jerry(at)jerryhey.com Guest
Posted: Tue Apr 08, 2008 1:09 pm Post subject: 601 crashes |
I am not a 601 builder or pilot. My heart goes out to all the 601
guys. I would not take a demo ride in one until what is going on is
understood and remedied.
I am about to start scratch building a 701. I have built tube and rag
in the past.
The 601 crashes have caused me to take another look at the 701. Quite
honestly, I love this airplane and it is probably strong enough to
never have a structural failure BUT nobody could call it rugged. The
thin skins, widely separated ribs, continual talk about oil canning.
I can imagine ia 701 is not difficult to dent. Perhaps the trade off
of structure vs weight has tilted too far toward light weight. Maybe
that is true but just for me. Others would quite rightly feel different.
I would not mind adding a few pounds of toughness to my airplane.
Jerry
John Bolding
Posted: Tue Apr 08, 2008 2:09 pm Post subject: 601 crashes |
The 601 and 701 are VERY far apart in design . not even apples and oranges,
more like apples and a Buick.
The 701 has been around for almost 20 yrs (1986 I think) and until recently
when a pilot dug in a wingtip on a low, LOW buzz job , there had never been
a fatality in one. In the homebuilt arena that is almost unheard of. It may
even be the only design that can claim that. Remarkable considering how
many there are and the conditions they are flown in.
Be cautious about adding "toughness" without proper engineering, making
things worse is EASY to do when you change highly loaded, lightweight
structures willy nilly.
Speaking about engineering, you guys gonna keep wringing your hands and
whining or DO something?? LO&SLO John
ggower_99(at)yahoo.com Guest
Posted: Wed Apr 09, 2008 5:49 pm Post subject: 601 crashes |
You can make a deal with yourself and with the 701... (Just talking, I dont know you or seen a photo of yourself)
For every pound of weight you loose (until you reach 150 lbs), add the same in extra aluminum skin thickness in the 701 so the plane performs as advertised
Sorry for the joke
The 701 is a great airplane for more than 25 years (maybe more) of no fatalities (but only one: the recent recless flying wing strike to the floor) .
YES, we all are waiting for the results of this accidents research in the XL's , I thrust Mr Heintz and Family with the results and any advised correction IF needed.
I will gladly rebuilt any part if advised.
For now, seems that the Australian plane had the wings attached once they found it in the ocean. so no structural failure in this wings, in this case..
Saludos
Gary Gower.
Jerry Hey <jerry(at)jerryhey.com> wrote:
[quote]--> Zenith-List message posted by: Jerry Hey
in the past.
thin skins, [quote][b]
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Thu Apr 10, 2008 2:29 pm Post subject: Re: 601 crashes |
Jerry,
You worry about .016" skin and yet you happily (I assume) have flown in rag wings? (I have done the same and am not in any way putting them down) I'd put .016" AL up against fabric any old day. I'm sure rag wings oil can too, we just don't have the ability to hear it. Have you purchased the .016" yet? It is not the foil that you may think it is. The 701 has an impeccable safety record and I have no worries about it. The Savannah has longer wings, a higher Vne and a higher gross. Yet it is not as ruggedly built as the 701, I may be wrong(I don't think so though) but I believe it to be a slightly moded non-SP (early model) 701. I have the Savannah upgrade instructions for the higher gross and it is not much!
Build your airplane and fly safe and you will be safe.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Apr 10, 2008 3:49 pm Post subject: Re: 601 crashes |
You're talking Apples and Oranges when you compare a ragwing to a Zenith. I also own a ragwing (Champ) and the fabric covering is for the most part just a cover. The strength in the fuselage comes from the welded tube frame. In the wings, there is internal cross bracing between the spars while the ribs are held in position by nails in the spars and tiny screws thru the fabric into the rib flange.
In semi monocoque construction like the Zenith (and Cessna, Piper, et al) the skin is indeed a structural component. It serves not only as a aerodynamic cover but also holds all of the underlying skeleton in position and helps transfer and distribute the flight loads. Although the individual pieces may seem flimsy, when joined together you can create a robust structure that performs well.
My wife helped me move the tail section of my XL fuselage out into the main hangar today and she was not impressed. I'm not sure I convinced her that the finished product will be strong enough to carry us aloft. For the time being she is giving me the benefit of the doubt.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
notsew_evets(at)frontiern Guest
Posted: Thu Apr 10, 2008 4:27 pm Post subject: 601 crashes |
" Eggshell "
kmccune
Posted: Thu Apr 10, 2008 5:21 pm Post subject: Re: 601 crashes |
I agree, but it is the perception, that is being questioned and Jerry offered up the rag wing. Its not like the skin will fatigue any sooner then the fabric will rot a few times on your champ. But your cloth is indeed part of your fuselage, remove it and see if it flys.
BTW: My next build is going to be a ragwing Cub like something or other.
| Tim Juhl wrote: | You're talking Apples and Oranges when you compare a ragwing to a Zenith. I also own a ragwing (Champ) and the fabric covering is for the most part just a cover. The strength in the fuselage comes from the welded tube frame. In the wings, there is internal cross bracing between the spars while the ribs are held in position by nails in the spars and tiny screws thru the fabric into the rib flange.
Do not archive |
Dorothy McCune |
Tim Juhl
Posted: Fri Apr 11, 2008 3:12 am Post subject: 601 crashes |
kmccune
