Doors coming off
Goto page Previous  1, 2
VHMUM(at)bigpond.com
PostPosted: Fri Apr 11, 2008 1:27 pm    Post subject: Doors coming off Reply with quote
"I also heard several post say to reach back and feel that the pin has gone through the door guide. " Guys this is rediculous we need a fix so that whoever can jump in and fly the plane and believe that the doors will not fly off. I mean would the public tolerate it if a car door fell off? Why should we. We need a fix so that you can get in shut the door "thats it" No checking pins or reaching behind the seat etc etc.
Ok so I am not convinced about this flexing yet as we cannot be sure the doors that have come off had the rear pins into the fuse (shut properly). So if this is the problem then Iflyrv10.com door guides will fix the problem as the door pins are guided into place. If we are saying there is flexing and the pins pop out then maybe tempory fix would be what Andre has done in here in AUS.
About to do first flight in a few weeks and i do not want to have to think about closing a bloody door or shouls I say a door coming off.
Keep thinking guys
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> reggards Chris 388
PostPosted: Fri Apr 11, 2008 1:41 pm    Post subject: Doors coming off Reply with quote
The after market door guides seem a good idea and I believed that one of the advantages of these was that you were able to shorten the rods so that if you accidently closed the door with the handle in the open position the pins would not hit the outside of the fuse stuffing the paint. This ofcourse means that with the door closed the pins would go through the after market guide but not the fuse.
Just a thought
regards Chris
Kearney(at)shaw.ca
PostPosted: Fri Apr 11, 2008 2:15 pm    Post subject: Doors coming off Reply with quote
Chris
6nbsp;
I have to say I agree with 6nbsp;you E An unclosed door should not result in an major emergency 6nbsp;in an un-pressurised 6nbsp;a/c E This problem C if not corrected will be an accident waiting to happen E It is a bit like the 6nbsp;Far Side cartoon the had a 2Wings Off 2 button on the arm-rest 6nbsp;of an airline passengers 6nbsp;seat E The questions 6nbsp;is not how to prevent the button being pushed but why it was there in the first pace E
6nbsp;
I know the risk can be mitigated by checking C with warning lights etc E But somewhere along the way C the failure chain will catch up with someone E
6nbsp;
Flying my Cherokee C part of the passenger 6nbsp;brief is that they should un-latch 6nbsp;the door in the event of an emergency 6nbsp;so the door does not jam upon landing E I am reluctant to use the Auzzie 6nbsp;fix as it may trap you in the a/c in the event of a crash E
6nbsp;
So rather than 2fixes 2 C what would be the 2Gold Standard 2 solution?
6nbsp;
Inquiring minds need to know E E E E
6nbsp;
Les 6nbsp;Kearney
340643
rene(at)felker.com
PostPosted: Fri Apr 11, 2008 2:18 pm    Post subject: Doors coming off Reply with quote
That is the way mine are set up. After all the discussion, I am considering changing that and lengthening the rods and getting the pin to go through the frame. Have not really decided yet. Maybe I will have one of the ME’s here give me an opinion about the strength of the AL block with the two bolts. My general feeling is that I am ok since those two bolts have a lot of strength in sheer.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough
Sent: Friday, April 11, 2008 3:37 PM
Subject: Re: Doors coming off
Just a thought
regards Chris
acs(at)acspropeller.com.a
PostPosted: Fri Apr 11, 2008 2:41 pm    Post subject: Doors coming off Reply with quote
Chris, I don't know how much can be gleaned from the latest? incident as some of the posts allude to the door coming off on a subsequent flight after the 4g crash/landing.
Maybe there wasn't a straight section left on this machine. In any case who would go flying in an aircraft with that much prior damage unless you had a special permit to return it to a maintenance workshop? Maybe the door popped out during the crunching landing. Have a look at the deformation on the glareshield. I'd be interested to see what the damage was/might be where the brace attaches to the cabin cover. I don't think well made RV-10's have a case of the door falling off, I think it's more a case of checking to see if it's properly closed. The same thing you'd do when you jumped in the family car.
Maybe the answer is a safety catch, sliding window bolt variety, at the rear attached to the lower door aimed down to the inside of the lower sill?
I'm interested in hearing Rene's report on the door in flight flexing because I reckon this would be the most likely scenario to ripping a door off especially if a significant gap opens up towards the airflow.
