airspeed indicator.
All ASI's have them, although most are not calibrated. If they are not
calibrated, they are not very accurate. Takes very little static pressure
error to kick one +10 or -10 mph.
Your photo is very impressive. If, in fact, your mkIIIx will fly 25 mph
straight and level, I congratulate you, because it is probably the only one
in existence that will fly that slow.
Again, I am not saying VG's do not work. I am saying whatever improvement
there is is not justification for me to install them on my airplane.
Titus, Alabama |
Posted: Mon Feb 18, 2008 8:28 am Post subject: Finally flying my MK III!!! |
I will only respond this once on this issue only because of your continued
inference about the flying qualities of a Kolb. "Kolb Quit" is a "stall"
caused by low speed landings in a very low mass airplane. This is what makes
our Kolbs superior STOL airplanes. If one follows common GA pilot training
with the use of flaps and no power in landing you are right Kolbs take a
high skill level to keep from bending gear. If we change our technique by
add some speed and power while landing, Kolbs become a very forgiving
airplanes to land correctly. Granted it is best to land without having to
depend on power and maybe slower speeds but slowly progress to that stage as
you get more proficient in your Kolb.
As for the VG thing. At some point I will put them on my plane. I think they
help and as I get older I might need the help but I'm still concerned about
them lowering my cruise speeds. With that said the benefits are considerably
over stated on this list. A ham fisted pilot will still bend his landing
gear or worse even with VGs. Mike keeps saying I ignore the "facts". Most of
us are aware that there is a considerable inaccuracy in airspeed indicators
in different airplanes especially between installations and measurement
types. To show a photo of a ASI and call it "fact" is a bit of a stretch. I
REALLY REALLY don't want to start another VG battle again on the list but. I
was there at the VG fly off and saw the drastic differences between the two
planes and pilots. There would have been 100% agreement between every one
there except maybe John H that he was going to get his butt kicked big time
before the fly off. It didn't happen, it was a draw.Yes I heard ALL of the
excuses but if VGs help as much as you guys say is "fact" it still would
have been a butt kicking. One final comment that is truly quantifiable is
that John's non VG airplane weighed almost 25% more!!!
OK. Mike I know you, like my wife, will have to have the last word so have
at it.
Rick Neilsen
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Mon Feb 18, 2008 10:20 am Post subject: Re: Finally flying my MK III!!! |
Sorry.
Two different airplanes (even though both are Kolbs) with two different pilots.
The “VG” fly off was interesting but hardly a definitive determination about the effectiveness of V.G.’s.
