				 Posted: Sat Apr 26, 2008 8:20 am    Post subject: The accident versus ready to fly aircraft |
				Hi guys,
 Yesterday, my over zealous “spam-protection” ate a dozen emails that
 were sent me on this issue, so I’m going to try a blanket answer with a
 “do not archive” that only reflects my view. If there was a specific
 technical question on an item, please do not hesitate to resend your
 email. Thanks again, Larry McFarland
 Professionally, I’ve only “studied” fatigue testing and failure on
 mechanical and structural elements, so I’m not qualified to make any
 statements that could prove anything. That experience did provide
 valuable insight on a few of the things seen in the images. After
 reading the NTSB sequence of events, I put the images on my computer to
 take an only slightly closer look via Photoshop, and did come to some
 conclusions on the damage characteristics. NTSB may offer a general
 statement, but the specific cause may never be answered in their report
 unless they take time to thoroughly investigate manufacture process,
 assembly errors and variant materials in the plane.
 The observed leveling and low altitude suggests the pilot was aware of a
 progressive structural failure.
 Complete failure of the center section front spar between and below the
 end points is telling. Bending stresses causing the center spar web and
 caps to crack and separate along lines nearly parallel to it, given the
 flight path, was progressive. Impact would not likely push or pull a
 long fractured line in the same direction as the design stress, but the
 length of center spar fracture and break up was so complete that it
 suggests that the shock that permitted folding wing(s) began here.
 The loss of a rear spar attachment and flap could very well create
 excessive stress on the front spar, break the bottom caps, and initiate
 collapse of the wing(s).
 The clean sheared rivet lines on the bottom spar cap versus the material
 that was last to tear from the top cap suggests that the web to cap line
 was torn from between the spar caps before being separated from the
 fuselage. Extensive separation of the center spar from top and bottom
 components far exceeds the damage seen in the wing, still attached. The
 fractures are not peeled and are parallel with the line of stress and
 are seen in the straight portions of still connected web and upper cap
 image 27. Broken out bolt holes are clean and likely impact related. The
 origin of failure is nearer the front lower spar cap and web than within
 the wing.
 . The original still flying XL demo plane is representative of all the
 XLs flying today and it strongly argues the case for a defective
 material or construction process by the actual foreign manufacturer of
 the quick-build or ready to fly aircraft. It’s not the result of a
 defective design material or process call out in the Zenith plans.
 Example: If pre-punched holes for the spar web didn’t match the caps,
 would the manufacturer just drill open the holes and continue to rivet?
 Very possible for people paid on product-volume, but I doubt a kit
 builder or scratch builder would ever tolerate such practice.
 I believe the plans to be “golden” and safe for both the kit and the
 scratch builder. The 601XL is a fine aircraft that will be around for a
 long time, so stay the course and keep on building.
 <http://www.macsmachine.com/> Do not archive
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		cookwithgas
				 Posted: Sat Apr 26, 2008 9:57 am    Post subject: Re: The accident versus ready to fly aircraft |
				Thanks Larry for your thoughtful input.
 This morning I put just over an hour on my 601XL and felt very good about it.  It flies like a dream and I have to pinch myself because I can't believe I built it and that it flies that well.
 I did a more thorough than usual pre-flight and found everything to be solid and tight.  The design is good and all the hard work has paid off with a very nice aircraft.
 For those still building, don't be discouraged.  Do quality work and you will have a well-built, safe aircraft.
 Scott Laughlin
 601XL/Corvair
 Finished & Flying as much as possible.
				 Posted: Sat Apr 26, 2008 1:01 pm    Post subject: The accident versus ready to fly aircraft |
				Righ ON! I just came back from flying and I as well am inspecting the plane throughout.  Scott please send more pics of your flying, I love those vids!  Sorry I missed you at the BBQ!
