dave
Posted: Sun Apr 06, 2008 9:51 am Post subject: Re: CGS Prop blades Loose |
The prop in question was a NSI hub that failed. Gary is a good friend and close neighbour. Lance Wheeler from NSI did nothing to help Gary if I recall correctly. Lance Wheeler had a reputation of not being the most honest person to deal with.
I had another prop near me depart a blade and yes it was a GSC wood prop. I have also see other brands including IVO shed blades. I had a blade departure my self once and you what results is a sonic like boom as your windshield blows out and the engine gets torn from the mounts. I deadsticked with no damage into a field. Put on trailer and took back to shop. This company unlike NSI replaced all damaged equipment including a NEW engine and PROP. There are very credible and we continue to sell their props.
I have at least 6 different props in stock now for demos for 582 tractors If anyone wants to fly in and try one or spend a day trying different props that can be arranged.
| Quote: | Noel
The blade that departed was on a float plane and was a composite blade not a
GSC and it happened to the fellow out of Montreal if I remember correctly.
It had something to do with the hub. His picture showed the departed blade
impaled into the front of the float. I think the fellows name is Gary and
his arcft was C-GOOT.
I think the above info is correct --- perhaps Gary could elaborate on this
as I am sure he is aware of the incident if it wasn't him.
DO NOT ARCHIVE
Ted Palamarek |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
clint_bazzill(at)hotmail. Guest
Posted: Sun Apr 06, 2008 3:30 pm Post subject: CGS Prop blades Loose |
If you claim that an IVO prop had a failure, please supply list with that information. I think you are wrong about that and give people bad impressions. Clint
| Quote: | Subject: Re: CGS Prop blades Loose
Date: Sun, 6 Apr 2008 10:51:09 -0700
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
> Noel
> DO NOT ARCHIVE
> Ted Palamarek
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=175092#175092
helili(at)chahtatushka.ne Guest
Posted: Sun Apr 06, 2008 4:16 pm Post subject: CGS Prop blades Loose |
Google comes up with a whole bunch of IVO prop failures.
John Hart
Kitfox IV
Wilburton, OK
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Sunday, April 06, 2008 6:28 PM
Subject: RE: Re: CGS Prop blades Loose
> From: dave(at)cfisher.com
> To: kitfox-list(at)matronics.com
[quote] [b]
dave
Posted: Sun Apr 06, 2008 5:24 pm Post subject: Re: CGS Prop blades Loose |
Clint , like others said lots on google as well.
Here is one of my own pics
Sounds like you never heard of a IVO failure >? Like i said all props die from time to time
34.55 KB |
509 Time(s) |
Float Flyr
Posted: Sun Apr 06, 2008 6:50 pm Post subject: CGS Prop blades Loose |
New... Over five years old??? GSC has a TBO on the blades something like
five years or 500 Hr....Whichever first.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sun Apr 06, 2008 6:59 pm Post subject: CGS Prop blades Loose |
The very first Ivo I saw had issues... Since that time I have used an Ivo
myself with excellent results. The issue with the first prop I think was
caused by not using an accurately calibrated torque wrench.
All composites, whether in a prop or the cowl of a jetliner require special
handling and react a lot differently than wood or metal. So much for the
obvious!
Noel
Kitfox III-A
propellerdesign(at)tele2. Guest
dave
Posted: Mon Apr 07, 2008 12:23 am Post subject: Re: CGS Prop blades Loose |
GSC blade departure.
This one happened a few miles from me 2 years ago. I ended up straightening and welding up the engine mount, fixing the cowl damage replacing the engine and gear box with a brand new unit. And of course a new prop. The owner went to a GSC again after having used GSC for over 20 year he was more than sold on them.
When this on departed he was not airboune but taxing back to shop and that blade departed just a few feet from hangar door. Owner was 84 years old at the time and still flies daily once snow melts. His snow drift almost gone this week and expect him out this week one day.
THis prop to my knowledge always had a good gap on aluminum blocks and was never over tightened, but it was over 5 years old.
95.59 KB |
458 Time(s) |
mikeperkins
Posted: Mon Apr 07, 2008 6:12 am Post subject: CGS Prop blades Loose |
There’s something that CAN be done if the blades of a GSC prop are loose because the hubs are touching.
I’ve owned my Model 1 with the GSC prop for 14 years and I never overtorqued the bolts, ever. (I’m the only one who’s ever worked on my Kitfox). I’ve always used the recommended 10 ft-lbs and always carefully “snuck up” on the final torque during the torquing process. Yet after about five years, the hubs nearly touched. I had a machinist plane off 0.010” from both inside hub faces on a milling machine. Since then, about 11 years now, they are nearly touching again, but re-torquing does not bring them any closer.