John 40315
rene(at)felker.com
PostPosted: Fri Apr 11, 2008 2:56 pm    Post subject: Doors coming off Reply with quote
I did not get to check the in flight flexing today…….will have to fly some other day to do it….darn. My wife is out playing this weekend…hockey….so it might not be able tofly until some time next week.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne
Sent: Friday, April 11, 2008 4:36 PM
John 40315
dlm46007(at)cox.net
PostPosted: Fri Apr 11, 2008 3:00 pm    Post subject: Doors coming off Reply with quote
The Gold standard solution is found on the SR22; forward hinged door and rear/top/bottom latch pin/pins. That solution would require some major re engineering by Vans which is unlikely. In the short run, install a small handle on the aft part of the door to aid in closing from the inside on the ground. Then check your pins by feel or use the system. Do not shorten the pins so that they do not penetrate the door jambs; this is a recipe for disaster if the beveled tips hit anything where they will be stressed/abraded etc. Eventually they may be just short enough to slip out, given the flex of the door and the flex of the rear pushrod. IIRC it was bent slightly to match the curvature of the door. For 29 years I closed the passenger door on my Cardinal RG; not because it would depart the aircraft but the passenger could damage the door. The handle had a shear pin in it so that when the locking bar was pushed aft, it would shear if the bar was not properly positioned and was striking the door frame. I always locked the door to prevent my passenger from disabling the aircraft and creating a maintenance job for me. IIRC I posted a passenger warning placard in the 10 stating that my aircraft does not conform to certification standards. In my cases it meets or exceeds them but in the case of the doors I don't think it does.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY
Sent: Friday, April 11, 2008 3:11 PM
Chris
I have to say I agree with you. An unclosed door should not result in an major emergency in an un-pressurised a/c. This problem, if not corrected will be an accident waiting to happen. It is a bit like the Far Side cartoon the had a "Wings Off" button on the arm-rest of an airline passengers seat. The questions is not how to prevent the button being pushed but why it was there in the first pace.
I know the risk can be mitigated by checking, with warning lights etc. But somewhere along the way, the failure chain will catch up with someone.
Flying my Cherokee, part of the passenger brief is that they should un-latch the door in the event of an emergency so the door does not jam upon landing. I am reluctant to use the Auzzie fix as it may trap you in the a/c in the event of a crash.
So rather than "fixes", what would be the "Gold Standard" solution?
Inquiring minds need to know ....
Les Kearney
#40643
tomhanaway
PostPosted: Fri Apr 11, 2008 4:28 pm    Post subject: Re: Doors coming off Reply with quote
I'd like to see Jesse S. hop in here when he gets a chance. I understand he's a little busy right now
Wink
I looked at his door at Sun & Fun today. Looks like he added both a small interior handle near the rear of the door and a secondary latch that seals the inside front side of the door.
Tom H.
billderou(at)yahoo.com
PostPosted: Fri Apr 11, 2008 8:46 pm    Post subject: Doors coming off Reply with quote
I looked over the pictures of the door departure and noticed something in the upper hinges.
It looked like the area around the hinges had little resin between the two surfaces.
Also, the screw heads were flattened to bury them in resin so they would not turn when tightened from below. I would guess this was to create a beautiful look to the top of the door with no screw head showing. However, the shear force is absorbed at the large diameter of the screw head and the mating nut surface. Any grinding of the screw head removes area available for shear and its only shear that is securing the top of the door to the hinges. The deeper the screw head is set into the door the less holding strength is available from the fiberglass. So burying the screw heads cause two problems, and if they are over torqued cracking the fiberglass a third problem arises.
Are others using this technique to make their doors beautiful?
Look carefully at the rear door guide/protector/fuselage hole - it would appear that the rod never reached far beyond the teflon guide, otherwise the protector would be torn off.
Bill DeRouchey
N939SB, flying
tomhanaway <tomhanaway(at)comcast.net> wrote:
[quote]--> RV10-List message posted by: "tomhanaway"
[Wink]
Tom H.