 Juan
		wjones(at)brazoriainet.co Guest
				 Posted: Sat Apr 26, 2008 1:42 pm    Post subject: The accident versus ready to fly aircraft |
				Hello all you newly licensed 601XL pilots . Did you use DARs or FAA ,if so
 was any special inspection requirements imposed since  3/1/08 . My local DAR
 said that he received information from the FAA that he must check to see if
 any additional inspection requirements apply to the 601XL .
 Wade Jones    South Texas
 601XL plans building
 Cont. 0200
				 Posted: Sat Apr 26, 2008 2:27 pm    Post subject: The accident versus ready to fly aircraft |
				Wade,
 we went to a DAR, and my thoughts on your DAR's comment,  Go to another DAR.
 JUan
		cookwithgas
				 Posted: Sat Apr 26, 2008 3:31 pm    Post subject: Re: The accident versus ready to fly aircraft |
				I used the FAA.  LOOONG wait and very picky.  My inspector told me that if I flew with my ever-so-slightly-slanted N-numbers that he would write me up.  Never mind that I bought them from Aircraft Spruce specially made.  His interpretation of "block letters" is plumb vertical with no slant.  While he was there he did a ramp inspection on a crop duster and busted him.
 I sent my paperwork off in May and I got my pink slip in December, 2007.
		sdthatcher
  Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
				 Posted: Sun Apr 27, 2008 6:23 am    Post subject: The accident versus ready to fly aircraft |
				Just a quick note for those who are concerned about flying their 601XL amid
 the recent accident paranoia (I include me as well).
 Use a Borescope: The 601XL that sustained vibration damage during a
 descending turn and who has successfully repaired that damage has mentioned
 that prior to his first flight, he used a borescope to inspect the inside of
 the wing, spar and caps, and found them in excellent condition. He was
 planning to fly shortly.
 Nylon Flap Stop: Also, another reminder to be sure you have installed the
 nylon flap stops as indicated in the plans. I have seen two aircraft without
 them and one stated that he felt vibration in the wing during cruise flight!
 The flaps should not exhibit any movement whatsoever when in the up position
 and the nylon stop guarantees that condition will apply. Naturally, when you
 lower the flaps, there is a certain amount of movement however the speed at
 which you lower the flaps is (should be) significantly lower.
 Getting ready for first flight this month!
 Scott Thatcher, Palm Beach Gardens, FL
 601XL with Corvair, Registered as E-LSA
 N601EL, http://placestofly.com, EAA203
  _________________ Scott Thatcher, Port Saint Lucie, FL
N601EL, EAA203 140 hours and not flying currently. |
				 Posted: Sun Apr 27, 2008 7:01 am    Post subject: The accident versus ready to fly aircraft |
				ok, I give...  What Flap stop ?????
		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Sun Apr 27, 2008 7:39 am    Post subject: Re: The accident versus ready to fly aircraft |
				 	  | sdthatcher wrote: | 	 		  The 601XL that sustained vibration damage during a
 descending turn and who has successfully repaired that damage has mentioned that  |
 What vibration damage...?
 This sounds like another data point.
 And something we should add to the list of things to check.
 Patrick
 XL/Corvair
 N63PZ (reserved)
		Jaybannist(at)cs.com Guest
				 Posted: Sun Apr 27, 2008 7:51 am    Post subject: The accident versus ready to fly aircraft |
				Steve,
 See Drawing 6-S-3.
 Jay in Dallas
				 Posted: Sun Apr 27, 2008 8:06 am    Post subject: The accident versus ready to fly aircraft |
				OMG !
 I love this website !!!
 SW
		sdthatcher
				 Posted: Sun Apr 27, 2008 6:14 pm    Post subject: Re: The accident versus ready to fly aircraft |
				<<What vibration damage...?
 <<This sounds like another data point.
 <<And something we should add to the list of things to check.
 <<Thanks,
 <<Patrick
 <<XL/Corvair
 <<N63PZ (reserved)
 Hi Patrick. A 601XL sustained rapid vibrations of the wings during a descending turn. I published the data on this site some time ago but the summary basically stated that a fix was attempted to a damaged rudder which shifted the CG of the rudder rearward and may have contributed to the vibrations which went through the fuselage and wings and may have been exacerbated by pilot induced response to the vibrations.
