lbgjb10
Posted: Wed Apr 02, 2008 1:07 pm Post subject: Flap Switch |
anyone know where to get a flap switch--3 position like some use on the Infinity grip, but for panel mounting. I would like it to have a broader 'toggle' than standard toggle switch so I can tell by feel it is flaps. thanks
_________________ Larry and Gayle N104LG |
sam(at)fr8dog.net Guest
Posted: Wed Apr 02, 2008 1:52 pm Post subject: Flap Switch |
A/C Spruce has the infinity switches.
lbgjb10 wrote:
Larry N104LG
http://forums.matronics.com/viewtopic.php?p=174398#174398
lbgjb10
Posted: Wed Apr 02, 2008 3:23 pm Post subject: Re: Flap Switch |
thanks for the reply, but I want a functioning switch 'like' what is on the infinity grip, but for panel mounting not on the grip. AT A/C they had switches for the grip. I would like the 'handle' on the toggle to be flat rather than regular round toggle. lbb
Posted: Wed Apr 02, 2008 4:24 pm Post subject: Flap Switch |
The toggle switch on my infinity grip, that I use for the flaps is a
flat blade type. It could be used anywhere. You just need the correct
part numbers, which I unfortunately don't have at the moment. But I'm
sure someone on the list has them readily at hand.
bgjb10 wrote:
Larry & Gayle N104LG
http://forums.matronics.com/viewtopic.php?p=174426#174426
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Wed Apr 02, 2008 4:31 pm Post subject: Flap Switch |
Apparently they're pretty hard to come by. You might try one of the A/
C salvage yards, such as Wentworth in the twin cities.
Some folks here have "rolled their own" with appropriate machine
tools. They slipped a "home-made" flap-shaped Al cover on a standard
toggle, and held it in place with a set screw. That's beyond my level!
We put our flap switch inside a cage-like guard and just used a
standard toggle configuration. It's the only guarded switch on the
panel - I think that will work well, and it's protected from
accidental activation in turbulence, for example.
Good luck!
Marlys and John 40458
LarryRosen
Posted: Wed Apr 02, 2008 4:37 pm Post subject: Flap Switch |
On this subject, does anybody know how much power this switch needs to
handle when wired to the Showplanes FPS? I know the power connects
both to the FPS controller and to the switch, so a switch that is made
for 1A might not be desirable for a circuit with a 10A breaker for the
flaps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Deems Davis
Posted: Wed Apr 02, 2008 4:41 pm Post subject: Flap Switch |
t's a bit pricey, but here's a link to Pacific Coast who has a 'paddle'
type flap switch..
http://www.pca.aero/OnlineCatalog/PCA_pg40-41.html
Right side of page 3/4 way down page.
Looks like this installed. (see attached)
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Description: |
Filesize: |
43.56 KB |
Viewed: |
547 Time(s) |
Posted: Wed Apr 02, 2008 5:24 pm Post subject: Flap Switch |
lbgjb10 wrote:
I don't know what the postioons are for the infinity grip, so here's
some suggestions.
Make your own 'flap handle' like a flap section, drill a hole in the
hinge side and use some JBWELD to hold it on the switch handle. You can
buy switches with threaded handles too. Google 'electronic parts'
..... jameco mouser allied digikey are all possibilities. You can get
flat handles ..... maybe 1/4" wide but I think you'd rather have
something 1" wide. Also, you want a round one (lollipop) for the gear
switch.
You can also go to http://www.fletchair.com/ and order a flap switch for
a 2-place grumman. It has a center off, momentary (for flaps down .....
you hold it) and the other way is up (not momentary).
Linn
Posted: Wed Apr 02, 2008 5:31 pm Post subject: Flap Switch |
Jesse Saint wrote:
to handle when wired to the Showplanes FPS? I know the power
connects both to the FPS controller and to the switch, so a switch
that is made for 1A might not be desirable for a circuit with a 10A
breaker for the flaps.
Remember that breakers are there to protect the wiring ...... the
devices connected to a 10A breaker may be very small current
consumers. However, this doesn't really answer the question either!
Linn
Quote: |
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
