New Builder - Tools
Goto page Previous  1, 2
jesse(at)saintaviation.co
PostPosted: Fri Mar 21, 2008 12:15 pm    Post subject: New Builder - Tools Reply with quote
I definitely have to go with John on the tungsten bucking bars. Just
the little one that Stein sells can now replace about 5 that I often
use. Well worth the money.
One word on Avery and Cleveland. They are both expensive and you can
find stuff cheaper...BUT...their tools are the best quality I have
used, from dimple dies and drill bits to squeezers. As far as I know,
a Sioux drill is a Sioux drill, so go for where you can get it
cheaper, but when it comes to stuff that isn't a specific brand, these
two companies are great to buy from. Believe me, I have tried quite a
few of them, and the more I try, the more I like Avery and Cleveland.
Speaking of Cleveland, as was already mentioned, their quick change
drill system is ABSOLUTELY FANTASTIC, but make sure you can get your
original chuck off your drill. I have only been able to get the chuck
off the Sious drills (and don't tell anybody, but I have destroyed 2
other drills trying to do the same to them, but they weren't Sioux).
When it comes to the actual tools, there are probably as many opinions
and preferences as there are RV-10 panel layouts. The Pneumatic
Squeezer is fantastic, but far from indispensible, IMHO. There are
many rivets I will use a hand squeezer on long before the pneumatic
because I have more control with the hand squeezer.
As John said, make your own list and check it twice. There is no one-
size-fits-all tool kit. As I often suggest to people, start with
budget (being realistic, of course), make a list and put the "must
haves" at the top, then the "really think I should have", then the
"wouldn't mind if I end up with" at the bottom. If you are building
alone and expect to take several years, start small and use ground
shipping. If you are full-time building and hope to be flying by
Oshkosh '08 (dream on!), then get more to start with and save the
overnight bills.
All IMHO.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 21, 2008, at 11:53 AM, John W. Cox wrote:
<johnwcox(at)pacificnw.com>
As another(A&P with IA and EAA TC) plus sometimes professional
mechanic
for the nation's top regional airline last year and an all too
sometime
RV builder, I second whole heartedly endorse Mike Crow's observation
from ATC as posted by Larry Rosen. My tool selection for the RV-10 is
far more vast than even the tools commonly used at work. Both have
their advantages. Often builders are quick to write an early check
and
make the quick selection process simplified. Make your own list and
check it twice.
I have found the use of pneumatic tools indispensible. Larry won me
over
with his Hardhat graphic on his website with a Pneumatic Jackhammer
operator. I would seldom resort to an electric powered hand tool -
since. I formerly and repetitively visited the late Boeing Surplus
store in Renton, WA which is now only a fond memory. Ebay is amazing
when you make a comprehensive list. Tungsten Bucking bars are the most
valued and borrowed tools I possess. Get some practical experience and
ask other builders their input. Knowledge of item A vs. item B. often
provides products which simplify the build and become a valued
asset. I
personally have two Sioux reversible drills which I love.
I have the utmost respect for those of you who continue to use a
mechanical hand squeezer or hand dimpler rather than the C214 style or
DRDT-2 dimpler (which has plans available). Randy Debauw, builder of
the first completed RV-10, enlightened me to the advantage of two or
three used drills (Pre-chucked with the correct bit size for time
efficiency). If you scan his file on Tim's site you may get a
glimpse of
the end of his workbench and down under the countertop a foot where
more
than a dozen such gems resided until needed. Several squeezers
(Preset)
makes the assembly a true pleasure. One vise mounted and the other
free
to roam in your hand. I have been surprised that more of you aren't
willing to part with such tools after the build is complete. There
is a
lesson in there somewhere.
Doug - Take the time to understand the process and the tools. Seek
multiple opinions. You're going to love this group of friendly
builders
with a common goal and passion.
John Cox
stein(at)steinair.com
PostPosted: Fri Mar 21, 2008 12:43 pm    Post subject: New Builder - Tools Reply with quote
I will ditto what Jesse said, but put special emphasis on Avery and
Cleaveland tool. Bob Avery and the Lauritsen clan are some of the best
people you'll ever deal with. Plus, they are both small family run
operations that truly care about each customer. I try pretty hard to split
any tool purchases I have between Avery and Cleaveland because I want them
to stay in business. Like us, they aren't always the cheapest, but they are
the best people I know in the business and their tools are top notch. We too
have worked on everything from 747's to Piper Cubs so our personal tool
assortment is pretty good (how many people need a 10X rivet gun) and I think
I've purchased tools from just about every place out there. For an RV
(we've built a good number of them too), I can't think of any reason not to
buy nearly all of your tools from either Avery or Cleaveland.
