Posted: Thu Feb 28, 2008 4:42 pm Post subject: FireStar Cockpit Noise Reduction? |
The fact that we are sitting at the focal point of a cone shaped
megaphone is the problem.
If we move our seats out in front of the windshield it will be a lot
quieter.
-or maybe a sound diffuser behind our backs.
BB
On 28, Feb 2008, at 3:46 PM, John Hauck wrote:
> Should be under 600 mph tip speed to reduce noise from the prop.
> Ray
Hi Ray:
We've knocked this noise thing around quite a bit over the years.
I'd say it it more prop noise than anything else. Also, I think we
can discount prop tips approaching or exceeding supersonic speeds.
The Rotax engines have already taken that into consideration for us.
I believe most of our noise is the result of a pusher engine
configuration with a prop that must run through air that is not
always clean and in close proximity to the aircraft structure.
I have gotten down to the point where I accept my noisy airplane
and try to take other routes to help make it liveable for long
flights. Some of us have proven that it is not so excessive we can
not live in our airplanes for very long periods of time.
mkIII Noisy beyond imagination.
captainron1(at)cox.net Guest
Posted: Thu Feb 28, 2008 5:26 pm Post subject: FireStar Cockpit Noise Reduction? |
The problem with VG's on the prop is that you will always have lots of Thrust. Even after you shut the engine down. You will need to install thrust nualifiers to keep your airplane from taking off and disappearing into the sky, perpetually loitering in the heavens.
---- Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
| Quote: | Mike W:
Once you start flying your mkIII you will probably discover the major noise
producing item is the prop.
By producing a very quiet engine, you will be able to hear your prop better.
Ah, John,
With very little MkIII flying time (read that to be "none"), I wouldn't know that the prop makes that much noise. But I really do believe I should have a very quiet engine, and I figured if the prop was a problem, then I would just install VGs on it.
chuckling
Mike Welch
Helping your favorite cause is as easy as instant messaging.�You IM, we give.
kugelair.com
JetPilot
Posted: Thu Feb 28, 2008 9:14 pm Post subject: Re: FireStar Cockpit Noise Reduction? |
My MK III Xtra was very noisey, the prop noise going into a huge megaphone is a very good description of the problem. The good news is that the noise can be fixed, and a Kolb can become pretty quiet.
On my MK III Xtra, I put 1/2 inch ductboard in the Cabin anywhere it faces the prop, and also under the engine ( Center Section ). Ductboard is rigid, fireproof, oil and fuel proof on the foil side, and does a fair job of dapening sound. I installed ductboard inside the lexan rear windows, and closed the back space of the cage where it goes against the prop. This was so successful in reducing the noise, that I can now communicate normally in the plane with headsets and intercomm, I could not before... The plane is now enjoyable to fly for long periods of time with out fatigue.
I did lose my view to the rear, but it was well worth it. I dont directly behind me much, and given the choice of having an airplane that I could not fly without going deaf, and one that is comfortable to fly, losing the rear visibility is a very good tradeoff.
Second, I do use ANR headsets. The ANR headsets did not work well alone with the huge roar of noise inside my life sized megaphone of a cockpit, but the headsets along with the ductboard made noise a Non - Issue in my plane.
I will post pictures soon.
Kolb MK-III Xtra, 912-S |
gaman(at)att.net Guest
Posted: Fri Feb 29, 2008 5:01 pm Post subject: FireStar Cockpit Noise Reduction? |
John,
I too was surprised by the MK-3 W/2200 Jabiru prop noise level..Hi tech foams offered a 1/2 in thick dense foam sound control product, and I lined ALL the rearward facing plexiglas and the complete center cover top,.spar carry thru,doubled that piece,and wing root ends.It has foam on the inside of the fabric behind the seats to the rear of the fuselage.Now with the ANR kits installed in my 30 year old DC H-10-30's with foam covers and leather bags over the mic's I can adjust the VOX on the intercom to talk to my passenger at cruise power settings under 2800 rpm but at full throttle it will open the mics.The ANR kits from Headsets Inc. (at)169.00 each were worth it! G.Aman .3iginal Message ----
Sent: Thursday, February 28, 2008 3:50:19 PM
Subject: Re: Re: FireStar Cockpit Noise Reduction?