To insure the blades are secure, my annual inspection not only includes re-torquing the bolts but also involves putting a “wrench” on each blade to insure it doesn’t turn. I’ve found that as long as I have the proper torque on the bolts and the hubs aren’t touching, there’s no way to rotate a blade without breaking it.
Mike Perkins
GONER752(at)aol.com Guest
Posted: Mon Apr 07, 2008 2:17 pm Post subject: CGS Prop blades Loose |
Mike,
Correct me if I'm wrong,but, isn't it 100 inch lbs.?
Been awhile since I did mine, but that sounds familiar.
Greg G.
In a message dated 4/7/2008 10:15:42 A.M. Eastern Daylight Time, Michael.Perkins(at)Rauland.com writes:
Mike Perkins
f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Macedon, N.Y.23NKn375KLMod 2582 Macedon, N.Y.23NKn375KLMod 2582 Macedon, N.Y.23NKn375KLMod 2582 Macedon, N.Y.23NKn375KLMod 2582 |
Planning your summer road trip? Check out AOL Travel Guides.
Posted: Mon Apr 07, 2008 4:45 pm Post subject: CGS Prop blades Loose |
Never heard of one leaving a 912 Clint
[quote] =================
dave
Posted: Mon Apr 07, 2008 5:10 pm Post subject: Re: CGS Prop blades Loose |
Mike, you are playing with luck right now -- well past TBO and over torquiing. GSC calls for 8 foot lbs ( 100 inch /pounds. )
That last pic i sent had never been over tightened but it still failed.
| Quote: | There’s something that CAN be done if the blades of a GSC prop are loose because the hubs are touching.
Mike Perkins |
dave
Posted: Mon Apr 07, 2008 5:13 pm Post subject: Re: CGS Prop blades Loose |
Clint,
Correct me if I am wrong but there was a guy on this forum in hte last 6 months that had a GSC fail or come loose or something like totally depart his Kitfox with a 912. Surely it will be in the archives.
CLint , also -- did I miss your report on VGs ?
Dave
| Quote: | clint_bazzill(at)hotmail.
Posted: Mon Apr 07, 2008 8:45 pm Post subject: CGS Prop blades Loose
Posted: Tue Apr 08, 2008 9:13 am Post subject: CGS Prop blades Loose |
I haven't got all the information together yet on the VG's. I have seen IVO props with part of the prop missing from something going through it on a pusher. I have seen props stricking ground, and being beat up pretty badly, but not a blade leaving a 912. Clint
[quote] Subject: Re: CGS Prop blades Loose
Date: Mon, 7 Apr 2008 18:13:22 -0700
Clint,
Dave
> Guest
http://forums.matronics.com/viewtopic.php?p=175380#175380
dave
Posted: Tue Apr 08, 2008 1:28 pm Post subject: Re: CGS Prop blades Loose |
Clint,
read about a 912 blade departure here
http://forums.matronics.com/viewtopic.php?t=41907
looking forward to reading about your VGs.
Mine work ok , I have not removed yet but no big gains like others claim.
Maybe I have to play around and adjust mine more ?
kitfox_robert(at)yahoo.co Guest
Posted: Tue Apr 08, 2008 6:40 pm Post subject: CGS Prop blades Loose |
Hi Pete, IVO and GSC hubs are not interchangeable.
Robert
San Diego
Former II/582
V/0200 N200KF
Do not Archive
Float Flyr
Posted: Thu Apr 10, 2008 4:47 pm Post subject: CGS Prop blades Loose |
When you get your new prop, calibrate your tach to make sure you are putting
as much power as possible into the prop.
Noel
Kitfox III-A
roncarolnikko(at)hotmail. Guest
Posted: Thu Apr 10, 2008 8:06 pm Post subject: CGS Prop blades Loose |
They both share the same Rotax bolt pattern so yes the whole prop will bolt on in place of the other whole prop. Ron NB Ore
[quote] Date: Tue, 8 Apr 2008 19:37:42 -0700
Subject: Re: Re: CGS Prop blades Loose
.ExternalClass DIV {;} Hi Pete, IVO and GSC hubs are not interchangeable.
Robert
San Diego
Former II/582
V/0200 N200KF
Do not Archive
richs(at)presys.com Guest
Posted: Thu Apr 10, 2008 8:35 pm Post subject: CGS Prop blades Loose |
Hi Ron, I'm working my way back to NB. Presently in Carson City. See you next week. Rich
Float Flyr
Posted: Fri Apr 11, 2008 5:26 am Post subject: CGS Prop blades Loose |
Hubs are completely different... Putting a square pin in a round hole would be easier! The bolt pattern is consistent
Noel.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Robert Harris
Sent: Wednesday, April 09, 2008 12:08 AM
Robert
San Diego
Former II/582
V/0200 N200KF
Do not Archive
Kitfox III-A