FYI...there has been a LOT of good information on this thread! That being
said, it really doesn't matter how big of a list you make, you'll still be
missing something. Part of the fun when doing a project like this is all
the treasure hunting you get to do for things like tools and such. I'd echo
what you've seen before. Buy a kit, then just buy the rest as you need it.
I'm sorry for the shameless plug, but as an RV builder myself I really like
to see people like those two companies get as much business as they can. I
don't have an affiliation with either company other than being a customer of
both - and a darned happy customer of both that goes back for more!
Sometimes price isn't the only thing to consider.....
Stein
[quote]--
av8or(at)cox.net
PostPosted: Fri Mar 21, 2008 1:04 pm    Post subject: New Builder - Tools Reply with quote
I echo the same and add Stein to that list....
#40626
"... put special emphasis on Avery and Cleaveland tool. Bob Avery and the Lauritsen clan are some of the best people you'll ever deal with. Plus, they are both small family run operations that truly care about each customer. I try pretty hard to split any tool purchases I have between Avery and Cleaveland because I want them to stay in business. Like us, they aren't always the cheapest, but they are the best people I know in the business and their tools are top notch. I can't think of any reason not to buy nearly all of your tools from either Avery or Cleaveland.
...as an RV builder myself I really like to see people like those two companies get as much business as they can. I don't have an affiliation with either company other than being a customer of both - and a darned happy customer of both that goes back for more! Sometimes price isn't the only thing to consider....."
Stein
LarryRosen
PostPosted: Fri Mar 21, 2008 2:53 pm    Post subject: New Builder - Tools Reply with quote
"Part of the fun when doing a project like this is all the treasure
hunting you get to do for things like tools and such."
About half way through you will start electrical wiring and then there
is a entirely new set of tools to purchase. And another set of quality
vendors supporting us RV builders, Stein being one of them.
Larry
Stein
Larry Rosen
#40356
N205EN (reserved)
<http>
Lew Gallagher
PostPosted: Sun Mar 23, 2008 5:11 am    Post subject: Re: New Builder - Tools Reply with quote
Hey Doug,
The guys here have been very helpful, but from observation and my own experience, they've neglected the very first "tool" ... these things apparently can NOT be built without a digital camera!
Also, what would be really helpful would be a list of all the acronyms ... IMHO (in my humble opinion). I still haven't figured out some of them! And as a non-pilot, you wouldn't believe the headaches I get trying to decipher all the avionics, mechanics, navigation, communication, etc. abbreviations. As with any new body of knowledge, I'm just immersing myself in it and waiting for it to "osmose".
This is a great resource, I check it every day.
Thanks to all.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
rene(at)felker.com
PostPosted: Sun Mar 23, 2008 5:33 am    Post subject: New Builder - Tools Reply with quote
Speaking of digital tools. A digital/electronic level and laser line. Got
mine at home depot.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Lenny Iszak
PostPosted: Sun Mar 23, 2008 7:18 am    Post subject: Re: New Builder - Tools Reply with quote
Doug,
I picked up the coolest little tool a couple of days ago. I was deburring holes with a larger drill bit, spinning it by hand. I got a slight carpal tunnel, and my hand started to get numb very fast.
Went to Lowe's and picked up this Dremel Driver. It's small, fits in your hand, the max rpm in 300, and the trigger is very controllable. You just have to use a drill bit with a hex shank. Check out the attached picture.
Bought my toolkit from Isham (planetools) because it included the pneumatic squeezer and the DRDT-2. I have this big grin on my face every time I use the dimpler Smile
I also picked up a hand squeezer from Avery. It's more accurate and has more control than the pneumatic one.
I bought some little stuff from different suppliers and so far Avery has been the fastest to ship my order.
This forum had been invaluable in researching the tools I needed. Thanks everyone!
 Filesize:  89.54 KB
 Viewed:  391 Time(s)
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
Page 2 of 2