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
> The single most effective thing you can do is get yourself a set of ANR
| Quote: | (Active Noise Reduction) headsets. MAN, what a difference they made for
me!
Dennis:
Got your bag packed for MV?
I tried the best Litespeed had to offer when they first came out without
success. Then, last summer, I bought the best that David Clark had to offer
the XL somethings. Neither would work in the mkIII cockpit.
The set that worked best for me was the DRE6000, which unfortunately, is out
of business. Got my fingers crossed my old set will keep on trucking.
mkIII Bag packed for MV - The Kolb-List Email Forum Use the Matronics List Features Navigator to the many List utilities such as List Archive Search & Download, 7-Day Browse, Chat, Photoshare, and much much --> - MATRONICS WEB FORUMS Same great content also available via the Web --> - List Contribution Web Site Thank you for your generous -Matt Dralle, List --> [quote][b]
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Wed Mar 05, 2008 6:52 pm Post subject: Re: FireStar Cockpit Noise Reduction? |
Hi All,
After reading all the helpful suggestions I now have a plan. I have ordered a propeller hub extension from Saber Mfg in TX. The prop will be moved back 3" to reduce tip noise.
Next I will be fabricating some filler panels to provide a physical barrier between the engine and the cockpit. On the panel side that faces the engine will have a soft acoustic material to reduce the noise further.
Finally, I will close off the cockpit with a bit more lexan windscreen material to minimize my exposure to engine noise.
Hopefully, My dear sweet wife will get me an ANR headset on my birthday/Fathers Day/Xmas to complete the noise reduction process.
I have tried the panel idea already and have had some sucess using just cardboard held in place with duct tape. The next step is to replicate the cardboard panels in foam and fiberglass to have some lightweight but stiff panels as the final product.
As the process evolves, I will try and keep everyone posted.
Best Regards
Carlos G
Steve Boetto
Posted: Thu Mar 06, 2008 4:26 am Post subject: FireStar Cockpit Noise Reduction? |
In a message dated 3/5/2008 9:55:56 P.M. Eastern Standard Time, grageda(at)innw.net writes:
Hi All,
Carlos,
Sounds like you bought #2 of 2 prototypes that Saber cut for me. I have not run mine yet but unless they re cut it you will have to make some custom washers. the clearance next to the inner hub is too tight for the bolt head. They could cut the inner spool to a smaller OD but they did not want to reduce it.
I bought some aluminum washers from ACS and knocked the edge off on the belt sander.
The reason for all the washers is because I used long enough metric bolts so as to have a grip long enough to all the way through the hub.
steve
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
24.18 KB |
449 Time(s) |
The BaronVonEvil
Posted: Thu Mar 06, 2008 8:55 am Post subject: FireStar Cockpit Noise Reduction? |
The BaronVonEvil
Posted: Sun Mar 16, 2008 8:11 pm Post subject: Re: FireStar Cockpit Noise Reduction? |
Hi All,
Well I got the prop hub extension on and tried it today. It made a noticeable difference in the cockpit noise. I took my Db meter with me and measured about a 3 to 4 db noise reduction in the cockpit area.
I also noticed the aileron torque tube on the right wing panel did not vibrate nearly as much as before.
Overall Id say that the extension of 3" did help significantly with the noise I was experiencing and reduced propeller tip pressure induced vibration to the airframe.
The propeller is now at about 5" from the aileron torque tubes and this seems to be the magic number.
I would recommend this modification for anyone considering it.
Again thanks for all the Advice,
Carlos G
AKA
BaronVonEvil