 If you were referring to the flaps, this was mentioned to me by another pilot while visiting a hangar that housed a 601XL and was missing the nylon flap stops.
		lgingell
  Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
				 Posted: Mon Apr 28, 2008 9:06 am    Post subject: Re: The accident versus ready to fly aircraft |
				My 6-S-3 from 12/03 has no nylon flap stops on it.  Someone care to post a scan?
 ..lance
  _________________ Zodiac XL/Jab 3300
http://lancegingell.com |
				 Posted: Mon Apr 28, 2008 10:25 am    Post subject: The accident versus ready to fly aircraft |
				I didnt think mine did either til I looked again.  It shows a 90 by 25 mm
 1/8 nylon piece (2) that goes under the flange of the drag spar .  I removed
 the three rivets from point of rib 7 outwards....
 Whalla! I have a stop....
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Mon Apr 28, 2008 11:17 am    Post subject: Re: The accident versus ready to fly aircraft |
				Flap Stop comment - The nylon stop does a good job of preventing movement of the retracted flap at the outboard end, while the inboard end is restrained by the actuating pin which rests in a slot.  I am considering installing a second stop at the inboard end to make it even more solid.
 Comments?
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
				 Posted: Mon Apr 28, 2008 12:24 pm    Post subject: The accident versus ready to fly aircraft |
				Sounds like an excellent idea Tim...
		Terry Phillips
  Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
				 Posted: Mon Apr 28, 2008 12:48 pm    Post subject: The accident versus ready to fly aircraft |
				Steve
 Along the same lines of general enlightenment, a while back you mentioned
 "drag spar" in one of your posts. I assume from the context that the drag
 spar is the rear spar. Is that correct? Thanks.
 Terry
 At 09:02 AM 4/27/2008 -0700, you wrote:
  	  | Quote: | 	 		  OMG !
 SW
 Terry Phillips
 ttp44~at~rkymtn.net
 Corvallis MT
 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
 are done; working on the wings
 http://www.mykitlog.com/N47TP/
  _________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
				 Posted: Mon Apr 28, 2008 1:11 pm    Post subject: The accident versus ready to fly aircraft |
				Yes em.
 Wings have "usually" two spars per side.  The main spar and the drag
 spar....
 "Some" designs these days have a humongous main spars and dont have a drag
 spar.
 These terms are from the 1940s til ???...
 Whatever they call them now is "what it is", my man...
 SW
		ashontz
				 Posted: Mon Apr 28, 2008 1:12 pm    Post subject: Re: The accident versus ready to fly aircraft |
				This is probably one of the more informative threads I've read on here in awhile. Thanks. Possible problems make more sense now. More than likely, the only problem is bad maintenance or construction.
		leinad
  Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
				 Posted: Mon Apr 28, 2008 3:55 pm    Post subject: Re: The accident versus ready to fly aircraft |
				Tim,
 It might work, but I think it could have the opposite effect.  By having the stop along way from the flap actuating lever, the flap is allowed to twist a little in the up position so that it's solidly held.  By putting a stop inboard, there won't be any twist and you may have it held firm on the inboard side but the flexibility of the flap will allow it to just rattle against the other stop.  If they could be adjusted so that the outboard one engaged first, allowed the flap to twist or spring a little, then the inboard one touches it might work.  All this just to say, I don't think your idea is a simple slam dunk.
 Dan
  	  | Quote: | 	 		  ="Tim Juhl"]Flap Stop comment - The nylon stop does a good job of preventing movement of the retracted flap at the outboard end, while the inboard end is restrained by the actuating pin which rests in a slot.  I am considering installing a second stop at the inboard end to make it even more solid.
 Comments?
 Do not archive |
  _________________ Scratch building XL with Corvair Engine |