Read this [quote][b]
PILOTDDS(at)aol.com
PostPosted: Fri Apr 11, 2008 11:25 pm    Post subject: Doors coming off Reply with quote
Worth mentioning is many light twins,for example a c-310 can lose a door if it comes unlatched during flight.This is clearly creating a problem on the rv-10 and we need to come up with a secondary latch system that can be released from the outside if rescue is necesary.I used a canopy latch on the forward bottom of the doors.A seemingly simple solution but does not allow rescuers easy access to the cabin.Do cessna aircraft allow outside door entry if the handles are in the down position as in normal flight?     728DD 175 hours
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
(http://money.aol.com/tax?NCID=aolcmp00300000002850) [quote][b]
james.k.hovis(at)gmail.co
PostPosted: Sat Apr 12, 2008 4:17 am    Post subject: Doors coming off Reply with quote
Typically, a fastened shear joint is designed so the entire shear
force is transferred in the shank of the fastener, not in the head,
even in a countersunk head. Also, having threads in bearing on the
structure is a no-no. Tension loads would be transferred by the
fastener head and nut, but typical aircraft design practice is to
design for shear loadings at joints whereever possible. That said, I
don't think there's anything wrong with the design of the -10 doors.
If the latching pins are engaged well, the hinges look robust engough
for the air loadings. As is inherent with gull-wing door designs, once
a door opens in flight and swings out past the boundary layer, it
basically becomes another short, fat wing. At 80+ knots, that results
in a rather large increase in the forces acting on the door and would
result in failures as seen in this discussion. I'd like to see if
there's a history of door failures on certified aircraft with
gull-wing doors.
KH
the upper hinges.
surfaces.
problem arises.
Bill DeRouchey
N939SB, flying
[Wink]
Tom H.
http://forums.matronics.com/viewtopic.php?p=176289#176289
PostPosted: Sat Apr 12, 2008 4:24 am    Post subject: Doors coming off Reply with quote
Thanks Tim. Just my opinion: mag sensors are notorious for having a
wide sensing range. I think micro-switches can be rigged to a finer
setting to verify proper pin engagement.
On 4/11/08, Tim Olson <Tim(at)myrv10.com> wrote:
That's what the door sensors van's provides do...they're magnetic
sensors, and there are magnets in the tips of the pins.
James K Hovis wrote:
> Being a lurker, I've read this thread with interest. Just to make a
> general comment, for good structural "retention" of the door, I feel
> the best set-up is for the door pins to pass completely through the
> opening frame on the fuselage. Of course, I'm basing this on the
> pictures I've seen so far. How does the warning light system "sense"
> full locking with the "blueprint" set-up for the door? Seems to me it
> would be a simple matter to add a couple micro-switches to the back
> side of the door frames so they light up (or better turn off a light)
> when the pins are fully engaged into the frames therefore indicating
> proper lock.
Lew Gallagher
PostPosted: Sun Apr 13, 2008 7:47 am    Post subject: Re: Doors coming off Reply with quote
Door latch picture ... (Sorry, I couldn't resist!)
James, I agree about the micro switches -- if you play with the magnetic switches provided (ohm meter on the leads while you move the magnet around the sensor), there's really quite a wide range. I was resigned to adjusting it while installed to find a true closed reading, but I'd prefer micro switches.
Thanks, Tim -- the bevel only makes sense to pull the door in.
And I'm really not comfortable with a threaded joint anywhere near the shear point.
Later, - Lew
 Filesize:  64.96 KB
 Viewed:  392 Time(s)
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
dlm46007(at)cox.net
PostPosted: Sun Apr 13, 2008 8:35 am    Post subject: Doors coming off Reply with quote
You have threads (plans call for a tap) there already; its just a question
of whether you fill them with something. The bevel is required but the
length of it is the question. Van's bevels range in size from .5" to '9".
Lew Gallagher
PostPosted: Sun Apr 13, 2008 5:35 pm    Post subject: Re: Doors coming off Reply with quote
Ahhh, the threads in the end of the rod.
I had asked earlier (and don't remember a response) about if the only reason to thread the end of the rod was to put a center marker in it to mark the sill. If so, seems like overkill when a marker can be put in there to do the same thing (a pencil is the right diameter), whether threads weaken the rod or not.
Folks are leaving the bolt in there and grinding it flush with the taper for strength? The AL rod isn't strong enough? OK, but I didn't like the idea of screwing in a bullet tip to extend the rod -- which I envision having to grind off the original taper, then the threaded joint would be very close to a shear point ... ?
Later, - Lew
non-pilot
Fly off completed !
Page 2 of 2
